Bolt roundedd off
dransy
PostPosted: 17:26 - 06 Nov 2005    Post subject: Bolt roundedd off Reply with quote
Hi all 2 bolts holding my caliper onto my bike , anyway one came of with a lot of struggle and the other one just rounded off, i got mole grips to it , but still no look its chewed the teeth on my mole grips.
Is my only option now to drill it out?
if so , how do i do it just i drill straight in the centre of the bolt or at angles etc?
cheers
marc
Visitor Q
$25 whore
PostPosted: 17:29 - 06 Nov 2005    Post subject: Reply with quote
easiest way ive heard is to dremel a slit into itwide enough for a screw driver.
tatters
Exxon Valdez
PostPosted: 17:41 - 06 Nov 2005    Post subject: Reply with quote
you could try tapping it around with a cold chizel and a club hammer, but be very carful beacause fork legs and calipers are easy to damage.
True Blue
PostPosted: 17:49 - 06 Nov 2005    Post subject: Reply with quote
The best way to get it out is to drill the head off by drilling the centre of the bolt with a drill bit which is the same size as the bolt. ie if it's a 6mm bolt then use a 6mm bit. Once the head is drilled off drill right down the centre with the smallest drill bit you can. Keep drilling through it with slightly bigger drill bits each time untill you have almost drilled it out to the size of the bolt. If it's a 6mm bolt tap into it with a 6mm tap. This should grab what's left and break it up without damaging the thread.
Works for me anyway Thumbs Up Wink
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
PostPosted: 17:51 - 06 Nov 2005    Post subject: Reply with quote
If you drill the head off the bolt, the calliper should come off (with the stump still in the calliper). It should unscrew fairly easily once the tension is off it.
Good luck getting new bolts, they are usually fine pitch metric. Evil or Very Mad
Teaman
PostPosted: 18:30 - 06 Nov 2005    Post subject: Reply with quote
id just get a bigger nut and weld it to the knakered one, then crank it off
Your nutt that is
erm ahhhh oooh
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
Lone-Wolf
PostPosted: 19:36 - 06 Nov 2005    Post subject: Re: Bolt roundedd off Reply with quote
Wotcha.
In a nutshell - no.
Try and find a "super-wrench". I bought a set of these at the bike show a few years back and they are invaluable for getting rounded bolts out.
Super Wrench
Very useful things to have hanging in the garage.
Cheers.
L.W. - www.moonshiners.org.uk
Mongrel
PostPosted: 20:25 - 06 Nov 2005    Post subject: Reply with quote
As a last resort you could trying hammering a socket of a size slightly smaller than the bolt on to the remnants, then try and turn it out with a socket wrench in the socket.
Take care not to damage the forks (brace them if possible).
EDBANGER
PostPosted: 22:41 - 06 Nov 2005    Post subject: Reply with quote
Experience has taught me that a sharp punch or chiesal tapped gently with a hammer gets most turning and out! Much better to try that first before drilling!
If you can't spot the sucker in your first half hour at the table, you are the sucker.
fuzz
PostPosted: 23:00 - 06 Nov 2005    Post subject: Reply with quote
Try this page for other useful ways
https://www.dansmc.com/stripbolt.htm
sanchezz_182
PostPosted: 23:51 - 06 Nov 2005    Post subject: Reply with quote
mongrel - thats why i do,, works most of the time...
if not get angle grinder out n just grind away the bits at the side,, ie forks an caliper,,, the bolt shoudl fall away with eas...
no sig, thats gay!!
The last post was made 21 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 70.53 Kb
