bleeding brakes
Scotty
Scooter Boi
PostPosted: 13:57 - 27 Feb 2003    Post subject: bleeding brakes Reply with quote
Erm i had to get a new master cylinder.
so i ended up landing one from a breakers yard.
anyway, fitted it this morning and have been bleeding the brakes for the past hour or so.
the brakes do work.
but there very spongy. and only seem to work at the last bit of leverage.
how do i make it so there as rock solid as
they where before??
Scotty
Regards
Scott
PostPosted: 14:23 - 27 Feb 2003    Post subject: Re: bleeding brakes Reply with quote
I think it's best to use a syringe from the bottom of the system when bleeding into a fresh system.
Have you tried the 'tying the brakes overnight' trick?
Scotty
Scooter Boi
PostPosted: 14:44 - 27 Feb 2003    Post subject: Reply with quote
nope, please go on and tell me...
Regards
Scott
Robby
Dirty Old Man
PostPosted: 14:50 - 27 Feb 2003    Post subject: Reply with quote
pull the lever back slightly and tie it in place with a bit of string. or a shoelace. leave it for a while, and the bubbles will rise up out of the line into the master cylinder, and the fluid from the master cylinder will fill the line.
the method that i use is to use distilled water bottle from a chemistry lab, tho any squeezy bottole will do. get some 6mm rubber or plastic tubing, and attach one end to the squeezy bottle, making sure its a good seal. squeeza the bottle closed, attach the other end to the open bleed nipple, and you have a vacuum pump. leave it for 5 mins, then close the nipple, disconnect the bottle, squeeze it again, and repeat the process. eventually you'll get some brake fluid and lots of bubbles going into the bottle.
oh yeh. hang the bottle over the handlebar or summat, so that the brake fluid in the pipe stops bubbles getting back in.
kevo
Cop Seeking Missile
Tie back the brake lever and leave it over night! Laughing
PostPosted: 15:05 - 27 Feb 2003    Post subject: Reply with quote
Cable tie the brake lever back the the handlebar overnight. Can work.
Another trick is to leave the bike to stand for a while, put some cloth around the top banjo bolt, pull the lever and the crack off the top banjo bolt and tighten it again
You can try using asyringe to push the fluid up from the bottom. I have a small vacuum bleeding kit that works quite well
Scotty
Scooter Boi
PostPosted: 15:17 - 27 Feb 2003    Post subject: Reply with quote
and all these tricks should give me a nice tight brake.
not the spongy one i have at the moment Wink
the only thing i have at the moment is like a pice of rubber
with the slit in the end to stop air getting back into the caliper.
i mean its been working but its not tight enough.
Regards
Scott
Demonic69
The Pink Rhino
PostPosted: 16:53 - 27 Feb 2003    Post subject: Reply with quote
I did that! now my right brake caliper leaks Very Happy
Back on a Blade. Just feels so right.
craigT19
Jolly Green Giant
PostPosted: 16:54 - 27 Feb 2003    Post subject: Reply with quote
and you didnt think to tell me this BEFORE i went on your bike deano:?: Laughing Confused
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
Demonic69
The Pink Rhino
PostPosted: 17:39 - 27 Feb 2003    Post subject: Reply with quote
I only noticed when I got back Very Happy
You're too much of a poof to ride the gixxer anyways Razz
WildGoose
White Van Man
PostPosted: 19:41 - 27 Feb 2003    Post subject: Reply with quote
yeh these noobs on their highly engineered post 95 bikes
how many times did you stall again craig? how long did it take you to get on the road on deans bike?? RazzRazzRazz
Scotty
Scooter Boi
PostPosted: 19:56 - 27 Feb 2003    Post subject: Reply with quote
well the tie back idea is working nicly for the moment.
oh how can you stall!!!
espcially on a bigger bike, i would have thought it was easier, tisk tisk...
Regards
Scott
Demonic69
The Pink Rhino
PostPosted: 20:37 - 27 Feb 2003    Post subject: Reply with quote
The Clutch is shit on the Gixxer, I'll give Craig that.
he didn't half whinge about the vibration though. I seemed to manage 400 miles on it though Razz
Scotty
Scooter Boi
PostPosted: 21:04 - 27 Feb 2003    Post subject: Reply with quote
yeh but his a big woman Wink
not like us men , hey dean.
dean was so secure about his sexuality he had a pink bike Wink
Regards
Scott
The last post was made 23 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 79.35 Kb
