Down Gearing the VFR?
retrofly
PostPosted: 12:53 - 12 Mar 2003    Post subject: Down Gearing the VFR? Reply with quote
hi
I wanna change it so it accelerates faster so a few questions
1.Go down one tooth on the front
2.Go down one tooth at the front and up one on the rear
3.How much top end is lost
4.Is it worth it?
5.How many teeth do both sprokets have as standard
6.Which/where should i get the new chain and sprokest from
Thanx for any replies
Luke
"The food was not undelicious"
-Homer Simpson (Exceptional beast : Underachiving Human)
www.geocities.com/retrofly
Deano
PostPosted: 13:12 - 12 Mar 2003    Post subject: Reply with quote
retro, I've asked a few of the 400 racerboys about this and the seem to find dropping a tooth from the front and the back is what they use the most on tracks, but I've spoken to people who've -1 front and +3 rear and they say the difference is big on the acceleration but you loose about 10mph at top end but in london how often do you get to top end of 6th, erm..........never! Confused
Hope that helps Very Happy
Dean Stone #777
EMRA 2012 final standings, Formula 600s 3rd, Superstock 600s 3rd.
www.triplesevenracing.co.uk: www.ljmotorcyclerepairs.co.uk www.gettaylored.co.uk BN RaceScience, Now officially run out of money to carry on racing Sad
TiN
Pocket Tin
PostPosted: 13:25 - 12 Mar 2003    Post subject: Reply with quote
The standard sprockets on the VFR is 15/40. Apparently, dropping one tooth from the front is the equivalent of adding 2 or 3 at the back. If you drop a tooth from the front, then you can probably get away with using your current chain, but if you get a bigger rear sprocket then you'll need a longer chain.
I was informed that a smaller front sprocket isn't too good for the life of your chain (again, it's just what someone has told me, I don't know from experience), so it's more advisable to get a bigger rear sprocket and a new chain.
As Dean said, acceleration will be improved but top-end will suffer (but 400s are built for top-end speed anyway, so f*ck it Very Happy), and your speedo will over-read by about 10%.
TiN
dotgems.net
PostPosted: 14:17 - 12 Mar 2003    Post subject: Reply with quote
Smaller front sprockets wear out chains mroe quickly. The smaller they are the quicker they wear. If you go down one tooth then you can probably get away with using the same chain but not certain, but go down one at the front and up one at the rear then you should be fine. However if you stick an old chain on new sprockets then they will wear out more quickly
WildGoose
White Van Man
PostPosted: 14:18 - 12 Mar 2003    Post subject: Reply with quote
are the speedo's measured from the sprocket on your 400's then?
Deano
PostPosted: 14:22 - 12 Mar 2003    Post subject: Reply with quote
I think they are! I was told if you change your gearing it affects the following, the speedo you will not be accurate you will be travelling slower than you clock indicates, you will constantly be hitting high revs without a thought which leads too more engine wear and more fuel consumption but not a massive difference though!
Dean Stone #777
WildGoose
White Van Man
PostPosted: 14:27 - 12 Mar 2003    Post subject: Reply with quote
err, your engine isnt gonna me damaged by high revs, as long as you dont exceed the red line
engines perform there best at high revs and are designed to be run as such, as long as the engine is warm, it wont do any damage
in fact it really annoys me people who dont rev there bloody bike, it seems like a waste, i was following a fazer in town and pulling away in first, he popped it into 2nd and subsequently 3rd and 4th before we even got to 25mph, and i was stilll in first, it was quite frustrating
Deano
PostPosted: 14:33 - 12 Mar 2003    Post subject: Reply with quote
@ Goose
were does the expression of "thrashing your bike" come from i've always thought that means that its causes more engine wear, I didnt say that it was going to damage your engine there is a difference in between the 2 you know..... Smile
P.S
I'm not trying to start an argument
Dean Stone #777
PostPosted: 14:51 - 12 Mar 2003    Post subject: Reply with quote
I've always taken 'thrashing your bike' to mean riding hard etc (doesn't have to involve high revs, just pushing it etc) However some (noteably 2 strokes) bikes do work better if they are revved more, because they are designed to work best like that.
If you have a digital speedo then you can get 'yellow boxes' which convert the signal to whatever you want using a set of dip switches.
craigT19
Jolly Green Giant
PostPosted: 15:19 - 12 Mar 2003    Post subject: Reply with quote
yeah when i say im going out for a thrash, i tend to mean hitting some twists going as fast as i can etc,
also G dont v4s ride like 2strokes in the way that at low revs they got no power they ned to be "wound up" to a sertain extent?
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
TiN
Pocket Tin
PostPosted: 15:26 - 12 Mar 2003    Post subject: Reply with quote
Erm, no Question ...if anything, the ZXR4 needs to be thrashed like a mutha more than the 400 V4s...the design philosophy of the V4 was to take advantage of the v-twin midrange whilst maintaining the 4-cylinder peakiness.
If you mean "400s" rather than "V4s", then yeah, they definately need to be revved more than bigger engines.
TiN
dotgems.net
craigT19
Jolly Green Giant
PostPosted: 15:28 - 12 Mar 2003    Post subject: Reply with quote
ok Wink
ive never been on a v-4 bigger than 400cc
PostPosted: 15:39 - 12 Mar 2003    Post subject: Reply with quote
Errr... AFAIK low down power (/tourque) has more to do with size per cyclinder (and bore/stroke) than the actual configuartion of the engine.
My exapmple of 2 strokes is because, AFAIK again, 2 stroke exhausts are tuned for best performance at a certain rpm range, which will obviously be high rpm on a sports bike. Obviously there are similar things on 4 strokes (thus EXUP valves etc), but not to such a great extent.
TiN
Pocket Tin
PostPosted: 15:57 - 12 Mar 2003    Post subject: Reply with quote
Yeah, but surely the configuration of the engine can determine the size of the cylinders? i.e. the design of the V-twin/4s can potentially allow each cylinder to be larger than, say, in an inline-4...?
TiN
dotgems.net
Demonic69
The Pink Rhino
PostPosted: 18:31 - 12 Mar 2003    Post subject: Reply with quote
I can't really see any bike that runs well at low revs. All sports bikes, tourers and ST's will run better around/after 7krpm. That doesn't leave you much if you think thrashing your bike is gonna damage it.
Back on a Blade. Just feels so right.
JimboJ
Manc Pikey
PostPosted: 18:35 - 12 Mar 2003    Post subject: Reply with quote
im thinking of doind this(i know another idea Rolling Eyes) but i dont use top speed at all cos its unconfortable. i want as much accel as possible . the rear is -36 and thr fron is 14 i think. also thers a flat spot at 5000 revs which since ropey highlighted it to me its pissing me off.
[00:42] <NSR-Andy> which one's the missionary position
[00:42] <NSR-Andy> i've heard it's good
[9:42pm] <Shaun> you came first mike | <Shaun> yes gav, because I really want to fuck you
Robby
Dirty Old Man
PostPosted: 18:54 - 12 Mar 2003    Post subject: Reply with quote
craig - ever head of a VFR750 or 800, or a pan european? both V4s over 400 cc.
and luke - i just went down one on the front, got a new chain too but its the same length, and going up more on the back shouldn't be a problem cos theres miles of adjustment there.
WildGoose
White Van Man
PostPosted: 20:13 - 12 Mar 2003    Post subject: Reply with quote
nah its cool dean im not starting an arguement either Smile
its just people always seem to be worried about damaging there engines, and they seem to forget that engines are dirty, noisy, in-efficient, and all they do from the time they are created is start to die, they are constantly wearing out, and i dont think the difference between high revs and low revs really makes a lot of difference to engine life
i could be way off here so Smile i'll allow keith or someone to state the facts
PostPosted: 21:35 - 12 Mar 2003    Post subject: Reply with quote
Nope, not at all. Main thing that determines torque is engine capacity and the stroke. The longer the stroke the more torque you will have. Whether it is a V4, flat 4, square 4 or in line 4 makes no difference to the stroke. As such a V4 has no advantage over an inline 4 as far as absolute power and torque go. Has packaging advantages, plus running a V engine enables you to play with the engine to get it smoother without resorting to balance shafts
craigT19
Jolly Green Giant
PostPosted: 22:18 - 12 Mar 2003    Post subject: Reply with quote
yes thank you robby im aware of that...if you read and fully understand my post you will se i said "i had never riden a v-4 bigger than 400cc" i said noughing about them not existing above 400cc Wink
Robby
Dirty Old Man
PostPosted: 23:09 - 12 Mar 2003    Post subject: Reply with quote
i thought you said you've never seen a v4 over 400cc, not ridden one...
Doddmaster
PostPosted: 08:35 - 13 Mar 2003    Post subject: Reply with quote
You forgot the best V4 ever... V-Max Very Happy
retrofly
PostPosted: 09:55 - 13 Mar 2003    Post subject: Reply with quote
hi
so how would i go about getting these chain and sprokets cause they aint standard? can i phone up places and get them to custom make me a set?
Luke
Deano
PostPosted: 11:24 - 13 Mar 2003    Post subject: Reply with quote
@ Luke
B&C Express are the UK Renthals and Arrow Distrubutors, so ring them, Im soz I've lost the link, sprockets are dead cheap something like 15 - 20 notes each Smile and you have a choice of anodised ones aswell but the chain will set you around £50 Shocked .
I think stew knows the web links so ask him..... Very Happy
Dean Stone #777
Phoenix
Twisted Firestarter
PostPosted: 15:55 - 13 Mar 2003    Post subject: Reply with quote
Goose, engines do wear more quickly at higher revs. The bikes that tend to last the longest are low revving ones, a Diversion for example has an 8,5K redline I think. One of the major reasons car engines last so much longer than bikes is because they rev so low in comparison. Thrashing in my opinion and interpreted in the context it's usually used means sustaining high revs most of the time and constantly giving it handfuls of throttle. A bike that redlines at 14K will as a rule last longer if you usually rode it around at 7K, obviously taking it higher every now and then than if you constantly kept it at 10K rpm.
The last post was made 23 years, 231 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 134.65 Kb
