exhaust blowing!!!!
gsxr_Scott
PostPosted: 13:33 - 29 Oct 2005    Post subject: exhaust blowing!!!! Reply with quote
im gettin pretty fed up now
i got a new can for my bike, i attached it looks brilliant sounds nice,
but then what do you no, out comes the spray (condensation) and i see my exhaust is blowing!
i tighten the screws hard as poss, makes no diff. so ok i thought i will try some of this stuff called fire gum i think it is, surpose to seal gaskets, manifolds etc, and goes like rubber kind of thing so vibrations wont crack it, have made 2 attempts to put this on,
yet again i fire it up, and what you think happened........ thats right still blowing!!!
anyone have any suggestions of what i can do to stop this, and does it make diff to the performance most of all damage anything??
thanks scott
gsxr 600!
Mongrel
PostPosted: 13:43 - 29 Oct 2005    Post subject: Reply with quote
Where about is the blow?
If it's on the link pipes is there supposed to be a gasket between them, on the Yoshimura on my Yamaha there is and it's a Yamaha dealer part not a Yoshimura part.
How big is the gap? More than a snug fit would probably need a gasket of some sort.
gsxr_Scott
PostPosted: 13:53 - 29 Oct 2005    Post subject: Reply with quote
the gap is perhaps 1mm maybe 2
it has a gasket already on it on the exhaust not the can, but my other 2 have worked fine so i presumed this one would also as the fitting is the same etc.
gsxr 600!
Mongrel
PostPosted: 14:07 - 29 Oct 2005    Post subject: Reply with quote
Could be the gasket is damaged and needs replacing.
I'm surprised that the firegum didn't seal it if it's only a couple of mm.
Did you smear it over the gasket or just around the joint?
IME it needs to get in to the joint, also when you warm the joint up after application, you need to be careful not to over rev the bike as you'll just blow the firegum straight back out of the joint.
gsxr_Scott
PostPosted: 14:14 - 29 Oct 2005    Post subject: Reply with quote
yer i put it all over the can joint and the gasket, fired my bike up no revs just ticking over and then as the bike got warm it started spraying,
im lost on what next just frustrating me, u recommend to put loads on?
i didnt wana cus it will look messy, im gonna give it one more attempt, shud i not leave it to seal for a while? it dont say on the instructions?
gsxr 600!
Mongrel
PostPosted: 14:22 - 29 Oct 2005    Post subject: Reply with quote
No need to put loads all over the join, as you say it will look shite and not seal any better! Most of the paste needs to be where the surfaces almost touch.
Try warming the exhaust a bit first, apply the paste, leave it to harden a bit for maybe 15 mins or so then fire the bike up to fully 'fire' the firegum. Hopefully it will have set enough to stop it being blown straight back out.
You do need to heat it though to get it to fully set.
Good luck.
gsxr_Scott
PostPosted: 14:33 - 29 Oct 2005    Post subject: Reply with quote
ok i think i see the problem,
as my bike is standing it is condensated now the problem is this water is making the gum turn water based and it is just leaking, now how am i surpose to stop this anyone have any ideas, i just dont have a clue?
do you think if i left it running for about 30 mins the condensation would go?
and then i can try again??
cheers Scott
gsxr 600!
ZRX61
Victor Meldrew
PostPosted: 18:07 - 29 Oct 2005    Post subject: Reply with quote
Chav grammar?
eh? it either already is water based, or it it isn't. It doesn't "turn water based" Rolling Eyes
gsxr_Scott
PostPosted: 21:05 - 29 Oct 2005    Post subject: Reply with quote
what you on about chav grammer???
and as for the paste, it is what i say it is simple it is a hard substance and the spray from the exhaust is making it turn watery
and as for your reply as there was not a single bit of help what was actually the point in it??
gsxr 600!
Finglonga
PostPosted: 21:51 - 29 Oct 2005    Post subject: Reply with quote
The condensation is breaking down the paste, its heat that 'cures' it to seal the joint. You need to put some more in and heat the area with a heat gun or blow torch so that the paste can solidify.
Andy Sez....
F.Y.Y.F.F.
gsxr_Scott
PostPosted: 22:54 - 29 Oct 2005    Post subject: Reply with quote
thanks for your help mate
i took the can off and let it run for a few mins to heat the exhaust up, then covered it put it back together let it stand for 2 hours started it up again for 5 mins, no leaks so now i think it is cured Smile
gsxr 600!
The last post was made 20 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 68.8 Kb
