High revving CBR 900RR
Nicole
PostPosted: 21:03 - 02 Nov 2005    Post subject: High revving CBR 900RR Reply with quote
Hi,
I've just bought a CBR 900RR and it's started revving very high if I give it too much gas. It also seems a bit sluggish to me and gets hot very quickly. Any ideas what might be wrong?
Many thanks
Nicole
White Noise
Mr Dudwee
PostPosted: 21:27 - 02 Nov 2005    Post subject: Reply with quote
does it started revving very high when you give it too much gas while moving? if so it sounds like you could be suffering from clutch slip, maybe you need to try to consider the type of oil you are using. i guess as you have just brought it you don't know what types in there though.
WN
DucatiEVO
PostPosted: 21:49 - 02 Nov 2005    Post subject: Reply with quote
Gets hot as in overheats; what sort of temp does it get up to? As WN says, sounds like it probably needs a new clutch too.
Smile
aKa: Ducky
the grim reaper
PostPosted: 13:46 - 03 Nov 2005    Post subject: Reply with quote
You can use fully synthetic in a blade without any problems, the five I've owned have all run on it without problems. Sounds to me like the clutch has been fried by too many attempted wheelies Shocked
Try an EBC clutch, cheaper than OE and supposedly good.
Grim
Nicole
PostPosted: 14:37 - 04 Nov 2005    Post subject: Reply with quote
Thanks a lot guys - very helpful
Nicole
The last post was made 20 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 42.54 Kb
