are their any radiator repair things that actually work?
gimpy limp
PostPosted: 17:57 - 13 Oct 2005    Post subject: are their any radiator repair things that actually work? Reply with quote
dunno how many times ive bought radweld put it in when warm with the engine running and it hasn't worked (I think it's like 5/6 quid a pop aswell?).
It's only a sneaky small leak but it's all dripping down onto my downpipes.
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
Walloper
PostPosted: 18:05 - 13 Oct 2005    Post subject: Reply with quote
Barrs Leaks. Thumbs Up (That's the name)
Nowt else.
Follow instructions.
map
Mr Calendar
PostPosted: 18:06 - 13 Oct 2005    Post subject: Reply with quote
Any leak probably means new radiator time. Bike radiators are tiny. Radweld stuff probably block it in the wrong place. Even if it stops a leak you'll only be running on part of the radiator so not very efficient.
FWIW I've always been told the old trick of using an egg works best. Never tried it myself but have had several first hand stories of it working.
Rob W
PostPosted: 18:12 - 13 Oct 2005    Post subject: Reply with quote
Nowt else.
When I used Barrs Leaks on my ZXR, all it did was block up the the coolant jacket around the head. Probably made it worse to be honest, because when I did the head gasket it was full of that shit.
gimpy limp
PostPosted: 18:14 - 13 Oct 2005    Post subject: Reply with quote
it does look slightly dodgy actually just ran a goodle search:
https://www.dodgedakotas.com/boards/per/3244.html
see last post. Maybe not ideal on a 26year old engine
finpos
PostPosted: 18:38 - 13 Oct 2005    Post subject: Reply with quote
If the rad's old and tired, change it. I'll be springing new leaks on a regular basis in the near future.
If it's in good condition and just been punctured by a stone or something, try crimping together the channel each side of the hole with fine pliers and then using chemical metal or some other epoxy type stuff to seal it from the outside.
And then you'll need to figure out how to get all the radweld gunk out of the water channels in your engine.
fin.
nsr_rk_boy
PostPosted: 22:37 - 13 Oct 2005    Post subject: Reply with quote
the egg trick works.......... crack the egg get rid of the yoke and put the rest in.
in fact it works better than radweld
bish777
PostPosted: 22:42 - 13 Oct 2005    Post subject: Reply with quote
if you can locate the leak externally you can repair it with JB weld or similar.
GSXR1100J
Teaman
PostPosted: 23:25 - 13 Oct 2005    Post subject: Reply with quote
https://cgi.ebay.co.uk/holts-rad-weld_W0QQitemZ4582392060QQcategoryZ40019QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Ive used it on my old gpz,, had a prob with a leaky pipe worked a treat,, also mended a bad leak on my old cx radiator
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
0ddball
PostPosted: 23:31 - 13 Oct 2005    Post subject: Reply with quote
I though i was having deja vu when i saw this post. Then i realised i'd just seen your post on mig. Laughing
Despite the cost i'd get a new one. Even if you bodged the old one up it would probably fail completely sometime in the future and leave you stranded.
ZXR750L
tatters
Exxon Valdez
PostPosted: 23:34 - 13 Oct 2005    Post subject: Reply with quote
super glue and a pair of long nosed pliers can be used to fix leaking fins, l,ve used this method quite a few times to fix small pentrations.
gimpy limp
PostPosted: 23:35 - 13 Oct 2005    Post subject: Reply with quote
lol
70 quid down the drain Crying or Very sad Crying or Very sad Crying or Very sad cry's
Walloper
PostPosted: 10:54 - 14 Oct 2005    Post subject: Reply with quote
Reflex wrote:
Nowt else.
Do you know what you are doing?
Mix the compound as instructed on the packet.
It is measured for a car engine maybe 1.5 - 2 gallons of coolant in the system.
Maybe you used tooooo much. Embarassed
It is not a perfect solution (No Pun) but is perfect if you need some time to save up the readies to buy a new rad.
Before fitting th new rad use Barrs Flush in the system to clean out all the crud.
In correct solution Barrs leaks will not block the system.
mr.z
PostPosted: 11:19 - 14 Oct 2005    Post subject: Reply with quote
There are companys that will rebuild your radiator for £70/80/90 (my cx/b cost 70) appart from buying a new/second hand one this is the best way of going about it..
Have you thought about buying a donor bike? Wink
The last post was made 21 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 83.39 Kb
