No Spark !!!
tony1967
PostPosted: 23:47 - 06 Nov 2005    Post subject: No Spark !!! Reply with quote
Hi, I have a 1995 rs125 it was running fine until a couple of days ago then it stoped no spark at plug have checked wiring and its ok. Where do i go from here?
garry
PostPosted: 23:54 - 06 Nov 2005    Post subject: wiring Reply with quote
start to work back mate
check main fuse/ plug/ht lead/ coil...
think you,ll find its one of those ..
good luck
so long so long so long and thanks for all the fish !
Biker-Kev
PostPosted: 16:00 - 07 Nov 2005    Post subject: Reply with quote
Firstly - Make sure the engine kill switch has not been pressed
Secondly - Change your spark plug
Thirdly - Check your HT lead.
Fourthly - Check your wiring around ignition and HT lead.
If noneof this works, then I have no idea what it wrong with it.
Zhongyu ZY50, Aprilia SR50, Motorhispania RX50, Aprilia RS125, Honda VFR400 nc24 and my corsa
https://www.bikepics.com/members/bikerkev/
Theory: Passed 8/11/2005 Practical: Passed 13/12/2005 Proud holder of A2 license
fuzz
PostPosted: 16:22 - 07 Nov 2005    Post subject: Reply with quote
Get your manual out and make sure all of the main components are reading the right impedance value:
Stator coil, pulse generator coil, primary and secondary ignition coil.
If one is out of range, replace it and test again. If all is OK, it doesn't necessarily mean that the parts are fine, as I am finding out at the moment.
I have the exact same problem. All compoenets tested OK so I got a different CDI but still no spark Mad
tony1967
PostPosted: 20:56 - 08 Nov 2005    Post subject: Reply with quote
Thanks, i have no CDI on my bike and my coil has four wires(red,black,orange and green) my mates is 1996 and he has only two wires but he has a CDI i think i will have to get a manual any ideas were to get one??
Have checked the HT,Main fuse and the plug is new battery fully charged....
Biker-Kev
PostPosted: 23:06 - 08 Nov 2005    Post subject: Reply with quote
Though bikes needed a CDI? If they do, then that will be your problem, but maybe they dont need one. PM kickstart and ask him, because he knows everything there is to know about bikes.
Kev
fuzz
PostPosted: 00:31 - 09 Nov 2005    Post subject: Reply with quote
Not all bikes have CDIs. Some bikes use points ignition timing, either magnetic or battery and coil.
dransy
PostPosted: 00:55 - 09 Nov 2005    Post subject: Reply with quote
This happened to my 1999 rs was at it for like a whole weekend in the end it was a bad earth on my coil just have a look around your coil
tony1967
PostPosted: 22:41 - 14 Nov 2005    Post subject: Reply with quote
my coil has four wires going into it my mate has a 96 his only has two do you know which is the earth? also where i can get it checked
tony1967
nora2004
PostPosted: 23:47 - 14 Nov 2005    Post subject: Reply with quote
Of course you have a cdi! lol
On the rotax 123 engine the coil and cdi is one unit, if I remeber rightly its usually a dark blue colour under your tank!
zorgman
PostPosted: 22:07 - 15 Nov 2005    Post subject: Reply with quote
thats a ducati make cdi your using
white is earth
i think green is ac volts
red is pulse
and the other is pulse
i cant get at my sheet at mo for specs but you need to do a test on the stator coils do u no how to use a multimeteras the readings will tell me what is going on
tony1967
PostPosted: 22:55 - 16 Nov 2005    Post subject: Reply with quote
the colour of the wires are red, black, green and orange i have a multimeter and can check for dc volts and resistance thats about all if that will help.
Thanks for the reply
and yes it is dark blue
The last post was made 20 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 72.96 Kb
