Wheelie Q- Throttle
freestyler_onli
PostPosted: 19:46 - 13 Oct 2005    Post subject: Wheelie Q- Throttle Reply with quote
When it says 'Shut off the throttle' does it mean let it go or physically twist it closed?
Ta.
fuzz
PostPosted: 20:04 - 13 Oct 2005    Post subject: Reply with quote
You should always roll the throttle off rather than let it go, then you are in control.
freestyler_onli
PostPosted: 20:05 - 13 Oct 2005    Post subject: Reply with quote
Ok ta for that! Cool
Sparks!
Sir Tart-a-lot
PostPosted: 20:13 - 13 Oct 2005    Post subject: Reply with quote
Wheelie + shut off the throttle should never happen unless you want to hurt yourself Laughing
freestyler_onli
PostPosted: 20:16 - 13 Oct 2005    Post subject: Reply with quote
Thats what a bloke in a video said, although he may have meant something else.
What do u think is the best way to get it up then?
The bike i mean........... Embarassed
Sparks!
Sir Tart-a-lot
PostPosted: 20:17 - 13 Oct 2005    Post subject: Reply with quote
Well for starters, shutting the throttle off won't get the wheel up Wink Laughing
fuzz
PostPosted: 20:22 - 13 Oct 2005    Post subject: Reply with quote
Roll the throttle on while slipping the clutch, then let the clutch out once the revs have risen should get the front up.
Roll off the throttle to set it down. Snap it shut and you'll probably land awkwardly. Roll it of and you should set it down more gently.
freestyler_onli
PostPosted: 20:25 - 13 Oct 2005    Post subject: Reply with quote
Aaaaah i see what you mean.
I/he was referring to the initial part of getting the front wheel up- go at 5-10 mph then ''shut the throttle'' and snap it open again.
Although yes, i agree with what you are saying! Razz
fuzz
PostPosted: 20:27 - 13 Oct 2005    Post subject: Reply with quote
The only reason I can see to shut the throttle off before opening it again, is to get the bike up off power using the rebound in the forks to help lift the front. (The forks will compress under engine breaking.) But I would have thought you need to be going faster than 10mph in the first place.
If the bike is not capable of lifting simply by pinning the throttle open, you would need high revs to get max power as you close and then re-open the throttle.
freestyler_onli
PostPosted: 20:32 - 13 Oct 2005    Post subject: Reply with quote
Aaaaah right.
He did mention something about feathering the clutch but this way seemed easier.
We'l see what happens!
(Crash probably)
Collier
PostPosted: 09:49 - 14 Oct 2005    Post subject: Reply with quote
Wheelie in 2 steps...
1. Buy RSV Mille
2. open throttle hard in 1st... or 2nd Laughing Laughing
freestyler_onli
PostPosted: 09:53 - 14 Oct 2005    Post subject: Reply with quote
LOL.
I had a go on my mates R1 once and it felt like Vanessa Feltz was on the back-the way it kept lifting the front end up! Laughing
Walloper
PostPosted: 10:18 - 14 Oct 2005    Post subject: Reply with quote
LOL.
What are ye trying to say 'bout wur lass?
Walloper
PostPosted: 10:23 - 14 Oct 2005    Post subject: Reply with quote
Ger off
freestyler_onli
PostPosted: 10:36 - 14 Oct 2005    Post subject: Reply with quote
It was a quote from...Fast Bikes magazine i think it was- or maybe T.W.O.......... Confused
Dark
PostPosted: 11:01 - 14 Oct 2005    Post subject: Reply with quote
I find dabbing the rear brake hard as well as shutting the throttle creates more rebound in the forks and with a little dip on the clutch sends the front wheel skyward on any bike with ease.
If the front wheel flys up violently rather than attempting to control it with rolling off the throttle, and risk loosing the wheelie altogether, i quick shift into the next gear. That seems to put a halt on the violent up surge and you invariably end up somewhere around the balance point.
This technique was mastered over about 3 years on a ZX7R and i can honestly say that the lighter the bike the easier it is. Works a treat on 400's for instance.
My Bikes in order:- Yamaha RXS100 / Suzuki X7 250 / Yamaha RD350LC / Kawasaki
KR1S 250 / Kawasaki ZXR750 H2 / Honda C50 / Kawasaki ZX7R P5 / Kawasaki ZX10R / Suzuki GSXR 400 / Honda CBR1100 Blackbird & Yamaha FZR 600
mylow
PostPosted: 11:13 - 14 Oct 2005    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=59792
I found this on another website a wile ago, bit long but worth a read, hope it helps[/url]
BSM Rider Traing, CBT's DAS and Instructor Training 01454 658 325
Funkmeister_Smith
PostPosted: 11:20 - 14 Oct 2005    Post subject: Reply with quote
I just recentley passed my test & started riding a GSXR600, after riding 125's for nearly 2 years, and have yet to master the art of the wheelie.
I find if I go up to about 6-7000 revs in 1st gear then 'rive' the throttle back, the front end will lift quite nicely, but then I shit myself & ease it back down! Embarassed It probably only goes about a foot/foot & a half off the ground, but there you go!
Trouble is, I'm a bit wary of doing a wheelie off the clutch on a 600. I used to try & do it on my first bike (TDR 125), it would only just work but it would make a nasty *clunk* noise, which immediately put me off! And apart from that, I don't want it to chuck me off or anything either (the 600 that is). Neutral
Dark
PostPosted: 11:29 - 14 Oct 2005    Post subject: Reply with quote
I use to get a clunking noise on some of the smaller bikes i rode too. But you shouldn't have a problem with that on your gixxer6, as long as your bikes in good mechanical order. Besides, you'll be surprised how little clutch you actually need.
PostPosted: 13:20 - 14 Oct 2005    Post subject: Reply with quote
In this instance, when they say 'shut off the throttle' they mean turn the throttle back with your hand.
It's more of just a dip, so your hand goes up, then comes back down quickly.
The last post was made 21 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 105.11 Kb
