Calling all Gixxer owners
ranna
PostPosted: 08:49 - 02 Nov 2005    Post subject: Calling all Gixxer owners Reply with quote
First of all i have a Gixxer 600 k4
Now for the problem. Whenever i use the front brake i here a quite noticable knock noise and this also happens when im pushing the bike backwards out the garage and use the front brake to stop.
Now i thought maybe the head bearings were loose or gone so i took it to drayton croft in coventry (official suzuki dealer).
First I phoned the Suzuki human resources department and confirmed with them that this should not be occurring and is covered within the 2 year guarantee.
Back to drayton croft. The guy says the knocking noise is coming from the floating brake disks K4 gixxers have and that it has a little give in them which is making the knocking noise upon applying the front brake.
What i need to know is this guy chatting **** or could it just be the floating disks and nothing to worry about. This was all done a month ago, the knocking noise is now a bit more noticable.
Sorry for the huge post but replies will be much appreciated
My Two Babys- 2007 Stealth YZF-R1- 2006 K6 Suzuki GSXR750 Track Bike
https://upload2.postimage.org/679527/photo_hosting.html
https://upload8.postimage.org/764558/photo_hosting.html
MarkyPancake
PostPosted: 12:39 - 02 Nov 2005    Post subject: Reply with quote
I have heard that floating discs are renowned for knocking.
I don't have floating discs, but have a noise coming from my front brakes. It's not there when I apply the brakes, but is when I don't. Apparently it's related to the backing plates on my R1.
Funkmeister_Smith
PostPosted: 15:13 - 02 Nov 2005    Post subject: Reply with quote
My Gixxer makes a knocking noise occasionally from the front area when I use the brakes, and its an '04 too. Confused I put it in for its 4000 mile service & I thought maybe they would pick up on it then, but they didn't mention anything about it. Therefore I presume its nothing to worry about....or should I? Shocked
Yamaha TDR 125 ~ Suzuki RG 125 ~ Aprilia RS 125 ~ Suzuki GSXR 600 K4 ~ 2001 Aprilia RSV 1000R (breaking for parts. Interested??) ~ Dajiang X-Stream X-Dirt 200 (stolen) ~ Suzuki DRZ400E (Stolen) ~ CCM 604E R30....
dainesefreak
PostPosted: 15:16 - 02 Nov 2005    Post subject: Reply with quote
Could well be warped disks.
strag
PostPosted: 18:07 - 02 Nov 2005    Post subject: Reply with quote
My K41000 does it as well and afaik it is normal and as you said, floating discs. If it were warped discs you would feel a very different sensation through the front of the bike.
carbon bling
instigator
PostPosted: 18:19 - 02 Nov 2005    Post subject: Reply with quote
Floating disks. Thumbs Up Hornet does it too.
ranna
PostPosted: 20:45 - 02 Nov 2005    Post subject: Reply with quote
Very Happy Very Happy Thumbs Up Thumbs Up Cheers people, thats one thing off my mind
freestyler_onli
PostPosted: 22:04 - 02 Nov 2005    Post subject: Reply with quote
On another note, i had 2 Gixxer k4's and today wasthe first problem i ever had with one. It wouldnt start. It just whirred when i pressed the ignition swith. Then i just gave it some and it roared upto about 12000 rpm. Shocked
Pistons werent too happy i bet!
Thats the only problem i ever had with mine- i hope it will be as well.........
riichy
PostPosted: 22:13 - 02 Nov 2005    Post subject: Reply with quote
as people have said Floating disks nothing to worry about, i hope..
just ride and see when you speed up dose the knocking get faster or not......
but probably nothing to get stressed over Mr. Green
.......... PLOD ............ zx636 2004
UrbanRacer
PostPosted: 12:34 - 03 Nov 2005    Post subject: Reply with quote
I've heard the knock a few times myself, i didn't know about floating pads. thanks for clearing this up for me Thumbs Up
Phoenix
Twisted Firestarter
PostPosted: 18:56 - 03 Nov 2005    Post subject: Reply with quote
If the disc(s) were warped you'd probably feel a pulsing through the brake lever on firm braking, or a knocking (but not just a single knock).
How can you not have floating discs on an R1? All modern bikes have floating discs, it just means the disc itself is revitted to the carrier rather than part of it. You will have some freeplay in the rivets, but personally I don't think they should knock. You can check the freeplay with your hands, if the disc is noticeably loose I don't see why you can't get it replaced under warranty, or re-rivetted.
You might also want to check the brake pads, if they're worn and one of the pistons is holding back (stuck) they may rattle inside the calipers and cause a knocking noise.
bish777
PostPosted: 19:25 - 03 Nov 2005    Post subject: Reply with quote
My 1100s full floaters clunk occasionally.
GSXR1100J
McGee
O RLY?
PostPosted: 19:29 - 03 Nov 2005    Post subject: Reply with quote
Never had this problem is it something to watch out for then ??
Its pronounced Jixxer!
bish777
PostPosted: 19:35 - 03 Nov 2005    Post subject: Reply with quote
When the little round bobbins wear a bit they let the disc move slightly causing a clunk noise.
Affects alll floating discs, my FJ1200 and sundry FZRs were the same.
GSXR1100J
McGee
O RLY?
PostPosted: 19:37 - 03 Nov 2005    Post subject: Reply with quote
I was told to get them replaced (the pads) every 600 miles, is this just the dealer trying to get more money (altough i will do the work my self).
freestyler_onli
PostPosted: 22:25 - 03 Nov 2005    Post subject: Reply with quote
WHAT!!!!!!!!!
I done 3000 miles and havent had em changed once.......... Shocked
McGee
O RLY?
PostPosted: 22:35 - 03 Nov 2005    Post subject: Reply with quote
Yeah but i think the guy at the garage thinks im a newb, they were done under warentty so im not bothered.
So its not worth it is it (yes i am a newb) Confused
Chriss
PostPosted: 00:23 - 04 Nov 2005    Post subject: Reply with quote
Once had a rattling from mine (fully floating discs) and it was natural, however, it soon fixed itself.
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
california_rookie
PostPosted: 03:38 - 04 Nov 2005    Post subject: Re: Calling all Gixxer owners Reply with quote
Mine does the same, as does another fellow k4 owner I know. I've never given it a second thought.
I'd chalk it up to 'general biker psychosis', very similar to hypochondria, in my opinion.
As for the frequncy of pad changing, I've done 14.5k on mine and they've still got at least another 20k on them. Though, I'll probably change them out just for kicks sometime in the near future. Why not, right?
https://www.bikepics.com/members/californiarookie/04gsxr600/
https://www.myspace.com/spapadillion
https://steamcommunity.com/id/spapadillion
Fruit'n'nut
PostPosted: 14:26 - 05 Nov 2005    Post subject: Reply with quote
My bike's still on original pads after 13,000 miles Thumbs Up
Power Ranger Very Happy
iPlod
PostPosted: 21:39 - 05 Nov 2005    Post subject: Reply with quote
I'm saying nowt matey Wink
Aikman666
PostPosted: 22:55 - 05 Nov 2005    Post subject: Reply with quote
Could it maybe be something to do with the weather? The disks expanding and contracting due to the coldness? In which case, they might be rubbing slightly in some areas because the disks have expanded to a larger size then they were in the warmer summer months.
I could just be talking shit though Laughing
Will work for petrol
My Design Blog
bish777
PostPosted: 14:19 - 06 Nov 2005    Post subject: Reply with quote
Also, ham fisted wheelying may have damaged your head bearings. May want that looked at.
GSXR1100J
ranna
PostPosted: 09:15 - 07 Nov 2005    Post subject: Reply with quote
No its not from wheelys because i had the head bearings looked at when I went to ask them about it
Ranger05
PostPosted: 12:07 - 07 Nov 2005    Post subject: Reply with quote
My K5 600 gixxer does it too, no worries there it's just the discs
The last post was made 21 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 128.55 Kb
