Getting to grips with winter
-Savage-
PostPosted: 19:43 - 10 Oct 2005    Post subject: Getting to grips with winter Reply with quote
Has anybody got any experience with Oxford hot grips, as i have seen them on offer for £39.99, reduced from £59.99.
I was wondering if any of you all year bikers have used them, and secondly, would they be easy to install on a cbr600f?
extreme3d
PostPosted: 19:59 - 10 Oct 2005    Post subject: Reply with quote
I'm assuming you mean the over-grips? If so, I've got them on my SV! Had normal heated grips on my last bike so can make a good comparison. The oxford ones seem hotter to me and this may be due to them being fabric rather than rubber. They are very easy to fit as you don't actually need to remove your current grips - they just wrap around them.
To fit you just connect the wires to the battery, mount the switch, wrap the over-grips around the bikes grips (The grips are rubber lined so don't slip) and finally cable tie the wires out of the way. Much easier than standard grips where you have to cut away the old grip.
Another advantage i can see is that come summer you can just unwrap the over-grips and unplug them (they plug into the switch so you can leave that and the battery connections in place). A normal heated grip is on for good and like normal rubber grips will eventually wear down and expose the heating elements.
Mr.Everready
PostPosted: 20:01 - 10 Oct 2005    Post subject: Reply with quote
On Ebay at £29.99
https://cgi.ebay.co.uk/OXFORD-2005-HOT-GRIPS-LATEST-MODEL-HOTGRIPS_W0QQitemZ8006318758QQcategoryZ25643QQrdZ1QQcmdZViewItem
Mr.Everready
PostPosted: 20:02 - 10 Oct 2005    Post subject: Reply with quote
Or the over grips at £24.99 Wink
https://cgi.ebay.co.uk/OXFORD-HOTHANDS-HOT-HANDS-HEATED-OVER-GRIPS-BMW-CBR-R1_W0QQitemZ8005921821QQcategoryZ25626QQrdZ1QQcmdZViewItem
Mr.Everready
PostPosted: 20:03 - 10 Oct 2005    Post subject: Reply with quote
Forgot to say that they are buy it now, they'll be cheaper if bid on I'd guess.
mr.z
PostPosted: 20:05 - 10 Oct 2005    Post subject: Reply with quote
Had heated grips before, they are not a total soloution to cold hands in winter.. only thing that will do that is heated gloves..
Grips are ok till it gets to -numbers, or going allong @5degrees for an hour, then they are pretty useless (even turned right up they just burn your palm while your knuckles are beeing frozen)
Nb
PostPosted: 20:27 - 10 Oct 2005    Post subject: Reply with quote
I dont have heated grips but i will be purchasing some soon, to go along with these ive just bought. https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4580946774&rd=1&sspagename=STRK%3AMEWN%3AIT&rd=1
My hands should be dry and warm even if they do look a bit odd. Laughing Wink
mr.z
PostPosted: 20:31 - 10 Oct 2005    Post subject: Reply with quote
Apparently they work great (usually) but make sure they dont foul your clutch or brake levers... maybe fit some sort of metal strip to hold it away from them...?
Nb
PostPosted: 20:37 - 10 Oct 2005    Post subject: Reply with quote
Good thinking, i'll make sure they dont foul anything. Then i'll get some overgrips to help. Sure ive seen them on ebay for about 20 quid... Very Happy
Teaman
PostPosted: 21:36 - 10 Oct 2005    Post subject: Reply with quote
I have Daytona heated grips,,, 25 quid i think,, i love em, wouldnt leave home without em
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
mattsmith95
PostPosted: 22:20 - 10 Oct 2005    Post subject: Reply with quote
Connect to the battery? are you mad? You only do that if you have a kickstart. (that's one way to kill your battery)
To fit properly there is a spare feed in the loom, remove the headlight and you should find a free brown wire.
Teaman
PostPosted: 22:31 - 10 Oct 2005    Post subject: Reply with quote
I still have my old grips and not a single cut in them,, ok they were a bitch to get off but i still did it,,and i use renthal grip glue
The last post was made 21 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 74.45 Kb
