cramp
greatmoorred
PostPosted: 14:26 - 05 Nov 2005    Post subject: cramp Reply with quote
does anyone else get cramp in their fingers when you have been out for a long ride ? My right hand hurts for a couple of days after. I think maybe im gripping the handle too tight ? are my gloves too thick ?
matty8887
PostPosted: 14:31 - 05 Nov 2005    Post subject: Reply with quote
If your getting cramp then you are gripping too tight, if its pins and needles then your leaning on your wrists too much. I have got it in the past and still get it sometimes now.
What bike do you ride?
greatmoorred
PostPosted: 14:36 - 05 Nov 2005    Post subject: Reply with quote
just learning at the moment on a CBF 500, went down to the NEC on it on tuesday which took about 3 hours each way with all the roadworks etc and my middle finger Middle Finger on my right hand is still sore now. Bought some summer gloves at the show but had to stop near leek to change back into my thick ones due to frostbite Crying or Very sad Maybe i just need to loosen my grip a bit.
matty8887
PostPosted: 14:39 - 05 Nov 2005    Post subject: Reply with quote
Ye, try and loosen your grip, if you went 3 hours like it then im not surprised your hand is hurting.
Just loosen your grip a bit and see if that improves.
Teaman
PostPosted: 15:07 - 05 Nov 2005    Post subject: Reply with quote
I find that changing grips can help aswell, I have less aches in winter due to heated grips,, (not cos there warm but because there thicker rubber they lessen the vibration) my bike vibrates at 4500rpm at 70mph ish, calms down at 9000 but thats around 85-90 mph,
try using your legs to grip the tank and relax your arms,
also you could buy a throttle buddy thing, it works by resting your palm on it instead of gripping the throttle,
my friend has one of those cheep throttle controll things that at a flick of the thumb it will hold your throttle in what ever position, personally a mtch works just as well, lodge it between the grip and the switch unit, this way you can move your right hand to get rid of any aches
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
The last post was made 20 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 43.59 Kb
