Chain Noise
kb-zxr
PostPosted: 09:45 - 07 Nov 2005    Post subject: Chain Noise Reply with quote
I noticed the other day that under heavy braking (almost emengency brake, really hard), the chain made a clicking sound. Well I think its the chain, came from the back wheel area. I do use the rear brake if this is any help. Is this normal under heavy braking?
Thanks
killa
Won't Shut Up
PostPosted: 09:59 - 07 Nov 2005    Post subject: Reply with quote
Winter is a bitch for chains, might need a new one, could be to tight or too loose.
Or maybe tight spotting, needs a good coating in lube.
dainesefreak
PostPosted: 10:03 - 07 Nov 2005    Post subject: Reply with quote
Have you checked that the rear wheel locking nut is at the correct torque setting? (Tight enough)
kb-zxr
PostPosted: 10:32 - 07 Nov 2005    Post subject: Reply with quote
Chain is fairly new (month old), and is only used in nice weather. I will give it a good lubing and check that nut. Might also check the sprocket nuts and allignment.
Thanks Thumbs Up
doggone
PostPosted: 17:43 - 07 Nov 2005    Post subject: Reply with quote
Have a look at the stay going to the brake caliper too.
kb-zxr
PostPosted: 20:00 - 07 Nov 2005    Post subject: Reply with quote
Thats a good point mate I'll check that.
Thanks
owdamer
PostPosted: 20:18 - 07 Nov 2005    Post subject: Reply with quote
Did you have the clutch pulled in?? sounds to me as if you didn't & the bike was on the verge of stalling causing the chain to flap about a bit.
The last post was made 21 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 50.12 Kb
