Getting the back out
Rookie
PostPosted: 18:12 - 14 Nov 2005    Post subject: Getting the back out Reply with quote
Can any of you get the back out under braking, ie you let the back wheel skip on the ground a bit and the back wheel kicks out a bit.
Always thought it looked really cool, the guy on Fifth Gear on the GSXR did it farily well. But then it looks like a risky thing to do, I imagine it's easy to take it too far and highside.
Anyone out there able to do it?
Lee_367
PostPosted: 20:15 - 14 Nov 2005    Post subject: Reply with quote
Did it on a supermoto at the bike show, all you had to do was drop 2 gears and dump the clutch going into the corner, i don't know if its any different with a sportsbike though.
?It?s mercy, compassion, and forgiveness I lack?not rationality.?
numark1
Scared of girls
PostPosted: 20:20 - 14 Nov 2005    Post subject: Reply with quote
I did it a few times on my road bike and it shit me up, too much back brake and downshifting.
MX it's a whole differnet story. Cool
phantomtek
Lil Joe Tek
PostPosted: 20:27 - 14 Nov 2005    Post subject: Reply with quote
I did it too much once, and the whole bike shifted sideways then back again. I thought I was going to stack it, be careful.
Rookie
PostPosted: 20:28 - 14 Nov 2005    Post subject: Reply with quote
I don't plan on doing it - not yet anyway Razz I was just wondering whether it's something you can intentionally do, though mostly for show.
johnsilva
PostPosted: 21:32 - 14 Nov 2005    Post subject: Reply with quote
dead easy
as you're crashing down the gears from say, very fast, stick it in first as soon as possible, let the clutch out and lean over, that will get the back out nicely, i speak from experience, this works
John
Current Bikes: ZX7R P5; KR1S C2; GPX250R F3
Previously: CBR400RR-R; YQ50 Aerox
johnsilva
PostPosted: 21:44 - 14 Nov 2005    Post subject: Reply with quote
Siggi wrote:
What? Thinking
WHAT?
John
mrchips
PostPosted: 21:54 - 14 Nov 2005    Post subject: Reply with quote
My AR125 was great for throwing the tail out in the wet.
Your best bet is a supermoto though, was having a look at the marshalls at the bike show they were rear braking it its way round corners.
Northern Irish? www.nibikers.com
lurker
PostPosted: 22:06 - 14 Nov 2005    Post subject: Reply with quote
Siggi wrote:
johnsilva wrote:
dead easy
John
What? Thinking
same as he said
WTF are you talking about
even if you are in the slightest in any way able to get the back wheel sliding in a gary mccoy kinda way youre description of how to do it is going to do nothing other than send some poor barstar down the road with the sound of breaking plastic.
you dont just kick the bike down from 6th to 1st in one swooping motion then let the clutch out and expect only a small slide from the back end.
dainesefreak
PostPosted: 22:18 - 14 Nov 2005    Post subject: Reply with quote
Usually on fast B roads when I giving it some, the back end just lifts under braking and engine braking if I've banged it down a gear on the entry to a tight corner.
Spinning the rear up is fairly easy under acceleration on the way out too if you're fairly heavy handed on the throttle. I can be easy to find yourself over cooking it to the point of no return. It's not something I would personally try to practice too often because I don't think I'm that talented and have very expensive plastics!
Barry_M2
PostPosted: 22:26 - 14 Nov 2005    Post subject: Reply with quote
I loved doing it when I had the 750, was quite easy to control the back. Its much harder on my little 250 now as its a bit to light so it all happens alot faster. I quite like backing into slow corners, most drivers tend not to stick to close to you after you do that in front of them. Quite liked spinning the rear up too when it was wet, but only to 3rd gear.
I've tried it a couple of times on the 250, but its no where near as easy as it was on the ZXR750. Takes a while to get used to it, and if I'm honest, the first time I 'rear wheel steered' was by accident, went a little to hot over a bridge and the roundabout the other side was closer than I expected Wink Confused , after that I sort of thought, well, that wasn't so scary, so started to practice it. Not like I do it all the time, but its nice to know how far you can take it if you do go in a little too hot! Thumbs Up
mrchips
PostPosted: 22:52 - 14 Nov 2005    Post subject: Reply with quote
Think what you want is one of these
SoND
PostPosted: 23:51 - 14 Nov 2005    Post subject: Reply with quote
I've had the back kick out quite a few times.
When I started riding I sometimes had the clutch in going round corners and it kicked it out a bit, quickly learnt to not do that.
From pushing too hard it's slid out on me a few times, in the wet, but I've managed to ride them through, almost all of the times. Whistle
Can't see myself doing it with the brake.
Rookie
PostPosted: 23:56 - 14 Nov 2005    Post subject: Reply with quote
You seem to be missing the point mrchips..or maybe I am, I don't know. Smile
I'm not saying I want to do it, actually the thought of doing it scares the gu-jesus out of me. Don't like unstable cornering at the best of times. I just saw it on a few track races like on Fifth and Top Gear, and wondered if it was something that is widely practised. Thumbs Up
colin1
Captain Safety
PostPosted: 00:05 - 15 Nov 2005    Post subject: Reply with quote
like lee, i did it at the supermoto track at the nec too but i wasnt much good.
I think you should do it by downshifting and engine brakeing as if you try to do it with the back brake you can lock the back wheel and lose it. At least thats what the guys on the supermoto track at the nec said.
Its something you use on sharp corners that you would normally take slowly. You get the back out so that you are starting the turn early and pwoering out of the corner.
Rookie
PostPosted: 00:06 - 15 Nov 2005    Post subject: Reply with quote
Yeah I thought that might be the advantage, so not really somthing that need apply on the roads. Shifty
colin1
Captain Safety
PostPosted: 00:20 - 15 Nov 2005    Post subject: Reply with quote
it would be quite handy in town on 90degree sharp corners but would probably be classed as reckless driving.
As it is, taking the racing line around a 90 degree sharp corner in town while maintaining the speed limit, would fail you a riding test, but doing it 10mph faster by backing it into the corner wd be seen as naughty.
My scooter has a lot of weight at the back so can swing out quite easily in the wet so maybe i shd do it with as its easier to contrl rear brake with left hand rather than right foot, but i dont think it wd be very safe really.
colin1
Captain Safety
PostPosted: 00:54 - 15 Nov 2005    Post subject: Reply with quote
not quite sure i understood that
it either meant
1)i think thats bollock, no one could go round a corner with the back sliding out and control it on roads with traffic. it cant be done its bollocks to claim it can be
or
2)i think thats unsafe and shdnt be discussed
haGGard
PostPosted: 01:16 - 15 Nov 2005    Post subject: Reply with quote
Looks pretty hard and i wouldnt want to give it a try. The guy on the R1 on Bendys video of 'Streetfighter Sunday 2004' at the Ace cafe does it on a public road and look pretty impressive too Thumbs Up
chaff mans random tingz on loot Razz
"Why dont you go and weld your face to a moving train, you sack of pus" - tobyr
"ROFL MY TOFFLE I AM TEH 1337 SPELLING MISTAKE FINDER!" - BikerBen
colin1
Captain Safety
true i guess, but it wd be kind of cool
i used to like doing it on my bmx on grass Smile
Biker-Kev
PostPosted: 01:19 - 15 Nov 2005    Post subject: Reply with quote
Yeah, sometimes do it if there is a hot bird watching, O/J
but yeah can do it, but not something i do too often mind you
Zhongyu ZY50, Aprilia SR50, Motorhispania RX50, Aprilia RS125, Honda VFR400 nc24 and my corsa
https://www.bikepics.com/members/bikerkev/
Theory: Passed 8/11/2005 Practical: Passed 13/12/2005 Proud holder of A2 license
BenBray
PostPosted: 02:20 - 15 Nov 2005    Post subject: Reply with quote
Siggi wrote:
My bollocks-meterTM has blown a fuze. 'BANG' it went, when it calculated all the paremeters involved in going around a corner with the back wheel sliding out and spinning, against oncoming traffic, deliberately. Or at any time really.
That is quite possibly up there with some of the funniest things I've read on this forum LaughingLaughingLaughing
Current Bike: nc30
AcIdBuRnZ
PostPosted: 04:11 - 15 Nov 2005    Post subject: Reply with quote
Siggi wrote:
It means I think anyone who goes around doing that deliberately on public roads needs his head tested.
Totally agree Thumbs Up
That kind of thing should be left with the racers/stunters but not during eveyday riding and certainly not on our roads.
Normal road tyres ain't designed for that kind of thing and all you are doing is putting your chances of binning it even higher.
Obviously, feel free to go and try it - it's your life, your bike, and your money to fix it all when it goes tits up. Actually, that's not exactly true because it's our Taxes that pay to fix YOU in hospital.
Penny Coin Penny Coin
dainesefreak
PostPosted: 09:37 - 15 Nov 2005    Post subject: Reply with quote
For me, it's not something that I try to do on purpose, it sometimes happens on a fast ride because of the nature of the bike/riding style. It's something that, when it does happen, I try to control and ride through not encourage the bike into. As I said before, I have very expensive new plastics and don't try to perform circus tricks in any shape or form.
Method
PostPosted: 09:52 - 15 Nov 2005    Post subject: Re: Getting the back out Reply with quote
https://www.bikechatforums.com/download.php?id=13240
https://www.bikechatforums.com/download.php?id=13241
Rolling Eyes Nope Rolling Eyes
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
The last post was made 20 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 128.93 Kb
