electrical problem with 50cc aerox scooter
davethenorman
PostPosted: 07:33 - 10 Nov 2005    Post subject: electrical problem with 50cc aerox scooter Reply with quote
My aerox 50cc water cooled scooter has a problem. When the lights are on, the intermitantley dim and then burn brightly , as the engine is revved, they brighten, then dim to nothing, for a few seconds, then pick up again etc. Also the back light bulb keeps blowing, and not just failing, but it makes a hole in the side of the glass, when it goes!
Can the magneto be playing up? could this be putting out an irregular voltage? Otherwise is there a voltage regulator on the bike somewhere, as it seems that the lights are not getting a steady voltage.
I have checked as best I can and there doesn't appear to be any loose wires in the headlight unit.
Any ideas anyone?
Dave The Norman
firefox
PostPosted: 20:00 - 11 Nov 2005    Post subject: Reply with quote
they do have a voltage regulator on them usally a silver square shape i believe on gopeds like yours they are under the seat like under the storage.
Mr noOdles
PostPosted: 15:56 - 12 Nov 2005    Post subject: Reply with quote
davethenorman
moped lights are suppose to dim out when there not being revved then it brighten up again when you rev it
you could have a weak battery and will need replacing
OR
could be a damage voltage regulator, but they ae rock solid and are not prone to break down
Confused
Project Typhoon (Abandoned)
Project MegaTyphoon (Under Planning) Arrow www.MyMoped.tk Update will regularly take place on a weekly bases.
davethenorman
PostPosted: 19:56 - 12 Nov 2005    Post subject: Reply with quote
Thanks, but the lights dim and brighten when the revs are held at say 3000, also the back bulb has blown 3 times, each time the glas has a hole blown in it, as if the volts are to high/
Any more ideas
Dave The Norman
zorgman
PostPosted: 20:05 - 12 Nov 2005    Post subject: Reply with quote
nowt to do with the regulator that is only for charging the batt. av a look under front panel and look for 1 or 2 oblong white ceramic tubes these are ballest resistors and that is where you problem lies. make sure that the connections are good as they get corrosion on them causing the fault
davethenorman
PostPosted: 15:21 - 13 Nov 2005    Post subject: Reply with quote
I've look under the front panel but couldn't see anything. I also look under the speedo and between the handel bars and couldn't find anything. Next to the seat there is a box with wires going to it but I think it's the CDi box. There arer also 2 other bowes near the battery. Do you know what these are?
Dave The Norman
zorgman
PostPosted: 16:36 - 13 Nov 2005    Post subject: Reply with quote
what you are looking for will be about 2" long and about 1/4-1/2" wide rectangular either metel cased or white ceramic these are the balast resistors that dump the excess voltage so 1 of them is either u/s or wiring slack. they are always bolted to the frame to keep them cool.
davethenorman
PostPosted: 07:15 - 25 Nov 2005    Post subject: Reply with quote
It appears that the nitro I have, has a combined voltage reg and ballast res, being a small metasl box with fins on it for cooling. I have changed it for a second hand item, and now the lights will run at half revs for two or three minutes, then I lose all lights including the dash lights. If I then turn the bike off, and restart the lights come on again!
Could the seciond hand part be at fault, or do I now have a seperate problem?
Any thoughts?
Thanks
Dave The Norman
The last post was made 20 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 56.6 Kb
