| 18_stuart_88 |
 18_stuart_88 World Chat Champion
 Posted: 15:55 - 12 Nov 2005 Post subject: Fitting Jets On My NSR 125 R1 2004! |
How long does this take to do?
How easy is it?
And
Could sombody talk me through an other kind of process that i need to do apart from screw in the jets?
Ive got them the now and about to do it, just needa few tips!
Stu  ____________________ Make: Honda NSR 125 R Year: 2004 Colour: Black And Silver - Died on December 18th 2005, Layed to rest December 30th 2005 :(Make: Aprilia RS 125 Year: 2000 Colour: Black And Red - Derestricted Sold!
Make: Suzuki GSXR 600 SRAD Year: 1998 Colour: Red - White - Blue
Pic of My New Bike!! |
| Biker-Kev |
 Biker-Kev Brolly Dolly
 Posted: 16:02 - 12 Nov 2005 Post subject: |
unless you really know what you are doing, or you have somebody watching you who knows what they are doing, i would really advise against doing it.
It is quite easy to do though.
Take the carb off, and if its the main jet you are changing, its at the bottom, under the float chamber, whip it out, and put in the new one. When you have your carb off, may aswell give it a clean up.
But tbh you would be much better giving it to somebody who knows what they are doing.
Kev ____________________ Zhongyu ZY50, Aprilia SR50, Motorhispania RX50, Aprilia RS125, Honda VFR400 nc24 and my corsa
https://www.bikepics.com/members/bikerkev/
Theory: Passed 8/11/2005 Practical: Passed 13/12/2005 Proud holder of A2 license |
| 18_stuart_88 |
 Posted: 16:11 - 12 Nov 2005 Post subject: |
Hrmmmmm! Its all three im changing
Bugger!!!!!!!
I pop a thread on the Scottish section see if anybody knows what they are doing and if they can gimme a wee hand.
Cheers Kev
| Biker-Kev |
 Posted: 16:42 - 12 Nov 2005 Post subject: |
lol,
Best of luck with it m8 ____________________ Zhongyu ZY50, Aprilia SR50, Motorhispania RX50, Aprilia RS125, Honda VFR400 nc24 and my corsa
| alains |
 alains World Chat Champion
 Posted: 17:43 - 12 Nov 2005 Post subject: |
it's fairly easy to change them providing you have taken the carb off . download my file https://www.geneva-racing.com/~alains/NSRtips.doc
the easiest is the main jet which is screw on top of the fixing float chamber bolt . you will find the others easily ____________________ the worst day fishing is better than the best day working |
| 18_stuart_88 |
 Posted: 18:12 - 12 Nov 2005 Post subject: |
Does the whole CArb need to be completly off Alains? like of and in the palm of my hand.
Ive never completly taken it off like that, ive keept it attacked by the Cable that through the middle of the chamber!
Is it still possible to do this with it all intacked able to access the bottom of the carb?
| alains |
| 18_stuart_88 |
 Posted: 19:21 - 12 Nov 2005 Post subject: |
| theshmoo |
 theshmoo Bottomless Pit
| alains |
| theshmoo |
| 18_stuart_88 |
 Posted: 22:51 - 13 Nov 2005 Post subject: |
Alains!
What about a Power Valve is that worth the invstment from Matt Copper?
| theshmoo |
| alains |
 Posted: 23:07 - 13 Nov 2005 Post subject: |
look my file and the diagram about valves sequence
the cables must be without play but not tighten too much . pulling out the sheaths will tell you how tighten they are , but it's essential that they open fully over 7500 rpm or when you put key on without starting engine . at this time check the sheath of the pulling cable , if you've got a play your valves do not open fully . to compensate , undo the screw on top of the pulley , lift up the pulley , pull out the pulling cable , with a piece of cupper wire (the one you use in your house, about 1mm diameter) , make a ring around the cable (this will make a thickness between the sheath and it's stopper) and it must go inside the stopper, refit the cable and the pulley .
note : using the adjuster will only work on the other cable , and why doing that ? because in use the cables come longer with the time ____________________ the worst day fishing is better than the best day working |
| alains |
| theshmoo |
| alains |
| 18_stuart_88 |
 Posted: 23:47 - 13 Nov 2005 Post subject: |
Their a joke mate! It just some local scammers from ebay who try to steal money from deranged bikers who dont know about their inner working of their bikes and just want it to go fast.
In my bike the powerband is between 7500 and 10000RPM, its just that extra bit of power the bike provides!
Doesnt yours have that Alains?
| alains |
 Posted: 23:52 - 13 Nov 2005 Post subject: |
you should reach 12000 in 5th gear as i do myself . so if i am not just a pretty face , my power band is between 7500 and 12000 rpm  ____________________ the worst day fishing is better than the best day working |
| 18_stuart_88 |
 Posted: 00:31 - 14 Nov 2005 Post subject: |
11000 RPM is my red line! Anything between 10000 and 10500 RPm it kinda screams "i dont wanna go any further or ill blow up" to me!
But i bet your bike a 2 stroker beast! beause you have all the big knowledge of how to keep your bike to the absolute best of it ability! Tuned up to the maximum
| alains |
| 18_stuart_88 |
 Posted: 14:07 - 14 Nov 2005 Post subject: |
Well ive sorted my spark plug to its proper distance apart.
The flat spot is still there! You got anymore ideas to what i could do to fix this!
It is the most annoying thing ever! It envoled a lot of sudden gear changes before my rev counter reaches 6000RPM's.
Stu
P.s. Is it the CDI unit that is compltely messing with my bike? If i get a new Uk model CDI unit will this completely sort this problem or will it just run faster but still with the flat spot?
Alains are you still selling those electronic boxes that you sold The Shmoo? If so i would quite like to invest in on? ____________________ Make: Honda NSR 125 R Year: 2004 Colour: Black And Silver - Died on December 18th 2005, Layed to rest December 30th 2005 :(Make: Aprilia RS 125 Year: 2000 Colour: Black And Red - Derestricted Sold!
| OreoXX |
 OreoXX Nova Slayer
| alains |
| 18_stuart_88 |
The last post was made 20 years, 281 days ago. Instead of replying here, would creating a new thread be more useful? |
