Optimax
kb-zxr
PostPosted: 18:05 - 13 Nov 2005    Post subject: Optimax Reply with quote
I see all these "super" petrols at the station, and wondered if they really make as much difference as they say.
Did it make it better or worse, and does the fact that its 2 or 4 stroke make much difference to the level in gain/drop in performance?
Is it worth it? I never used it, can I afford that extra quid Razz
Chriss
PostPosted: 18:07 - 13 Nov 2005    Post subject: Reply with quote
They have addatives in, like detergant, to help clean your engine. Some also have a higher octane rating.
Are they worth it? Depends how high performance your bike is. I'm not talking basic power commender, can and K&N. Wink
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
Quote Me Happy
Never noticed any peformance gain, although the bike may have gone a little further for the same amount of fuel. Not worth it IMO.
colin1
Captain Safety
PostPosted: 18:09 - 13 Nov 2005    Post subject: Reply with quote
5th gear are gonna do an item on next weeks show about premium petrols and if any of them are any good (or did i miss it and it was last week ?)
Chriss
PostPosted: 18:11 - 13 Nov 2005    Post subject: Reply with quote
Not all the benefits are designed to be short term. Supposed to help your engine go longer and be more effecient long term. (I used to work for Texaco, and asked a engineer about it. Smile )
craigs23
Mr Muscle
I occasionally use it when I'm feeling generous. It doesn't seem to give any more power, but the throttle reponse seems a bit crisper.
Type_Mo
PostPosted: 18:14 - 13 Nov 2005    Post subject: Reply with quote
I put a full tank in typhoon oncve becuase there were no other petrol station around, and the bike was slow and sluggish with that in there. (typhoons are designed to run on no-0more then 98ron, evan with a 70 bore)
But on bigger bikes they should do something good Laughing
instigator
PostPosted: 18:21 - 13 Nov 2005    Post subject: Reply with quote
On the hornet, I got 98 miles to a tank as standard, one time putting that stuff in, I switched to reserve at 120 miles.
I went 1/5 further!
Not that I buy it anyway, that was a one off. Tank range on a hornet is a big problem so I had to do something!
california_rookie
PostPosted: 18:23 - 13 Nov 2005    Post subject: Reply with quote
A higher detergent and/or octane rating is not necessarily a promise of a boost in power. The purpose of the additives, such as Chevron's Techron and Shell's Propower are obviously to keep your engine running clean by cutting down on sludge build-up. The higher octane level usually serves only to reduce the possibility of 'detonation', which leads to knock, which is bad. The only gain you might expect from so-called premium fuels might be a smoother powerband due to a lack of the knock sensor (should your bike even have one) cutting in and retarding timing when it senses detonation, often felt as a low spot in the powerband.
https://www.bikepics.com/members/californiarookie/04gsxr600/
https://www.myspace.com/spapadillion
https://steamcommunity.com/id/spapadillion
Robby
Dirty Old Man
PostPosted: 19:16 - 13 Nov 2005    Post subject: Reply with quote
They have a higher octane rating (97 RON instead of 95) and some more detergent.
The octane rating won't matter unless your engine is set up for it, which means either significantly higher compression ration or forced induction.
The detergent will make a difference over a long period of time. A single tank now and then will not clean everything out. Using the expensive stuff for a few months would.
Personally I use it in my car, because my car specifies 98 octane. I often chuck it in the bike too, on based on the idea that the bike is used very infrequently and if I'm starting with 97 octane it will take longer to degrade to 91 (most jap bikes need 91 or higher) than something starting at 95.
base
PostPosted: 21:23 - 13 Nov 2005    Post subject: Reply with quote
i run my zxr750h2 on super unleaded, it seems to tick over better and has less of a flat spot, but it makes no difference to my fzr1000 exup incidently the exup is basically standard where as the zxr is modified
romperstomper...
PostPosted: 21:59 - 13 Nov 2005    Post subject: Reply with quote
they did a feature in ride mag
average performance gain 1-2%
decreased fuel consumation and lower emissions
I use it all the time for the extra cost, less than £1 extra for a fill you may aswell
Yeah I know !
LUXY DJ
PostPosted: 22:18 - 13 Nov 2005    Post subject: Reply with quote
anyone know what the difference is out of bp's super & shell's optimax?
GSXR750
Chriss
PostPosted: 22:27 - 13 Nov 2005    Post subject: Reply with quote
Currently, 0.5p. Location depending.
HTH
kawakid
PostPosted: 23:03 - 13 Nov 2005    Post subject: Reply with quote
Felt funny in the ER5, sort of nocking noise, perhaps it was me.
But soon got rid of the stuff and never put it back in.
Anyone tried LRP??????
I've a twin and a 4.
Chriss
PostPosted: 23:04 - 13 Nov 2005    Post subject: Reply with quote
LRP is for 4* engines mate. Laughing
Bandito
PostPosted: 00:19 - 14 Nov 2005    Post subject: Reply with quote
I use BP's version... Ultimate Unleaded...
I have a CBR600RR and at first I just used regular fuel... then I was at the petrol station one night and the only available pump was the ultimate unleaded... thought I would give it a try and it worked out about £2 more expensive than normal...
Didn't notice much diff but read up about it and it says that putting it in once a month or once every two months won't give any benefits... so now its all I put in and I have noticed a big difference.. it feels smoother on acceleration, sounds nicer and kinda gives me a warm feeling knowing its cleaning the engine out.. Thumbs Up
LUXY DJ
PostPosted: 00:20 - 14 Nov 2005    Post subject: Reply with quote
HTH
Laughing na i meant the difference if any but they must diffa somehow(not price but performance,cleaning,etc)
soz i didnt put it clear enough
GSXR750
riichy
PostPosted: 00:24 - 14 Nov 2005    Post subject: Reply with quote
i buy it for my bike on its B-DAY and X-MASS Laughing ..i love my bike Mr. Green
.......... PLOD ............ zx636 2004
instigator
PostPosted: 00:26 - 14 Nov 2005    Post subject: Reply with quote
For the length of time an owner keeps their motorcycle before upgrading, optimax or whatever it's alternative will make more or less no difference to the health of your engine.
Sounds nicer - buy a different can. Laughing
Smoother on acceleration? Just get a dynojet kit and be done with Wink
The optimax stuff round here is about 10p more than regular. Nae chance I'll buy it.
Bandito
PostPosted: 00:36 - 14 Nov 2005    Post subject: Reply with quote
already got a top can on it...
cheaper than a dyno kit (though power comm is on xmas list)
guess it depends on how much you love your bike.... do you drink rola cola? Razz Very Happy
riichy
PostPosted: 00:39 - 14 Nov 2005    Post subject: Reply with quote
oyyy my mum swears by rola cola........ 20L for 80p cant go wrong at that price... Wink Laughing
mattsmith95
PostPosted: 00:56 - 14 Nov 2005    Post subject: Reply with quote
Yes they do work, I use Esso supreme from time to time, gives me quite a few more miles per gallon.
What these fuels do is restore the MPG you should be really getting, cleans your carb, some performance differences like throttle responce.
OH BTW, Texaco petrol is crap, my bikes run like a dog using standard unleaded and my MPG suffers really badly, takes 2 tanks of Esso supreme to get it running better.
colin1
Captain Safety
PostPosted: 03:22 - 14 Nov 2005    Post subject: Reply with quote
its a marketing ploy. with commodities such as sugar and petrol people buy on price but with branded products, ppl buy into a name they trust and so pay extra and feel good about it.
Its possible that there are real benefits to justify this marketing ploy, but its still a marketing ploy as I'm sure the additives cost next to nothing to make and they could put them in all petrol if they wanted to.
LUXY DJ
PostPosted: 08:51 - 14 Nov 2005    Post subject: Reply with quote
iv been using optimax on every fill for a while now & i dont mind the little bit more for it its minor really if it works then all good if it dont then no big deal Neutral
still wanna know the pro's & con's between
optimax
bp super
esso super
GSXR750
The last post was made 20 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 127.42 Kb
