reg/rec question
mirax
PostPosted: 18:36 - 10 Nov 2005    Post subject: reg/rec question Reply with quote
i think my reg/rec is on its way out as my lights go really bright for a second then go back to normal and 1 of the headlights have blown. is there any other running issues a knackered reg/rec could cause i.e the bike running rough etc???
Claud 14.7 to 1
PostPosted: 19:29 - 10 Nov 2005    Post subject: Reply with quote
Yea, if can run rough when the battery doens't have enough charge to provide a strong spark. Mine ran badly at low revs only but seemed to be ok higher up.
It can even cut out if the battery gets too low. By that time however, it wouldn't even have enough charge to even turn over the engine after. In that case the battery would be drainnig whilst you are riding.
JamesVFR This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
mirax
PostPosted: 20:10 - 10 Nov 2005    Post subject: Reply with quote
where could i find that ?
Bezzer
PostPosted: 20:57 - 10 Nov 2005    Post subject: Reply with quote
You've got a Honda dude, it's bound to be the reg/rec. Laughing
If you're noticing the brightness as you say don't use it until you've checked the output voltage as you could end up blowing a lot more expensive things than a bulb.
For a quick check put a multimeter across the battery terminals, start it up and rev it to around 5,00rpm, meter should climb to a max of around 15-15.5 volts , if its over then the reg/rec has fried in the open position letting excess voltage through. Start with that and at least you know if it's safe or unsafe to to run it.
Phoenix
Twisted Firestarter
PostPosted: 00:33 - 11 Nov 2005    Post subject: Reply with quote
Generally if the headlights dim when you rev it (rather than brighten) then it's had it. All older VFRs and CBRs have bad regulators that don't usually last over 30,000miles.
Bezzer
PostPosted: 01:56 - 11 Nov 2005    Post subject: Reply with quote
Still the same with the newer bikes, Honda can't get the right supplier for shit, must be some heavy kickbacks involved for all the years it's been going on, even Suzuki eventually made changes after the crap ones they used on their older bikes.
Phoenix
Twisted Firestarter
PostPosted: 19:55 - 11 Nov 2005    Post subject: Reply with quote
Best bet is just to spend £60 on a new aftermarket heavy duty one with a good heatsink and fit a fan if you really want. You'll never have to replace it again.
The last post was made 20 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 55.56 Kb
