| LUXY DJ |
 LUXY DJ World Chat Champion
 Posted: 21:51 - 15 Oct 2005 Post subject: 1st gear bogging problem... |
right i dont know what it can be but basically in 1st gear when pulling away its PROPER slow & boggy then @ about 5-10mph it then kicks in & its fine thro all the gears but this is a C**T cause when lights change & im still kinda sitting there & even cars are pulling away better then me I KNOW THERES A PROBLEM so .....any ideas peeps? man who dont alot of my setting up...1st said it might be the clutch plates but then he tried it 2day but only breifly as he was very busy & i was in & out & now reckons it deffo aint anything to do with the clutch but he did say just try cleaning the air filter out 1st (which i am now) but what other thing/s could it be?
thanks in advance  ____________________ GSXR750
(FAR FAR from standard) www.gixerjunkies.net |
| McGee |
 McGee O RLY?
| LUXY DJ |
 Posted: 22:19 - 15 Oct 2005 Post subject: |
yea pipe aint a std 1!
so what 2 rich or 2 lean u reckon?
anymore suggestions  ____________________ GSXR750
| LUXY DJ |
 Posted: 22:55 - 15 Oct 2005 Post subject: |
ok cheers but i would of thought it would have been 2 rich hence it bogging down(2 much fuel,oil) cause lean is less but a lot more dodgy (use to strip 2t's) so plug colour will still tell me wont it? same as 2t's? ____________________ GSXR750
| stu_m |
 stu_m Crazy Courier
| LUXY DJ |
 Posted: 00:11 - 16 Oct 2005 Post subject: |
yea did think of that aswell but would that cause only 1st gear doing it? its quite dodgy really cause u try to go from lights & its dodgy cause cars think they should takeover me cause im not hardly moving but then its even more dodgy cause it kicks in & i kind of SHOOT off  ____________________ GSXR750
| LUXY DJ |
 Posted: 03:26 - 16 Oct 2005 Post subject: |
so any 1 got any more suggestions on what it could be? ____________________ GSXR750
| arsehole |
 arsehole L Plate Warrior
| BigChris |
 BigChris Spanner Monkey
 Posted: 11:28 - 16 Oct 2005 Post subject: |
Ok a couple of things:
Are you both using carb'ed engines? If so you'll probably find that it'll be affected a lot more by factors such as air temp, humidity, engine temp, oil temp etc. Not to mention cack in the bodies, wear and tear on the engine, jetting, balancing etc...
Not a lot we can do about any of that - but it will explain some of it. My CBR600 performs a shedload better in cold crisp dry air, than hot/humid summer air (like someone hitting the boost button).
2ndly have you tried over revving it? If you want to make a fashionable exit from some lights I may consider doing it conservatively at say 4 or 5 k, but have been known to rev up to 10k! ( you car drivers! )
When doing this its crucial to have good clutch control (so your idea of perhaps dodgy clutch plates could be a good one, but maybe not a physical problem with the clutch, just how you're using it?) Fractionally too little clutch and you're insta-wheelie-ing down the road, too much and you sound like a cunt and not going very far very fast...
The first few metres shouldnt be too slow though. When im doing my fast takeoffs it'll drag like you've described for about the first second, and then really kick in - this is where the clutch has fully bitten and its all systems go  |
| G |
 G The Voice of Reason
| LUXY DJ |
 Posted: 12:03 - 16 Oct 2005 Post subject: |
cheers for the replies but yes i have tried higher revving then letting clutch out but once it starts 2 bite then it kinda kills it so it goes striaght back to it bogging. but how much i've revved it on the lights before i try & take off with decent enough acceleration is FAR too much then what i should have to be doing
it did backfire few days ago aswell MASSIVE BANG!
also im not sure if it is the pipe whats been put on cause when i got it with the pipe already on i dont remember it being like this  ____________________ GSXR750
| LUXY DJ |
 Posted: 20:20 - 16 Oct 2005 Post subject: |
ok cheers mate will try that soon-ish ____________________ GSXR750
The last post was made 20 years, 327 days ago. Instead of replying here, would creating a new thread be more useful? |
