Cleaning up a recently brought 2nd hand bike
BenBray
PostPosted: 03:31 - 19 Oct 2005    Post subject: Cleaning up a recently brought 2nd hand bike Reply with quote
I'm trying to sort everything out and learn stuff myself, but I just thought I'd run things by you guys just for peace of mind:
The bike is at about 6300 miles and I'm thinking it should go in for a service. I'm not willing to spend a daft amount of money to get everything done if I might be able to have a stab at it, so I have it to this:
Clean out and lube:
Clutch lever holder
Side stand pivot and spring hook
Drive chain
Brake level holder
Throttle cable
Brake pedal pivot
Check the following:
Spark Plug
Chain and Sprockets [will probably clean them all up]
Engine Oil [Will replace anyway]
Oil Filter [Again, might as well replace]
Air filter [Will clean it out or change it depending on condition]
Drive Chain
The only thing I think I'm missing [beyond tire pressures etc which are fine anyway] is a good old valve clearance. The only real question I have is how much is all this likely to cost me, as I have no oil of any sort whatsoever? and how much for the service? I'm only looking for rough estimates, natch Smile
Cheers for any relpies, guys
Ben
Current Bike: nc30
PostPosted: 18:40 - 19 Oct 2005    Post subject: Reply with quote
You don't say what bike.
sparkplugs. £3 each
Oil, filter and air filter £24 from Hein Gericke
Workshop manual: Priceless
BenBray
PostPosted: 01:21 - 20 Oct 2005    Post subject: Reply with quote
*coughs* ... I didnt did I?
What a newb!
Suzuki Marauder [125]
Cheers stinkwheel! Thumbs Up
Current Bike: nc30
PostPosted: 02:11 - 20 Oct 2005    Post subject: Reply with quote
Oil even cheaper then. I'd just get normal engine oil from the garage. I'm fairly sure the oil filter will be a metal gauze too which will just need cleaning in a solvent (eg petrol).
Robby
Dirty Old Man
PostPosted: 11:15 - 20 Oct 2005    Post subject: Reply with quote
Pretty sure they run a normal, albeit small, disposable paper oil filter.
Sump capacity is under a litre.
Only one spark plug.
Quite a nice ride for what it is, a friend of mine used to have one. Quicker than a restricted 2 stroke 125.
The last post was made 20 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 44.45 Kb
