throtle sticking and driving me crazy
hazza
PostPosted: 20:14 - 13 Nov 2005    Post subject: throtle sticking and driving me crazy Reply with quote
i changed the grips on my rxs 100 today and the throttle keeps sticking...its not rubbing on the metal twisty thing...when i take the top off the throttle it works fine but when i put it on it dosent want to work
gsxrpeak
PostPosted: 20:21 - 13 Nov 2005    Post subject: Reply with quote
try giving everythign a lube up.
try twisting the throle control around a bit
try re routing the cable.
kris
visit my shop
www.tqmotorcycles.co.uk
https://stores.ebay.co.uk/TQ-Motorcycles_W0QQsspagenameZMEQ3aFQ3aSTQQtZkm
Andrewc2oo5zx...
PostPosted: 20:24 - 13 Nov 2005    Post subject: Reply with quote
try attachin it to a peice of wood and holding it in your teeth, works for me, but seriouslt, i changed my grips and they were fatter in diameter and it affected throtle control
zxr's and cbr's
SUNDERLAND AFC
Bezzer
PostPosted: 20:43 - 13 Nov 2005    Post subject: Reply with quote
Take the bar end off first and see if it works OK without it fitted. Could just be the new grips are fractionally longer and jamming between the weight and the throttle housing which would also explain why it's OK when you've taken the top off the housing as that would relieve the friction as well.
If it is that then stick a washer or two on the inside of the bar end to stop it clamping up too close to the throttle rubber.
brown_d9
PostPosted: 07:27 - 15 Nov 2005    Post subject: Reply with quote
Take off the throttle assembly and give the handlebar a clean up with some emory tape, that sorted the probelm out on my NS125F
The last post was made 21 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 43.35 Kb
