Vibrating severly when braking!
haGGard
PostPosted: 22:04 - 28 Oct 2005    Post subject: Vibrating severly when braking! Reply with quote
I was out riding today, and everything was normal. However, on my journey home i quickly noticed that every time i brake, the whole scooter will shake and vibrate really quite vigorously! Shocked It has never ever done this before and its definatley not normal. It happens mostly when i apply the rear brake, but also slightly when i apply the front brake. It will also do it at any speed, be it 10 mph, or 60mph Thinking
Any ideas what it could be? I can feel the shake all over the bike so i am not quite sure where it is comming from, as i can feel it below me, through the handlebars and through the brakes etc...
Any ideas what it could be? Confused
chaff mans random tingz on loot Razz
"Why dont you go and weld your face to a moving train, you sack of pus" - tobyr
"ROFL MY TOFFLE I AM TEH 1337 SPELLING MISTAKE FINDER!" - BikerBen
instigator
PostPosted: 22:15 - 28 Oct 2005    Post subject: Reply with quote
You checked your brake pads, how much wear is on them and the condition of the disks? Although if it's doing this suddenly, then I presume it's not these.
I'm thinking wheel bearings? Never had them go before though
haGGard
PostPosted: 22:24 - 28 Oct 2005    Post subject: Reply with quote
I know for a fact that my rear pads are low, but when my front pads when low last year they made a scraping sound/feel rather that a jolting vibration....
The scooter has only covered 8000km, would bearings go after this mileage?
Finglonga
PostPosted: 22:26 - 28 Oct 2005    Post subject: Reply with quote
Could be the brakes have been binding, heated the disc up and warped it. Put it on the center stand and see if both wheels spin free (you will also be able to feel if the wheel bearings are shot as the wheel will feel rough as you rotate it).
Andy Sez....
F.Y.Y.F.F.
cyberglass
PostPosted: 00:15 - 30 Oct 2005    Post subject: Reply with quote
check your front bearings (steering and wheel)
i had a speedfight 125 which the bearings where squared every time i braked the bike shook like a washing machine on spin cycle and pulled to one side
hope this helps
LUXY DJ
PostPosted: 07:20 - 30 Oct 2005    Post subject: Reply with quote
haggard also try checking your engine mounts just put it on center stand then see how much play is in the whole lump from side to side & also try holding front brake on & pushing bike back & forth to see if your steering bearings are loose
GSXR750
DannyW
PostPosted: 12:52 - 30 Oct 2005    Post subject: Reply with quote
mine did this it needed a new front shocker.
muddycoffee
PostPosted: 13:02 - 30 Oct 2005    Post subject: Reply with quote
I would agree with everyone here, but I would like to suggest you get the bike with the front wheel off the ground and check that the steering hasn't come loose, I could imagine a fault like that if a bolt around the steering bearings had come loose.
Suzuki SV650 naked Blue curvy with Givi Screen and G force can.
Robby
Dirty Old Man
PostPosted: 13:40 - 30 Oct 2005    Post subject: Reply with quote
Vibrating under braking is normally a warped disc(s). Obviously also worth going over and checking all the steering an suspension bolts are done up tight.
haGGard
PostPosted: 13:50 - 30 Oct 2005    Post subject: Reply with quote
It all happened immediatley after fitting a side stand too, though i doubt that has anything to do with it, as its just bolted onto the frame underneath... Question
When i get some free time today or tommorow, ill have a go at the things you suggested Thumbs Up Getting it booked into Aye Gee's during the week too, so they can give it a service/look over
NSR Mick
PostPosted: 15:10 - 30 Oct 2005    Post subject: Reply with quote
my money's on a warped disk
simon1221
PostPosted: 17:47 - 30 Oct 2005    Post subject: Reply with quote
And mine.
What could cause a warped disc? overheating?
The last post was made 20 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 71.44 Kb
