New Brake pads grinding
Blackbird
PostPosted: 22:55 - 11 Oct 2005    Post subject: New Brake pads grinding Reply with quote
I just replaced the brake pads on a blackbird. I have done about 120 miles, the stopping power is not great and They are grinding real bad in the wet just as it is about to stop. Does anyone have any ideas?
Thanks
Blackbird
tatters
Exxon Valdez
PostPosted: 00:17 - 12 Oct 2005    Post subject: Reply with quote
Have you put them in the right way, with the metal side of the pads facing the pistions and not the disk?
Whats the condision of the brake disks like, any tracks or sgins of really bad wear?
White Noise
Mr Dudwee
PostPosted: 00:20 - 12 Oct 2005    Post subject: Reply with quote
please tell me people don't do this! Rolling Eyes
WN
Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight
alains
PostPosted: 00:53 - 12 Oct 2005    Post subject: Reply with quote
your disc need to be rectified if it's not wraped . an other trick when you change pads : make their surface a bit rough with sandpaper (40 or bigger) or with a cutter make several crossing strips with a cutter .
see the design (soory i'm not very good)
Blackbird
PostPosted: 11:23 - 12 Oct 2005    Post subject: Brakes Reply with quote
Hi White noise
thanks for the reply. but yes they are in the right way.
Blackbird
the grim reaper
PostPosted: 12:57 - 12 Oct 2005    Post subject: Reply with quote
Blackbird,
If you bought OE pads, be aware that they are contoured pads and they do tend to grind when new. Also, check that there are no lumps of sinter in the pads, I've seen that before.
Cheers
Grim
The last post was made 20 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 47.58 Kb
