| retrofly |
 retrofly World Chat Champion
 Posted: 12:53 - 12 Mar 2003 Post subject: Down Gearing the VFR? |
hi
I wanna change it so it accelerates faster so a few questions
1.Go down one tooth on the front
2.Go down one tooth at the front and up one on the rear
3.How much top end is lost
4.Is it worth it?
5.How many teeth do both sprokets have as standard
6.Which/where should i get the new chain and sprokest from
Thanx for any replies
Luke ____________________ "The food was not undelicious"
-Homer Simpson (Exceptional beast : Underachiving Human)
www.geocities.com/retrofly |
| Deano |
 Deano World Chat Champion
 Posted: 13:12 - 12 Mar 2003 Post subject: |
retro, I've asked a few of the 400 racerboys about this and the seem to find dropping a tooth from the front and the back is what they use the most on tracks, but I've spoken to people who've -1 front and +3 rear and they say the difference is big on the acceleration but you loose about 10mph at top end but in london how often do you get to top end of 6th, erm..........never!
Hope that helps  ____________________ Dean Stone #777
EMRA 2012 final standings, Formula 600s 3rd, Superstock 600s 3rd.
www.triplesevenracing.co.uk: www.ljmotorcyclerepairs.co.uk www.gettaylored.co.uk BN RaceScience, Now officially run out of money to carry on racing  |
| TiN |
 TiN Pocket Tin
 Posted: 13:25 - 12 Mar 2003 Post subject: |
The standard sprockets on the VFR is 15/40. Apparently, dropping one tooth from the front is the equivalent of adding 2 or 3 at the back. If you drop a tooth from the front, then you can probably get away with using your current chain, but if you get a bigger rear sprocket then you'll need a longer chain.
I was informed that a smaller front sprocket isn't too good for the life of your chain (again, it's just what someone has told me, I don't know from experience), so it's more advisable to get a bigger rear sprocket and a new chain.
As Dean said, acceleration will be improved but top-end will suffer (but 400s are built for top-end speed anyway, so f*ck it ), and your speedo will over-read by about 10%. ____________________ TiN
dotgems.net |
| Kickstart |
 Kickstart The Oracle
 Posted: 14:17 - 12 Mar 2003 Post subject: |
Smaller front sprockets wear out chains mroe quickly. The smaller they are the quicker they wear. If you go down one tooth then you can probably get away with using the same chain but not certain, but go down one at the front and up one at the rear then you should be fine. However if you stick an old chain on new sprockets then they will wear out more quickly
| WildGoose |
 WildGoose White Van Man
| Deano |
 Posted: 14:22 - 12 Mar 2003 Post subject: |
I think they are! I was told if you change your gearing it affects the following, the speedo you will not be accurate you will be travelling slower than you clock indicates, you will constantly be hitting high revs without a thought which leads too more engine wear and more fuel consumption but not a massive difference though! ____________________ Dean Stone #777
| WildGoose |
 Posted: 14:27 - 12 Mar 2003 Post subject: |
err, your engine isnt gonna me damaged by high revs, as long as you dont exceed the red line
engines perform there best at high revs and are designed to be run as such, as long as the engine is warm, it wont do any damage
in fact it really annoys me people who dont rev there bloody bike, it seems like a waste, i was following a fazer in town and pulling away in first, he popped it into 2nd and subsequently 3rd and 4th before we even got to 25mph, and i was stilll in first, it was quite frustrating ____________________ So in other words, he stopped you for being flagrantly in posession of a motorcycle in direct contravention of the Hippies, Darkies and People Whose Face I Don't Like The Look of (Police Powers) Act. 1976 |
| Deano |
 Posted: 14:33 - 12 Mar 2003 Post subject: |
@ Goose
were does the expression of "thrashing your bike" come from i've always thought that means that its causes more engine wear, I didnt say that it was going to damage your engine there is a difference in between the 2 you know.....
P.S
I'm not trying to start an argument ____________________ Dean Stone #777
| G |
 G The Voice of Reason
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 15:19 - 12 Mar 2003 Post subject: |
yeah when i say im going out for a thrash, i tend to mean hitting some twists going as fast as i can etc,
also G dont v4s ride like 2strokes in the way that at low revs they got no power they ned to be "wound up" to a sertain extent? ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
| TiN |
 TiN Pocket Tin
| craigT19 |
 Posted: 15:28 - 12 Mar 2003 Post subject: |
ok
ive never been on a v-4 bigger than 400cc ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
| G |
| TiN |
 TiN Pocket Tin
| Demonic69 |
 Demonic69 The Pink Rhino
| JimboJ |
 JimboJ Manc Pikey
 Posted: 18:35 - 12 Mar 2003 Post subject: |
im thinking of doind this(i know another idea ) but i dont use top speed at all cos its unconfortable. i want as much accel as possible . the rear is -36 and thr fron is 14 i think. also thers a flat spot at 5000 revs which since ropey highlighted it to me its pissing me off. ____________________ [00:42] <NSR-Andy> which one's the missionary position
[00:42] <NSR-Andy> i've heard it's good
[9:42pm] <Shaun> you came first mike | <Shaun> yes gav, because I really want to fuck you |
| Robby |
 Robby Dirty Old Man
| WildGoose |
 Posted: 20:13 - 12 Mar 2003 Post subject: |
nah its cool dean im not starting an arguement either
its just people always seem to be worried about damaging there engines, and they seem to forget that engines are dirty, noisy, in-efficient, and all they do from the time they are created is start to die, they are constantly wearing out, and i dont think the difference between high revs and low revs really makes a lot of difference to engine life
i could be way off here so i'll allow keith or someone to state the facts ____________________ So in other words, he stopped you for being flagrantly in posession of a motorcycle in direct contravention of the Hippies, Darkies and People Whose Face I Don't Like The Look of (Police Powers) Act. 1976 |
| Kickstart |
| craigT19 |
 Posted: 22:18 - 12 Mar 2003 Post subject: |
| Robby |
 Robby Dirty Old Man
| Doddmaster |
 Doddmaster World Chat Champion
| retrofly |
 Posted: 09:55 - 13 Mar 2003 Post subject: |
hi
so how would i go about getting these chain and sprokets cause they aint standard? can i phone up places and get them to custom make me a set?
| Deano |
 Posted: 11:24 - 13 Mar 2003 Post subject: |
@ Luke
B&C Express are the UK Renthals and Arrow Distrubutors, so ring them, Im soz I've lost the link, sprockets are dead cheap something like 15 - 20 notes each and you have a choice of anodised ones aswell but the chain will set you around £50 .
I think stew knows the web links so ask him.....  ____________________ Dean Stone #777
| Phoenix |
 Phoenix Twisted Firestarter
The last post was made 23 years, 232 days ago. Instead of replying here, would creating a new thread be more useful? |
