Fuel Leek
jay12329
Dr. Evil
PostPosted: 18:02 - 06 Nov 2005    Post subject: Fuel Leek Reply with quote
I got het CBR started today to find a fuel leek. It seams to be comeing from between carb 2 and the engine block. What might be causing it and it there anything quick i can try?
I spent 2 hours atempting to get the carbs off but i couldnt get them to budge. Brick Wall
Thanks
J
PostPosted: 18:17 - 06 Nov 2005    Post subject: Reply with quote
Well, sounds like your vacuum fuel tap is not working as it should. No fuel should be able to run out of the carbs when the engine is off.
It is not uncommon for there to be a leaky needle valve on modern Japanese bikes but you don't notice it because of the vacuum fuel tap. When the tap fails, you suddenly get fuel pishing out.
I would switch the fuel off when parked for the time being. If fuel is overflowing through the needle valve, it can run down into the engine and fill up your sump with petrol. Which is obviously not a good thing.
jay12329
Dr. Evil
PostPosted: 18:22 - 06 Nov 2005    Post subject: Reply with quote
Mines a '87 crb 6 does that count as modern?
Its not pissing out its more of a dribble, which slows to a drip and eventually stops when the engine is turned off (i assume this is due to there being no more fuel in the carbs rarther than anything.)
The bike seams to run ok, revs reasonably constant at 1500rpm idel with an ocasional stutter and it gets going again.
Thanks
J
PostPosted: 19:22 - 06 Nov 2005    Post subject: Reply with quote
I suppose they are getting on now Laughing but yes, I would include that in ther 'modern' category.
Might just be a sticky float. Any way of giving the carb a few sharp taps to free it off? (I usually use a nylon hammer for this)
jay12329
Dr. Evil
PostPosted: 21:17 - 06 Nov 2005    Post subject: Reply with quote
well they have had a few belts and a prod and a shake and a pull. might jsut tighten everything up and try it again. if not ill have to give another go at gettign them off so i can look at them properly.
J
finpos
PostPosted: 22:28 - 06 Nov 2005    Post subject: Reply with quote
if my (hazy) memory serves me correctly, your old cbr might have a fuel pump feeding the carbs, which would explain it leaking until pump pressure has reduced after the engine is turned off. Dodgy float/needle valve almost certainly the root of the problem.
One thing for sure - If you are going to take the carbs off, buy new intake rubbers before you start. The carbs will NOT go back on with the old stiff ones.
fin.
jay12329
Dr. Evil
PostPosted: 22:55 - 06 Nov 2005    Post subject: Reply with quote
Thats ok, they wont come off witht eh old stiff ones! Laughing
J
garry
PostPosted: 00:21 - 07 Nov 2005    Post subject: hi jay Reply with quote
if you,ve identified the leak between the block and NO2 carb .... they aint no quick fix ,,
its carbs off ............ and to infinity and beyond !!!!!!!!!!!!
prob jus a stuck float ..... but the lots gotta come off
good luck jay Smile
so long so long so long and thanks for all the fish !
clemsta
PostPosted: 00:24 - 18 Nov 2005    Post subject: Reply with quote
Yeah i agree on stuck float, the float could possibly be puncured and lost its buoncy, this would make the needle valve open more, then when the bike is switched off, fuel would drip out the overflow. Thats what happened on my NS125R
Hope you get it sorted without too much hassle.
Adam
SOMEONE CALL THE DOCTOR! I've got 2 stroke fever!!!
OGRI - Stuff everything, i've always got my bike!
DAS Passed - 7/6/06
owdamer
PostPosted: 20:40 - 19 Nov 2005    Post subject: Reply with quote
A fuel leek??
https://www.auswelshmalechoir.org.au/IMAGES/leek.jpg
Flip
PostPosted: 03:19 - 20 Nov 2005    Post subject: Reply with quote
Owdamer wrote:
One of those in your tank is a nightmare.
Beat me to it you f*cker.
The last post was made 20 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 69.93 Kb
