oil filter
riichy
PostPosted: 14:43 - 11 Oct 2005    Post subject: oil filter Reply with quote
ok when i finaily get my oil filter off, it says on the box 1.5~2.0kg of torque. only thing is i dont have a torque ratchet... so can i just tighten it by hand ???? Thumbs Up
riichy
.......... PLOD ............ zx636 2004
sanchezz_182
PostPosted: 14:49 - 11 Oct 2005    Post subject: Reply with quote
yup, when doing my car one i just get a rag or sumthin an giv a gd twist,, so its tight, an then a little more,,
if when u start the bike up it leakes tighen it sum more,,, simple
no sig, thats gay!!
Walloper
PostPosted: 15:57 - 11 Oct 2005    Post subject: Reply with quote
Rule of thumb:
Clean the contact area where the rubber seal seats.
Oil the rubber seal of the new filter with clean oil
Spin on the new filter till it JUST touches the engine case.
Tighten by turning by hand about 2/3 or 3/4 turn.
It should feel tight by this time (If you're not a gay body builder Laughing )
Check engine has enough oil to start
Start engine
Check for oil leaks past seal of filter
If leaking turn on a bit more (unlikely)
Stop engine and top up the oil that the engine put through the filter.
Put bike back in shed, clean floor of kitchen before mum gets home. Laughing
riichy
PostPosted: 16:01 - 11 Oct 2005    Post subject: Reply with quote
Walloper wrote:
Rule of thumb:
Start engine
walloper your a book of knowledge.. Wink thanks fella Thumbs Up
Mr.Everready
PostPosted: 16:03 - 11 Oct 2005    Post subject: Reply with quote
It was a copy and paste from another site.
You don't really think he knows that stuff do you ? Rolling Eyes
Walloper
PostPosted: 16:10 - 11 Oct 2005    Post subject: Reply with quote
You cheekie monkey you. Laughing
I knew loads more than just that Laughing
riichy
PostPosted: 16:14 - 11 Oct 2005    Post subject: Reply with quote
Embarassed
spitfire
PostPosted: 16:18 - 11 Oct 2005    Post subject: Reply with quote
Walloper wrote:
Rule of thumb:
Start engine
I actually fill the new filter with clean oil as well so you don't have to top up so much, does depend on the filter type and location though
Walloper
PostPosted: 16:19 - 11 Oct 2005    Post subject: Reply with quote
Embarassed
No worries rich babe, I was often told by teach' to give the others a chance to answer. Laughing
riichy
PostPosted: 16:46 - 11 Oct 2005    Post subject: Reply with quote
Embarassed[/quote]
No worries rich babe, I was often told by teach' to give the others a chance to answer. Laughing[/quote]
Laughing Laughing Laughing Thumbs Up
Mr.Everready
PostPosted: 16:51 - 11 Oct 2005    Post subject: Reply with quote
Yup, I do that too.
riichy
PostPosted: 16:52 - 11 Oct 2005    Post subject: Reply with quote
yer but all the oil will just spill out as soon as you trun it to put it on Confused
spitfire
PostPosted: 16:54 - 11 Oct 2005    Post subject: Reply with quote
true....it does normally work better on cars but I just love spilling oil everywhere Laughing
Mr.Everready
PostPosted: 17:00 - 11 Oct 2005    Post subject: Reply with quote
It does a wee bit, it's all part of the fun.
riichy
PostPosted: 17:17 - 11 Oct 2005    Post subject: Reply with quote
you to are crazy ........ Laughing
Walloper
PostPosted: 19:17 - 11 Oct 2005    Post subject: Reply with quote
Technical Stop Press:
The oil filter works by catching and preventing particles suspended in the oil from causing damage to close fitting engine components.
Determined by each engine manufacturer. somewhere in the small micron department. (1 micron= 0.000045 of an inch)
By construction the flow of oil through the filter means foreign bodies reaching the 'Up Stream' side of the filter paper from the sump via the oil pump are trapped in the fine matrix (paper, steel mesh, fabric etc).
If you fill the filter prior to installation in theory you could permit debris/dirt etc to be deposited in the 'down Stream' side of the filter.
When the flow of oil through the filter picks up this material it could block a gallery or cause serious damage to engine parts.
It doesn't take much time for the oil pump to fill the filter on start up. Just don't give it a handful until engine conditions stabilise.
spitfire
PostPosted: 19:20 - 11 Oct 2005    Post subject: Reply with quote
hum...interesting point
Mr.Everready
PostPosted: 19:21 - 11 Oct 2005    Post subject: Reply with quote
in theory
Whistle
riichy
PostPosted: 19:26 - 11 Oct 2005    Post subject: Reply with quote
Mr.Everready wrote:
in theory
Whistle
boom Wink
Walloper
PostPosted: 20:17 - 11 Oct 2005    Post subject: Reply with quote
Oh you bums you Laughing
bish777
PostPosted: 20:26 - 11 Oct 2005    Post subject: Reply with quote
Wellll you should fill the filter to ensure immediate oil pressure to the engine, to prevent things grinding themselves, particularly the cams,valves etc which are particularly sensitive.
Id personally pre fill the filter to make sure the engine isnt briefly starved of oil, rather than worrying about the chance of some crud getting into the filter.
GSXR1100J
0ddball
PostPosted: 20:40 - 11 Oct 2005    Post subject: Reply with quote
It's only really of use on a turbo engine, i still do it as a matter of course though.
ZXR750L
Walloper
PostPosted: 20:42 - 11 Oct 2005    Post subject: Reply with quote
When you dismantle any engine that's been running normally aren't all the bits covered in nasty oil.
The only real concern for the 'oil pressure' is when the engine is under load and oil pushed out from friction surfaces needs to be replenished rapidly.
This is the case for most high speed machinery.
Some machines having NO oil pump rely solely on 'splash lubrication' can and do run for 20 years or more without failing.
The filter is filled within seconds of the engine starting and this is not that much longer than a normal starting cycle takes to fill galleries.
What if the bikes been parked up for a couple of months???
The last time it was running the oil was hot and the filter was full. After cooling down the oil shrinks an drains normally to sump. You have nowt but air on top of the oil now so when you start you have that 'bubble' to push out.
You cold start more times than you change a filter so where is the problem?
The pathways are shorter than on great big dirty engines so no worries.
The lubrication duty of the oil is provided by the oil molecules adhering to one and other in the oil film. (Microscopic possibly 1 molecule thick.)
Now:
If you have disassembled an engine for major surgery then it would be a good idea to turn the engine over with the plug leads off for a few seconds.
You will still have protection as you 'should' have coated everything with clean oil during assembly.
bish777
PostPosted: 20:47 - 11 Oct 2005    Post subject: Reply with quote
Thats larger motors that are DESIGNED that way.
On a complex engine like most modern bikes, with alot of gear in the head, look in the top of a yamaha genesis FZ/FZR/R1/R6 motor for example. Theres alot of gear in there that are on oil dependant plain bearings. Id rather make sure they didnt have to run without oil for the bare minimum of time.
My XBR500 succumbed very rapidly to poor oil feed to the head, and Its also what i believe killed my FZR1000.
So id rather not take my chances.
Its also what most manufacturers recommend, Suzuki, Yamaha and Honda certainly do.
GSXR1100J
riichy
PostPosted: 20:55 - 11 Oct 2005    Post subject: Reply with quote
well did my oil change, and my god it made a diffrence bike runs smooth as a babys botom. plus i just put some oil on the o ring of the new filter, then put oil in and started ran fine. so why is everyone saying put oil in the filter first, wouldnt they put it on the filter box if thats what you had to do Question Confused
The last post was made 21 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 130.8 Kb
