| 18_stuart_88 |
 18_stuart_88 World Chat Champion
 Posted: 12:48 - 30 Oct 2005 Post subject: NSR De-Restricted Now! ( Kinda ) |
Ritchie ( True Blue ) Just de-restricted my bike for me! And took the plate out the carb and drilled the exhaust plate out too!
It is a lot more responsive wen trying to boot it! But as its a import it still need the CDI unit replaced/sorted or watever!
But wen im driving noramlly away from the power-ban thing. it seems to choke at about 6 - 6.5 RPM in about 3rd - 4th - 5th gear! and if i want to hit the Power-ban thing i hav to drop a gear!
Anybody know wat could be causing this or even better how to fix it?
Stu ____________________ Make: Honda NSR 125 R Year: 2004 Colour: Black And Silver - Died on December 18th 2005, Layed to rest December 30th 2005 :(Make: Aprilia RS 125 Year: 2000 Colour: Black And Red - Derestricted Sold!
Make: Suzuki GSXR 600 SRAD Year: 1998 Colour: Red - White - Blue
Pic of My New Bike!! |
| OreoXX |
 OreoXX Nova Slayer
| 18_stuart_88 |
| Joey Bane |
 Joey Bane Borekit Bruiser
| OreoXX |
 OreoXX Nova Slayer
| 18_stuart_88 |
 Posted: 22:34 - 30 Oct 2005 Post subject: |
Right...... I'll hav a bash at that on tuesday wen im off work! I'll giv you a P.m. if i hav any troubles!
you reckon this is the problem to my flat spot?
Im just waiting on a email back from David Silver Part on geting a UK model CDI Unit!
Cheers mate
| fuzz |
 fuzz World Chat Champion
 Posted: 13:35 - 31 Oct 2005 Post subject: |
At the bike show DSS quoted me £104.75 for the CDI unit. A little more than I thought it would be. I'm currently searching elsewhere... ____________________ https://www.bikepics.com/members/fuzzbcf/
Bikes: '99 NSR125R, '00 SV650S, K1 GSX-R600, '97 CB500, K3 SV1000S, '16 VFR800 |
| OreoXX |
 OreoXX Nova Slayer
 Posted: 14:14 - 31 Oct 2005 Post subject: |
I found the CDI and the RC units on ebay for 70 euros, you guys should start monitoring ebay, someone will sell a CDI there sooner or later.
And yes stuart, I'm pretty sure this is the problem, if you have any problems, give me a PM. The jets should be about £2 each, you can order them from www.dellorto.com by mailing Matt Cooper. You will probably find the main jet at an MC store, but the power and slow jets are a little harder to get, so order them  ____________________ Honda NSR125RR '01 Fully Derestricted w/ Gianelli Exhaust and Carbon Can |
| fuzz |
 Posted: 12:55 - 01 Nov 2005 Post subject: |
I have been given new quotes for the CDI from breakers around the country. You should be able to get one from £35-£50, they seem in good supply. I have had 7 emails in one day by using https://bike-breakers.info/. It's free  ____________________ https://www.bikepics.com/members/fuzzbcf/
| 18_stuart_88 |
 Posted: 19:35 - 01 Nov 2005 Post subject: |
Thats me finished trying to fix my flat spot! I took out teh carb and cleaned it with WD - 40 and had a wee look around to see if there was anything that look any out of the ordinary! But all looked fine!
After all that i stuck it all back together and fired it up ( started first time ) Went for a wee run and its still there
So im prosuming i need new Jets! There is only two in the carb i think. So will i be able to go to Victor Devine Honda tomorrow and ask for new jets and they will be able to giv me them?
Dont think im gonna be to great at taking them out and replacing them tho, but ill giv it a bash anyhow!
Thanks for all the help guys
| OreoXX |
 OreoXX Nova Slayer
 Posted: 19:43 - 02 Nov 2005 Post subject: |
There are 3 jets that you should replace, the main jet (138), the slow jet (42) and the power jet (65). All of them are located inside the float chamber. The power jet is the smallest one, located next to one of the floats, the slow jet is a bit bigger, located around the middle, tha main jet is the biggest, located on the big bolt that you removed when you opened the float chamber.
And also, did you check the needle? Disassemble the throttle cable from the throttle slide, and you will be able to see if it is set to the right height. (Center notch if the needle has 5 notches, 2nd from the top if the needle has 4 notches) ____________________ Honda NSR125RR '01 Fully Derestricted w/ Gianelli Exhaust and Carbon Can |
| alains |
 alains World Chat Champion
| 18_stuart_88 |
 Posted: 17:13 - 03 Nov 2005 Post subject: |
Right im about to Order some new jets from that dellorto site !
Wat size do i need?
How many do i need?
And do i need any other things for them to work?
| True Blue |
 True Blue World Chat Champion
| alains |
| 18_stuart_88 |
 Posted: 18:30 - 03 Nov 2005 Post subject: |
| 18_stuart_88 |
 Posted: 18:46 - 03 Nov 2005 Post subject: |
Hi,
Just want to make sure im buying the bang on things!
Put together a wee Word document jsut to make sure! Could sombody double check for me please!
Hope you can make it out!
| T1z3R |
 T1z3R World Chat Champion
 Posted: 22:43 - 03 Nov 2005 Post subject: |
BTW Stu...Mary wants her effin screwdriver back  ____________________ duck my sick! |
| 18_stuart_88 |
 Posted: 22:59 - 03 Nov 2005 Post subject: |
I know man! Got all cought up in the moment and completly forgot to bring it back Remembered when i got home and pulled it out ma pocket!
Could you tell her im sorry and ill pop in with it tomorrow about 1.30pm on my way to Braehead please.
| T1z3R |
 Posted: 23:05 - 03 Nov 2005 Post subject: |
mate im stayin outta her way...she was in a rage shouting how she uses that effin driver every day and "he" said he would be two mintues....keep yer helmet on when you see her  ____________________ duck my sick! |
| 18_stuart_88 |
 Posted: 23:30 - 03 Nov 2005 Post subject: |
Sudden wiff of BULLSHIT in the air!!!!!!!!!
| alains |
| theshmoo |
 theshmoo Bottomless Pit
 Posted: 01:36 - 04 Nov 2005 Post subject: |
Stu tell Mary the bodge man shmoo says her screw driver sucks small goats cocks thro a big tube and shes not to bust your balls or i will come give her the beast  ____________________ CBR 1100 blackbird. |
| T1z3R |
| DimmniBurek |
 DimmniBurek Renault 5 Driver
 Posted: 10:43 - 04 Nov 2005 Post subject: |
I have ordere the jets from Matt Cooper, and they were in SLOVENIA in 3 days!  ____________________ There Is No Stronger Drug Than Reality
There Is No Engine Like TURBO Engine |
The last post was made 21 years, 19 days ago. Instead of replying here, would creating a new thread be more useful? |
