| Scotty |
 Scotty Scooter Boi
| G |
 G The Voice of Reason
| Scotty |
 Scotty Scooter Boi
| Robby |
 Robby Dirty Old Man
 Posted: 14:50 - 27 Feb 2003 Post subject: |
pull the lever back slightly and tie it in place with a bit of string. or a shoelace. leave it for a while, and the bubbles will rise up out of the line into the master cylinder, and the fluid from the master cylinder will fill the line.
the method that i use is to use distilled water bottle from a chemistry lab, tho any squeezy bottole will do. get some 6mm rubber or plastic tubing, and attach one end to the squeezy bottle, making sure its a good seal. squeeza the bottle closed, attach the other end to the open bleed nipple, and you have a vacuum pump. leave it for 5 mins, then close the nipple, disconnect the bottle, squeeze it again, and repeat the process. eventually you'll get some brake fluid and lots of bubbles going into the bottle.
oh yeh. hang the bottle over the handlebar or summat, so that the brake fluid in the pipe stops bubbles getting back in. |
| kevo |
 kevo Cop Seeking Missile
 Posted: 15:05 - 27 Feb 2003 Post subject: |
Cable tie the brake lever back the the handlebar overnight. Can work.
Another trick is to leave the bike to stand for a while, put some cloth around the top banjo bolt, pull the lever and the crack off the top banjo bolt and tighten it again
You can try using asyringe to push the fluid up from the bottom. I have a small vacuum bleeding kit that works quite well
| Scotty |
 Scotty Scooter Boi
 Posted: 15:17 - 27 Feb 2003 Post subject: |
and all these tricks should give me a nice tight brake.
not the spongy one i have at the moment
the only thing i have at the moment is like a pice of rubber
with the slit in the end to stop air getting back into the caliper.
i mean its been working but its not tight enough. ____________________ Regards
Scott |
| Demonic69 |
 Demonic69 The Pink Rhino
 Posted: 16:53 - 27 Feb 2003 Post subject: |
I did that! now my right brake caliper leaks  ____________________ Back on a Blade. Just feels so right. |
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 16:54 - 27 Feb 2003 Post subject: |
and you didnt think to tell me this BEFORE i went on your bike deano:?:  ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
| Demonic69 |
 Posted: 17:39 - 27 Feb 2003 Post subject: |
I only noticed when I got back
You're too much of a poof to ride the gixxer anyways  ____________________ Back on a Blade. Just feels so right. |
| WildGoose |
 WildGoose White Van Man
 Posted: 19:41 - 27 Feb 2003 Post subject: |
yeh these noobs on their highly engineered post 95 bikes
how many times did you stall again craig? how long did it take you to get on the road on deans bike??    ____________________ So in other words, he stopped you for being flagrantly in posession of a motorcycle in direct contravention of the Hippies, Darkies and People Whose Face I Don't Like The Look of (Police Powers) Act. 1976 |
| Scotty |
 Scotty Scooter Boi
| Demonic69 |
 Posted: 20:37 - 27 Feb 2003 Post subject: |
The Clutch is shit on the Gixxer, I'll give Craig that.
he didn't half whinge about the vibration though. I seemed to manage 400 miles on it though  ____________________ Back on a Blade. Just feels so right. |
| Scotty |
 Scotty Scooter Boi
 Posted: 21:04 - 27 Feb 2003 Post subject: |
yeh but his a big woman
not like us men , hey dean.
dean was so secure about his sexuality he had a pink bike  ____________________ Regards
Scott |
The last post was made 23 years, 130 days ago. Instead of replying here, would creating a new thread be more useful? |
