 Nicole L Plate Warrior
 White Noise Mr Dudwee
 Posted: 21:27 - 02 Nov 2005 Post subject: |
does it started revving very high when you give it too much gas while moving? if so it sounds like you could be suffering from clutch slip, maybe you need to try to consider the type of oil you are using. i guess as you have just brought it you don't know what types in there though.
WN ____________________ Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight |
 DucatiEVO Could Be A Chat Bot
 Posted: 21:49 - 02 Nov 2005 Post subject: |
Gets hot as in overheats; what sort of temp does it get up to? As WN says, sounds like it probably needs a new clutch too.
 ____________________ aKa: Ducky |
 the grim reaper World Chat Champion
 Posted: 13:46 - 03 Nov 2005 Post subject: |
You can use fully synthetic in a blade without any problems, the five I've owned have all run on it without problems. Sounds to me like the clutch has been fried by too many attempted wheelies
Try an EBC clutch, cheaper than OE and supposedly good.
Cheers
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
