Prep for winter riding
gavking
PostPosted: 13:21 - 10 Oct 2005    Post subject: Prep for winter riding Reply with quote
I know there's been a few topics about preping a bike to stay in the garage all winter, but what can you do to save your pride and joy through the winter months if you're not able to afford a winter hack? My bike in particular is a naked bike with a cockpit fairing and has a lot more exposed to the elements.
XJR400R, Ohlins Shocks, Brembo brakes all round, Full Digital dash, Cockpit fairing, twin lamp headlight. Lookin' Good!
mchaggis
PostPosted: 20:15 - 10 Oct 2005    Post subject: Reply with quote
Don't put it to bed with wet forks, they'll probably get pitted. Smear grease/ vaseline over anything shiny which doesn't get hot. Check the chain and lube it at least every week, if not twice a week. Check your tyre pressures and keep them inflated to the correct pressure. You'll start sliding about much faster on low pressure tyres in the muck.
Also, keep a close eye on your petrol and oil, and get breakdown cover. Also consider carrying spare bulbs and cables. Breaking down in the middle of winter is not fun.
Edit: forgot to mention, use vaseline on your battery terminals and electrical connectors, and plenty of WD40 regularly on switchgear, particularly the rear brake light switch, which gets clarted up and sticks remarkably easily.
I must not be a troll...
Mmmm, Guinness
fast_tzr
PostPosted: 23:02 - 10 Oct 2005    Post subject: Re: Prep for winter riding Reply with quote
Where? I cant find any.
The Old Geeza
Back in my day...
PostPosted: 23:32 - 10 Oct 2005    Post subject: Re: Prep for winter riding Reply with quote
Wash the bike thoroughly and dry it off completely - let it dry off naturally for a couple of days if you have to. Take the seat off, then, spray EVERYTHING completely with WD40 - including the brakes. Put a cover over the bike and leave it. But, about twice a Month, start the engine and allow it to run for about 10 minutes. When the engine's warm, rev it up very gently. This will ensure the petrol in the carbs is completely used up, the jets are cleaned out and fresh petrol is supplied from the tank. It also stops the inside of the cylinders from oxidising and 'pitting'. Basically, what you need to do is keep the bike 'dry' from the inside. This includes getting the engine and exhausts hot to disperse any moisture.
I'm no expert and this is a very simplistic approach which should serve you well. But, if you want to 'put your bike to bed' for the winter, without doing anything, then the procedure is far more complex - as anyone will tell you. I'm just offering a little bit of help. But, no doubt I'm about to be shot down in flames by superior bikers (as always)!
Horse Power was safer when the Horses had it!
mchaggis
PostPosted: 23:35 - 10 Oct 2005    Post subject: Re: Prep for winter riding Reply with quote
Tut Tut
Don't go near things which rely on friction to keep you alive with WD40, you're asking for trouble.
Mmmm, Guinness
instigator
PostPosted: 23:39 - 10 Oct 2005    Post subject: Reply with quote
Well, usually I'd go with what you said haggis but if the bike is going to be stored away for a good few months and won't be ridden, then wd40 on the brakes shouldn't cause any problems.
Because it is easy enough to get off (in my own opinion it is anyway).
Important this is to: RINSE/SCRUB IT OFF WHEN YOU WANT TO RIDE IT. Laughing
The Old Geeza
Back in my day...
PostPosted: 23:47 - 10 Oct 2005    Post subject: Re: Prep for winter riding Reply with quote
mchaggis wrote:
Tut Tut
Not so when you're storing the bike for winter. It will prevent the disks rusting over the winter. A damp rag of cellulose thinners on the disks will soon clean off the film of WD40 when the bike is needed next season. And if any of it got onto the brake pads (which is unlikely to any large degree), this will be removed the first time the brakes are applied Thumbs Up
mchaggis
PostPosted: 23:49 - 10 Oct 2005    Post subject: Reply with quote
Fair dos.
The way I read his question, he was riding over the winter, in which case oil and brakes is a contract with the undertakers. For storage, I can't see too many problems, so long as you don't forget that you did it.
Mmmm, Guinness
colin1
Captain Safety
PostPosted: 02:39 - 11 Oct 2005    Post subject: Reply with quote
i dont think discs rusting over winter is a problem, as the rust will just be removed by the pads when its next used
gavking
PostPosted: 12:47 - 11 Oct 2005    Post subject: Reply with quote
sorry maybe I wasn't clear. I DO intend to ride over the winter because i cant afford a second bike. So i'm after tips for saving paint and metalwork from the nastiness of salt and grit n the other shit they throw around these days.
Gav.
gavking
PostPosted: 12:53 - 11 Oct 2005    Post subject: Re: Prep for winter riding Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=34335
mmm... search function.... Drooling
spitfire
PostPosted: 17:13 - 11 Oct 2005    Post subject: Reply with quote
Obvious, but ensure you let the bike warm up and remember that the tyres will take longer to warm. If the bike is water cooled ensure the antifreeze is at the correct gravity, if not top it up. Check the oil and keep the petrol topped up.
If you are not using it for a few days, charge the battery.
Try and keep the bike warm, its not nice sitting on a frost covered seat in the morning, cover it in blankets or nick the duvet from the spare room, I'm sure the missus wont mind Wink
Don’t forget yourself, warm dry kit is a must and ensure you have a good breakfast before you go. If it's really cold I use my skiing kit such as socks and thermals.
Oh and don’t be a hero, unless you have to don’t ride in ice or snow (although snow can be fun on a dirt bike) take the car, train, bus or get a lift.
Mrs Kickstart
PostPosted: 19:02 - 11 Oct 2005    Post subject: Reply with quote
Hi,
Consider some Fork Gaiters I had some on the GPZ which was used all year and really did seam to help.
How many miles / how far do you go ?
I have fitted a scotoiler to my ZZR which so far is working.
WD is an essential buy (but not for the brakes if your riding it).
Just do what you can to keep the salt off.
Also crash bungs just in case
Regards
Charlotte
(who is usually to lazy to do the above)
DAF
PostPosted: 21:45 - 11 Oct 2005    Post subject: Reply with quote
I've heard Finnegan's waxoyl is recommended as a good bike protector for all weather riding.
Anyone here used it or have any idea where to buy it? Did a Google but didn't come up with much.
2005 Yam Fazer (FZ6-S)
mrchips
PostPosted: 22:31 - 11 Oct 2005    Post subject: Reply with quote
Best thing is to grease everything that can corrode. Don't wipe the grease off untill spring.
Northern Irish? www.nibikers.com
The last post was made 20 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 88.74 Kb
