Bogging Bugs, again
Kram
PostPosted: 14:06 - 04 Nov 2005    Post subject: Bogging Bugs, again Reply with quote
well i got my carbs out and cleaned them.
and put redex in the tank.
and redex down through the air intakes (like it says on the bottle)
although it runs better Twisted Evil it still bogs down when you crack the throttle.
this makes me wonder if it's electrical.
but the battery is fully charged and is charging right.
any ideas?
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
DucatiEVO
PostPosted: 14:32 - 04 Nov 2005    Post subject: Reply with quote
Has it always bogged down when you crack the throttle; does it do it when you roll the throttle instead?
Sounds like fuelling issue?
aKa: Ducky
Kram
PostPosted: 14:43 - 04 Nov 2005    Post subject: Reply with quote
it bogs at about 6k revs (with lights on) and 8k (lights off) i took the fuel pump off and cleaned it when i did the carbs this mornin.
it might be a fueling issue, is there any way of testing the fuel pump without blasting all my petrol everywhere?
DucatiEVO
PostPosted: 14:47 - 04 Nov 2005    Post subject: Reply with quote
Not really unless you have a Haynes manual, think this give a test for the flow amount vs time etc.
Have you had it dynoed, might be your best bet? They'd spot any problems for sure.
aKa: Ducky
Kram
PostPosted: 14:48 - 04 Nov 2005    Post subject: Reply with quote
i haven't had it dyno'd and can't afford to till after my hols.
i got a haynes manual so will have a look.
cheers
The last post was made 20 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 43.92 Kb
