Starter motor..
nibraz
PostPosted: 01:28 - 13 Oct 2005    Post subject: Starter motor.. Reply with quote
Hello,
In my gilera dna something is wrong with the starter motor. When I press the electric start i jus hear a sound saying ''click'' is their any way i can fix that?
alains
PostPosted: 12:15 - 13 Oct 2005    Post subject: Reply with quote
first of all , put your battery on charge for 8-12 hours at 0.5 Amps
then try . if it's the same , 2 options :
- starter relay is worn
- starter motor needs maintenance : change brushes,springs then commutator cleaning and oiling the mobile parts
fuzz
PostPosted: 12:46 - 13 Oct 2005    Post subject: Reply with quote
You could have worn brushes in your starter motor. The click is the starter relay. If you dont hear the starter motor turning, the brushes are probably not making contact with the comutator.
benc
PostPosted: 03:57 - 14 Oct 2005    Post subject: Reply with quote
it could also be that the engine wont turn over. ive had this once with mine when the floats had stuck and the engine had filled with petrol, but other things could cause it. it could be seized but im sure you would have noticed it if it happend.
Mark_petty
PostPosted: 09:22 - 14 Oct 2005    Post subject: Reply with quote
I had the same on my bike, I hit the starter motor with a hammer then tried starting and it fired up as normal
[Rides: Suzuki GSF600sx]
[CBT: Passed] [Theory: Passed] [DAS: Passed]
alains
PostPosted: 12:24 - 14 Oct 2005    Post subject: Reply with quote
this was a sign of a badly maintained bike . the starter motor has a mobile pinion which need to be lubricated time to time (once every 2-3 years) ! Sad
Mark_petty
PostPosted: 12:50 - 14 Oct 2005    Post subject: Reply with quote
my starter went coz I dropped the bike Sad damaging the starter
Robby
Dirty Old Man
PostPosted: 13:19 - 14 Oct 2005    Post subject: Reply with quote
What a lot of silly posts.
As the search function will attest to, with instances of this popping up in this forum at least 4 times a week, your problem is a dead battery.
Dead battery doesn't have enough power to turn the engine over. Tis the season for them to fail a lot. The clicking is the starter relay and engaging and disengaging.
fuzz
PostPosted: 13:35 - 14 Oct 2005    Post subject: Reply with quote
Well a dead battery certainly wasn't the cause of my starting problem, so nah nah Razz
Mark_petty
PostPosted: 15:35 - 14 Oct 2005    Post subject: Reply with quote
not always the fault.
My starter failed but my battery was fine (virtually new)
nsr_rk_boy
PostPosted: 17:15 - 14 Oct 2005    Post subject: Reply with quote
get a charger and put the live straight on the live on the starter motor if it still clicks then there nothing wrong wid the battery and u will prob want a new starter
alains
PostPosted: 19:10 - 14 Oct 2005    Post subject: Reply with quote
or a starter relay !
arsehole
PostPosted: 11:40 - 16 Oct 2005    Post subject: Reply with quote
the starters have a solenoid starter switch atached or built into the startermotor, when you press the ingnition switch a small amp wire operates the solenoid switch which creates a contact through the soleniod to the motor and the main live feed from the battery the soleniod is a type of electro magnetic switch and can sometimes get fouled with carbon from electric arcs from contact wear (you hear the sound of the solenoid click across but due to the carbon deposit it cannot create the circuit to the battery) tapping it with a spanner sometimes cause it to create a circuit but if you can dismantle the solenoid or get some spray contact oil in it, it might solve your problems I find GT85 oil the best dont bother with WD40. sorry its long winded
But Hope this helps
alains
PostPosted: 11:55 - 16 Oct 2005    Post subject: Reply with quote
i agree my dear , exactly what i was thinking
sickpup
Old Timer
PostPosted: 19:08 - 16 Oct 2005    Post subject: Reply with quote
As well as the above it's quite coomon for the the starter gear to fail, it no longer throws out but you would hear the starter motor.
nibraz
PostPosted: 00:01 - 17 Oct 2005    Post subject: Reply with quote
But Hope this helps
So I just spray with GT85 oil into the starter motor?
nibraz
PostPosted: 22:32 - 17 Oct 2005    Post subject: Reply with quote
Is this the electric start motor shown in pic??
https://img398.imageshack.us/img398/1060/newimage1vh.jpg
alains
PostPosted: 22:36 - 17 Oct 2005    Post subject: Reply with quote
it looks like an electric motor ! should be it
nibraz
PostPosted: 22:38 - 17 Oct 2005    Post subject: Reply with quote
Cool! Thanks for helping Very Happy
fuzz
PostPosted: 23:54 - 17 Oct 2005    Post subject: Reply with quote
Looks like the top half of it anyway Wink
The last post was made 20 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 103.07 Kb
