1st gear bogging problem...
 Topic moved: from General Bike Chat to The Workshop by Kickstart (15 Oct 2005 - 21:13)
LUXY DJ
PostPosted: 21:51 - 15 Oct 2005    Post subject: 1st gear bogging problem... Reply with quote
right i dont know what it can be but basically in 1st gear when pulling away its PROPER slow & boggy then @ about 5-10mph it then kicks in & its fine thro all the gears but this is a C**T cause when lights change & im still kinda sitting there & even cars are pulling away better then me I KNOW THERES A PROBLEM so .....any ideas peeps? Confused man who dont alot of my setting up...1st said it might be the clutch plates but then he tried it 2day but only breifly as he was very busy & i was in & out & now reckons it deffo aint anything to do with the clutch but he did say just try cleaning the air filter out 1st (which i am now) but what other thing/s could it be?
thanks in advance Wink
GSXR750
McGee
O RLY?
PostPosted: 21:59 - 15 Oct 2005    Post subject: Reply with quote
Thats just as strange as my problem Neutral
Its pronounced Jixxer!
PostPosted: 22:12 - 15 Oct 2005    Post subject: Reply with quote
Non stock exhaust? Sounds like a flat spot just off idle, and these are often caused by mixture problems from aftermarket exhausts.
LUXY DJ
PostPosted: 22:19 - 15 Oct 2005    Post subject: Reply with quote
yea pipe aint a std 1!
so what 2 rich or 2 lean u reckon?
anymore suggestions Confused
GSXR750
PostPosted: 22:50 - 15 Oct 2005    Post subject: Reply with quote
Probably too lean, at some point.
Probably best to take it along to someone with a dyno and an exhaust gas analyser to play with the jetting and set it up for the can.
LUXY DJ
PostPosted: 22:55 - 15 Oct 2005    Post subject: Reply with quote
ok cheers but i would of thought it would have been 2 rich hence it bogging down(2 much fuel,oil) cause lean is less but a lot more dodgy Shocked (use to strip 2t's) so plug colour will still tell me wont it? same as 2t's?
GSXR750
stu_m
PostPosted: 23:47 - 15 Oct 2005    Post subject: Reply with quote
sometimes it can be that your carbs or throttle bodies need balancing
LUXY DJ
PostPosted: 00:11 - 16 Oct 2005    Post subject: Reply with quote
yea did think of that aswell but would that cause only 1st gear doing it? its quite dodgy really cause u try to go from lights & its dodgy cause cars think they should takeover me cause im not hardly moving but then its even more dodgy cause it kicks in & i kind of SHOOT off Surprised
GSXR750
LUXY DJ
PostPosted: 03:26 - 16 Oct 2005    Post subject: Reply with quote
so any 1 got any more suggestions on what it could be?
GSXR750
arsehole
PostPosted: 11:20 - 16 Oct 2005    Post subject: Reply with quote
If it helps I put an art can on my gsx400, the bike was un ridable till I hade it dyno tunned so flat of the floor you wouldnt belive
BigChris
PostPosted: 11:28 - 16 Oct 2005    Post subject: Reply with quote
Ok a couple of things:
Are you both using carb'ed engines? If so you'll probably find that it'll be affected a lot more by factors such as air temp, humidity, engine temp, oil temp etc. Not to mention cack in the bodies, wear and tear on the engine, jetting, balancing etc...
Not a lot we can do about any of that - but it will explain some of it. My CBR600 performs a shedload better in cold crisp dry air, than hot/humid summer air (like someone hitting the boost button).
2ndly have you tried over revving it? If you want to make a fashionable exit from some lights I may consider doing it conservatively at say 4 or 5 k, but have been known to rev up to 10k! ( Middle Finger you car drivers! Mr. Green )
When doing this its crucial to have good clutch control (so your idea of perhaps dodgy clutch plates could be a good one, but maybe not a physical problem with the clutch, just how you're using it?) Fractionally too little clutch and you're insta-wheelie-ing down the road, too much and you sound like a cunt and not going very far very fast...
The first few metres shouldnt be too slow though. When im doing my fast takeoffs it'll drag like you've described for about the first second, and then really kick in - this is where the clutch has fully bitten and its all systems go Smile
PostPosted: 11:33 - 16 Oct 2005    Post subject: Reply with quote
First off, have you tried slipping the clutch at higher rpm to get away?
Second, are you sure you're going to lower revs in other gears for it to happen? It might just be that you don't go that low down the rev range in normal riding, so don't notice it.
LUXY DJ
PostPosted: 12:03 - 16 Oct 2005    Post subject: Reply with quote
cheers for the replies but yes i have tried higher revving then letting clutch out but once it starts 2 bite then it kinda kills it so it goes striaght back to it bogging. but how much i've revved it on the lights before i try & take off with decent enough acceleration is FAR too much then what i should have to be doing
it did backfire few days ago aswell Confused MASSIVE BANG!
also im not sure if it is the pipe whats been put on Confused cause when i got it with the pipe already on i dont remember it being like this Confused
GSXR750
PostPosted: 19:05 - 16 Oct 2005    Post subject: Reply with quote
If carbed I would try lifting the needles one notch and see if that improves things. Hopefully this might improve things and if so will at least let you know what you need to do.
LUXY DJ
PostPosted: 20:20 - 16 Oct 2005    Post subject: Reply with quote
ok cheers mate will try that soon-ish
GSXR750
The last post was made 20 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.94 - MySQL Queries: 16 - Page Size: 90.71 Kb
