how do moters determine if your brakes are good enough?
gimpy limp
PostPosted: 18:13 - 08 Nov 2005    Post subject: how do moters determine if your brakes are good enough? Reply with quote
I like to have squishy brakes but does it have to be rock hard for the mot? how do they test the pressure? can I test them myself somehow before taking it? If it wont pass as they are ill just have to let some more air out bleeding them again. Your lights dont have to be aligned or anything silly like that like on a car does it? can I do that myself?
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
The Old Geeza
Back in my day...
PostPosted: 18:16 - 08 Nov 2005    Post subject: Re: how do moters determine if your brakes are good enough? Reply with quote
gimpy limp wrote:
...Your lights dont have to be aligned or anything silly like that like on a car does it?...
Yes, they do. And car brakes have to meet the MOT requirements too.
The same applies to bikes Thumbs Up
Horse Power was safer when the Horses had it!
gimpy limp
PostPosted: 18:18 - 08 Nov 2005    Post subject: Reply with quote
I thought with cars if the brakes work it passes but ive heard people with bikes saying that they've failed on the brakes working but not applying enough force to the disc. I like it like that though, if I want to stop really quick to avoid a child running out i'll jump off the bike waving my hands in the air screaming in hysterics.
doggone
PostPosted: 18:22 - 08 Nov 2005    Post subject: Reply with quote
They need to lock the wheel so that when applied you can push the bike and the wheel skids.
If you have to pull the lever almost to the bars to do this it won't do.
It should feel reasonably firm, have a look at the pads, if they're well worn will need changing - not too expensive for most bikes.
PostPosted: 18:24 - 08 Nov 2005    Post subject: Reply with quote
They test them on a rolling road brake tester. It does some sort of calculation using the weight pushing down on the road and the stopping force.
The test is wierd though, patently useless brakes can test up very well and apparently good ones can fail.
I would suggest that if your brakes are not as good as they should be, it would be a good idea to fix them eh?
I have bikes with crap brakes, but they work as well as they were designed to.
They are supposed to test the headlamp alignment. In my experience, they don't usually bother because they know you'll just adjust it back to how you had it before.
PostPosted: 18:27 - 08 Nov 2005    Post subject: Reply with quote
They don't do this any more. They use a rolling road to measure braking force and have to enter the results in the new computerised MOT system. This is just as well because my older bikes with twin leading drums can be pushed along with the brake held on but dynamically test up very well. The wheel has to be turning for them to function properly.
mchaggis
PostPosted: 19:42 - 08 Nov 2005    Post subject: Reply with quote
I acquired this from the MOT UK website:
https://www.motuk.co.uk/motor_cycle_testing.htm
I must not be a troll...
Mmmm, Guinness
The Old Geeza
Back in my day...
PostPosted: 19:54 - 08 Nov 2005    Post subject: Reply with quote
gimpy limp wrote:
... if I want to stop really quick to avoid a child running out i'll jump off the bike waving my hands in the air screaming in hysterics.
Hmmm...
Never seen that as one of the 'advisories' for the brake test on the MOT form Shocked Laughing
It's a good 'un, though Thumbs Up
Teaman
PostPosted: 19:58 - 08 Nov 2005    Post subject: Reply with quote
you have a cx mate, they dont have brakes,,
braided hoses help a bit
its cos you have single piston brakes on a small smooth disk,
also your headlight is crap,
they will check everything at the mot station and avise you what to do anyway
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
mr.z
PostPosted: 20:43 - 08 Nov 2005    Post subject: Reply with quote
Braided hoses, new fluid and new pads, they are "ok" (amazeing after a year on a cg)
Bear in mind th e hoses are probably original 20year olduns, so they will distort a fair bit! been promiseing my bike some for some time!)
gimpy limp
PostPosted: 20:52 - 08 Nov 2005    Post subject: Reply with quote
I've got braided hoses, new oil and new pads. I just left some air in the system so it's how I like it, i'll have to do it propperly for the mot by the sounds of it. I have 2 fog lamps either side of the bike to help the headlight out abit.
Cillit-BANG
PostPosted: 21:04 - 08 Nov 2005    Post subject: Reply with quote
ARE YOU NUTS?
The MOT is set at a standard that requires your brakes to work, your saying you prefer your brakes not to work?
I've heard it all now !!
gimpy limp
PostPosted: 21:13 - 08 Nov 2005    Post subject: Reply with quote
where did i say they dont work? just abit spongier than what most people would be used to requiring pulling in abit more but they work fine like said. They will be too close to the handlebar (cheers doggone) when the lever is pulled in so will need changing.
Cillit-BANG
PostPosted: 21:15 - 08 Nov 2005    Post subject: Reply with quote
I am ignoring this thread. It is making my head hurt.
There will be tears......
The last post was made 21 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 84.36 Kb
