| mirax |
 mirax Scooby Slapper
| Claud 14.7 to 1 |
 Claud 14.7 to 1 World Chat Champion
| JamesVFR |
 JamesVFR Borekit Bruiser
| mirax |
| Bezzer |
 Bezzer World Chat Champion
 Posted: 20:57 - 10 Nov 2005 Post subject: |
You've got a Honda dude, it's bound to be the reg/rec.
If you're noticing the brightness as you say don't use it until you've checked the output voltage as you could end up blowing a lot more expensive things than a bulb.
For a quick check put a multimeter across the battery terminals, start it up and rev it to around 5,00rpm, meter should climb to a max of around 15-15.5 volts , if its over then the reg/rec has fried in the open position letting excess voltage through. Start with that and at least you know if it's safe or unsafe to to run it. ____________________ I used to be indecisive but now I'm not quite so sure. |
| Phoenix |
 Phoenix Twisted Firestarter
| Bezzer |
| Phoenix |
The last post was made 20 years, 343 days ago. Instead of replying here, would creating a new thread be more useful? |
