CG Fairing Project. Finished!
shammon
PostPosted: 23:14 - 22 Oct 2005    Post subject: CG Fairing Project. Finished! Reply with quote
Thought id post this if any one else has some info or advice about this idea. From my good friend Ebay managed to get a front fairing of a Kawasaki AR 125cc, Cheap as dammaged corner and some minor cracks, Otherwise screen and rest ok.
Decided to try to fit to the bike for two reasons 1. to improve how it looks its a naked bike so wont hurt to try and also to 2. stop my alarm keyfob getting a soaking! Very Happy
Any way The light front panel is exacty the same on the cg, the square headlight type. Will need some slight removal from the internal screen ledge and corders BUT looks the part. Il keep some updates of how its going as i get it done. Just thought other cg owners would be intrested...O and fitted also crash bars. Which do look ok. Thumbs Up
https://i7.photobucket.com/albums/y277/shammon/ar.jpg
mchaggis
PostPosted: 23:23 - 22 Oct 2005    Post subject: Reply with quote
This has to be good for a laugh at any rate. Very Happy Good luck. Thumbs Up
I must not be a troll...
Mmmm, Guinness
mr.z
PostPosted: 01:21 - 23 Oct 2005    Post subject: Reply with quote
Got a pic of the crashbars?
The faring should be allright to fit provided your headlight is the square type Razz Just going to be a matter of piffleing about makeing the bracket...
MAke sure to keep us posted how it goes Thumbs Up
shammon
PostPosted: 10:43 - 23 Oct 2005    Post subject: Reply with quote
https://i7.photobucket.com/albums/y277/shammon/mini-DSC04711.jpg
shammon
PostPosted: 01:14 - 30 Oct 2005    Post subject: Reply with quote
OK, Update. Fairing repaired and fixed to the front still to be primed and sprayed but fits perfect. had to remove the plastc tray insert under the fairing screen and trim about an inch of the corners to avoid it hitting the tank on full lock.
Existing brackets used to secure it to the front head light bolts with 2 home made L shaped brackets, made out of aliminum strips from B&Q £2.30. Paint is going to cost £18 cheaper from bikepaint.co.uk Others wanted £35 Shocked . Il post a pic tomorow. Wink
YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı
shammon
PostPosted: 22:41 - 30 Oct 2005    Post subject: Reply with quote
Fitted very easily does realy need painted now but does the job i think.
https://i7.photobucket.com/albums/y277/shammon/mini-FAIR.jpg
shammon
PostPosted: 11:17 - 02 Nov 2005    Post subject: Reply with quote
Well finaly got it done today enkoyed messing about with it and end result is not bad, sadly the cg is now just my work bike as time to concentrate on my Yamaha xj600 from today so il no doubt post my happenings with that also.
https://i7.photobucket.com/albums/y277/shammon/mini-cg.jpg
https://i7.photobucket.com/albums/y277/shammon/mini-cg1.jpg
veeeffarr
PostPosted: 11:27 - 02 Nov 2005    Post subject: Reply with quote
Hey mate,
Was that fairing easy to fit? That's for posting this up I've been wanting to do this for ages! What advantages does the fairing give you?
If you could give me more details I'd be chuffed! Very Happy
vlf
PostPosted: 15:24 - 02 Nov 2005    Post subject: Reply with quote
Awesome job, nice fit.
It does improve the CG's look, doesn't it?
danzai66
PostPosted: 15:30 - 02 Nov 2005    Post subject: Reply with quote
nice one.
my girlfriend leans out of the window and laughs at me as i kangaroo my cg past.
maybe a hayabusa fairing might work..
iCraig
PostPosted: 18:21 - 02 Nov 2005    Post subject: Reply with quote
Could someone please post the dimensions of the AR125 or GG125 headlight please?
shammon
PostPosted: 21:46 - 02 Nov 2005    Post subject: Reply with quote
Well it saves a bit of rain and wind i suppose, il post the dimentions tomorow. Cheers Thumbs Up
muddycoffee
PostPosted: 22:10 - 02 Nov 2005    Post subject: Reply with quote
Well done mate that looks great.
Just one thing. After riding bikes for nearly 20 years, I would advise you to take all those other keys off your bike ignition key. for 3 reasons.
1) I have had a key snap out of the lock because of the weight of the other keys when I rode over some bumps.
2) If the lock gets worn, especially if some scroat has a go at it with a screwdriver the keys can fall out without you noticing.
3) the rest of the keys bashing around might damage or scratch your clocks or something nearby that's painted.
I always keep my bike key seperate. I had 2 CG125 ignition keys snap until I learned my lesson.
Suzuki SV650 naked Blue curvy with Givi Screen and G force can.
dibbster
PostPosted: 22:32 - 02 Nov 2005    Post subject: Reply with quote
Nice job, im amazed how good it looks.
Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's Thumbs Up
www.bikepics.com/members/dibbster
shammon
PostPosted: 23:59 - 03 Nov 2005    Post subject: Reply with quote
CG Square light 18cm x 12cm
AR 125 Front Fairing 19cm x13.5 cm Wink
Gazdaman
I did a trackday!!!
PostPosted: 02:42 - 04 Nov 2005    Post subject: Reply with quote
Nice job!
If you need any XJ600 help give me a shout, I've had mine in many more pieces than I ever wanted it in!
Gaz
shammon
PostPosted: 18:46 - 04 Nov 2005    Post subject: Reply with quote
Gazdaman wrote:
Nice job!
Gaz
Thanks for the offer if im stuck i will def give you a shout. Thumbs Up
veeeffarr
PostPosted: 18:47 - 04 Nov 2005    Post subject: Reply with quote
shammon wrote:
Gazdaman wrote:
Nice job!
Gaz
Hi Shammon,
Where did you get the rack and box from? Is there anywhere online that sells them?
shammon
PostPosted: 18:50 - 04 Nov 2005    Post subject: Reply with quote
Funny you ask i have a spare box and rack in my garage! The rack has been well used and has some rust, the box is white but in still good condition locks etc was going to put it on ebay,
veeeffarr
PostPosted: 19:00 - 04 Nov 2005    Post subject: Reply with quote
Cool, i might be interested in the box if you want to sell Razz
Where are you based? Do you know where to buy a new rack online?
Cheers,
Toby
shammon
PostPosted: 19:03 - 04 Nov 2005    Post subject: Reply with quote
Here Toby link for a new one
https://www.hondaspares.com/newparts/details/default.asp?prodID=103348
I Stay in Glasgow mate and box is £15.
veeeffarr
PostPosted: 19:05 - 04 Nov 2005    Post subject: Reply with quote
Holy fuck £55 for a rack?!
The last post was made 20 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 113.54 Kb
