Electric problem
superstacker
PostPosted: 11:14 - 06 Nov 2005    Post subject: Electric problem Reply with quote
This is kinda linked in with my white smoke thread,
my battery is knackered, i am aware of this, however when i connect it up to the jump leads, the neutral light wont go on and the electric starter wont work.
Its not a blown fuse as far as i can tell, is it just because of the dead battery or do i have yet more complicated problems with my once flawless bike?
vfr400 nc24
Guest
PostPosted: 15:11 - 06 Nov 2005    Post subject: Reply with quote
Everything should work ok when you hook up the other battery - do you have lights?
Dunno about Hondas, but Suzukis have a main 30A fuse, usually located on or near the starter solenoid. If that's gone then it'll be totally dead however good the battery is.
Robby
Dirty Old Man
PostPosted: 16:39 - 06 Nov 2005    Post subject: Reply with quote
Well get a good battery on there and see.
freestyler_onli
PostPosted: 23:56 - 06 Nov 2005    Post subject: Reply with quote
Speaking of electrics, i was on a motorway slip road and as i went to change gear i got a short sharp shock in my left hand from the bike.
As all the electric stuff is on the other side-any ideas????
superstacker
PostPosted: 20:46 - 08 Nov 2005    Post subject: Reply with quote
New battery fitted, neutral light comes on when it wants to.... will check connections!
superstacker
PostPosted: 20:47 - 08 Nov 2005    Post subject: Reply with quote
doggone
PostPosted: 23:58 - 09 Nov 2005    Post subject: Reply with quote
If nothing works most likely your earth cable is corroded where it links onto the bike.
That is the negative lead, which runs directly to the bike frame.
joshua1 This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
The last post was made 21 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 53.25 Kb
