reving issue
mirax
PostPosted: 22:30 - 24 Oct 2005    Post subject: reving issue Reply with quote
ive got a leaking exhaust on my vfr400 would this cause reving problems or would this be more like my air filter cauing the problem?? by this i mean it seems to be breathless and not as roary as it should be with a race can
?M?gg????
PostPosted: 22:37 - 24 Oct 2005    Post subject: Reply with quote
Is it a new can?
Has the jetting/fuelling been adjusted for the can?
Bandit 600, TDM 850,Bandit 1200
One by one the penguins steal my sanity.
mirax
PostPosted: 22:46 - 24 Oct 2005    Post subject: Reply with quote
it was fine when i bought it and it has been jetted to suit , it had no air box cover which i noticed when i had it restricted so a got 1 and fitted it at the same time.then it was breathless which i put down to the restriction kit as they dont like them being fitted on them. but recently i had it de retricted and the carb had been cleaned and has been re balanced but it still seems breathless when i rev it and does flood a little.
?M?gg????
PostPosted: 22:55 - 24 Oct 2005    Post subject: Reply with quote
If I were you I'd try it without the airbox cover. If it's still the same then I'd go and get it re-tuned but if removing the cover sorts the problem then I'd be looking at changing the air filter to a hi-flow one such as K&N
pocket_Rocket
PostPosted: 23:00 - 24 Oct 2005    Post subject: Reply with quote
maby left the choke on a little boging it down a bit
mirax
could it be the exhaust leak at all tho? back pressure ect ?? does anyone know where i can buy a sheet of filter foam from or buy a k&n for an nc30 from if this is the problem
mirax
PostPosted: 23:01 - 24 Oct 2005    Post subject: Reply with quote
this problem occurs with the cloke closed
mirax
PostPosted: 21:57 - 25 Oct 2005    Post subject: Reply with quote
does anyone know if this problem could be caused by the leaky exhaust ?? Question
riichy
PostPosted: 22:00 - 25 Oct 2005    Post subject: Reply with quote
all the more reson to rev it even harder.......
ps you realy souldnt talk to yourself people will laff Wink Mr. Green
.......... PLOD ............ zx636 2004
mirax
PostPosted: 22:10 - 25 Oct 2005    Post subject: Reply with quote
lol Razz does any one have any ideas
riichy
PostPosted: 22:12 - 25 Oct 2005    Post subject: Reply with quote
sorry all out of them.........kickstart will have some good ideas i bet Thumbs Up Mr. Green
Davo
Davo To The Rescue!
PostPosted: 22:16 - 25 Oct 2005    Post subject: Reply with quote
Sounds like the mixtures slightly off. Has the bike just had a race can etc.. put on?
riichy
PostPosted: 22:19 - 25 Oct 2005    Post subject: Reply with quote
DAVO i was just about to say the same thing.......... Mr. Green Wink
mirax
PostPosted: 22:24 - 25 Oct 2005    Post subject: Reply with quote
yes it has but it was fitted when i got it and it was set up for it
Davo
Davo To The Rescue!
PostPosted: 23:09 - 25 Oct 2005    Post subject: Reply with quote
I'd try plugging the whole in the exhaust, see if that makes a difference, if not I'd suggest you get the mixture checked out, as it sounds like it could be running a bit lean (which is why the bike is running fine on the choke).
A check of the spark plugs would probably confirm this (have a look at the haynes manual there's usually a guide there for spark plug colours/diagnosis).
sickpup
Old Timer
PostPosted: 11:05 - 26 Oct 2005    Post subject: Reply with quote
Take the cover back off the airbox.
Guessing the bike is an NC30. When these are piped and carbed the airbox lid is often cut up or removed so the engine can breath better.
And fix the exhaust.
Johnny GSX-R
PostPosted: 11:15 - 26 Oct 2005    Post subject: Reply with quote
Do you have an air filter which requires a film of oil on it like the standard Kawasaki ones and the K&N type??
If so, try and get some filter oil spray and give it a coating, i had the same symptons on my ZX10 a while back.
killa
Won't Shut Up
PostPosted: 11:19 - 26 Oct 2005    Post subject: Reply with quote
I had a reving problem with my VFR.
Check:
Spark plugs
Coils and leads
Air filter is clean
Fuel diaphragm isn’t blocked
Fix exhaust leak, it can cause loss of power, but not a lot.
Shims, valves
In the end it was the fuel diaphragm for me, it had pulled some shit through from the tank.
mirax
PostPosted: 00:30 - 27 Oct 2005    Post subject: Reply with quote
right today i took the intake rubber off the airbox cover to get more air to it and it run like crap i mean major bog downs on accelation nearly died on me so i recon it actualy might be running lean rather than too rich in that case this could be due to when i has the carbs balanced after i got it de restricted
Johnny GSX-R
PostPosted: 00:41 - 27 Oct 2005    Post subject: Reply with quote
NO NO NO thats bollox...........
Check the filter is moist with oil 1st... Its cheaper to check that before anything else.
mirax
PostPosted: 00:42 - 27 Oct 2005    Post subject: Reply with quote
the filter on these bikes are paper not foam so are not oiled
Davo
Davo To The Rescue!
PostPosted: 00:50 - 27 Oct 2005    Post subject: Reply with quote
It should still be oiled to some degree, hence why most air boxes have an oil rebreather.
sickpup
Old Timer
PostPosted: 00:56 - 27 Oct 2005    Post subject: Reply with quote
Wrong.
The crankcases have a breather which vents into the airbox instead of dripping on the road.
Do not oil paper air filters.
mirax
PostPosted: 00:57 - 27 Oct 2005    Post subject: Reply with quote
theres no metion in the manual or haynes about oiling it, it says to use compressed air but checking it earlier it seemed ok
mirax
PostPosted: 00:58 - 27 Oct 2005    Post subject: Reply with quote
thought i was right about that soz davo
The last post was made 20 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.15 - MySQL Queries: 15 - Page Size: 125.5 Kb
