NS125F Top speed?
brown_d9
PostPosted: 08:24 - 15 Nov 2005    Post subject: NS125F Top speed? Reply with quote
My 1988 NS125F has been fully dereistricted with an aftermarket exhaust system courtesy of micron, with a 120 main jet and standarg gearing etc etc.
But in top gear it maxes out at 9000rpm which i expected as it would be a miracle for it to reline in top, being a rotten 2squeek, but at this engine speed it is doing an indicated 80mph which i thought would be more like 90-100, would going up another 1 or 2 main jet sizes give me that little bit more power at the top end?
Thanks in advance for all the help.
PostPosted: 12:02 - 15 Nov 2005    Post subject: Reply with quote
They would indicate around 80 anyway when restricted (the speedo was one of the less accurate ones when they were new). Unlike most sports 2 strokes they will not rev out well, mainly due to the way Honda restricted them by leaving the ATAC chamber open in the low revs position.
I would expect an indicated 95mph+ from an NS, with a real 85~90 top speed if properly derestricted.
brown_d9
PostPosted: 15:10 - 17 Nov 2005    Post subject: Reply with quote
Would a bigger mainjet make it a bit quicker though, there is nothing bad that can happen from having too bigger main jet is there, so i thought a bigger one might help?
Hex
Party Boy
PostPosted: 15:43 - 17 Nov 2005    Post subject: Reply with quote
It would allow to much fuel in and basically flood the engine, thus making it run slower/bog down.
Bigger is not always better, ideally you want the correct one for the engines needs.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
PostPosted: 17:25 - 17 Nov 2005    Post subject: Reply with quote
As above. Bigger is safer (you are unlikely to suffer sudden terminal engine failure from using a main jet a bit too big, quite probably from using one slightly too small), but not better.
You need the right size for best results. Just like increasing the mains up to 300V would not give you a better TV picture.
The NS airbox was meant to be quite restrictive. Drilling holes in it (make sure you drill them in the right place) or replacing it with a K&N were both quite good for performance, just make sure you rejet to get it right.
Also, check your sprockets. Sound to me as though someone has lowered the gearing.
clemsta
PostPosted: 23:35 - 17 Nov 2005    Post subject: Reply with quote
I have a NS125R, with a Allspeed pipe and a K&N type filter, the filter makes it sound really throaty and a lot louder. I've also put a 120 main jet in and i've put the clip on the needle second from bottom, but it sounds rough and between 3/4 and full throttle you can feel it holding back, if you pull full throttle it does not accelerate any harder than if it were at 3/4 throttle but it makes more noise. I haven't touched the mixture screw after adding the pipe and filter, do you screw out to richen and in to lean?
Is there such a thing as a 2 stroke exhaust gas analyser, if there was then you could tell when it was running rich and lean at different rpms.
Has anybody got any suggestions on what to do next.
Thanks in advance
Adam
SOMEONE CALL THE DOCTOR! I've got 2 stroke fever!!!
OGRI - Stuff everything, i've always got my bike!
DAS Passed - 7/6/06
brown_d9
PostPosted: 08:30 - 18 Nov 2005    Post subject: Reply with quote
You need to do a plug chop, ask around on here as im not 100% sure how to do them.
PostPosted: 12:30 - 18 Nov 2005    Post subject: Reply with quote
That suggests it is the main jet that is wrong. At those kind of throttle openings the needle position and the idle air screw / idle mixture screw have no effect.
Not sure what size the stock main jet is on the NS. I would be tempted to buy a range of main jets and have a play (they are cheap).
No difference to a 4 stroke, but the problem is that some people will not want to use them on a 2 stroke due to the amount of rubbish they throw out of the exhaust.
With a slide carb it is not so easy to check the mixture. The mixture is mainly affected by the throttle position rather than the revs. On a dyno you need someone who knows how to operate the throttle, rather than just some monkey who treats it as a CV carbed bike and whacks it onto full throttle immediatly.
There is a gap of 2 years, 218 days between these two posts...
andi_woodley
PostPosted: 23:30 - 23 Jun 2008    Post subject: Reply with quote
Where do you get new carb jets from???
Andi Woodley
PostPosted: 08:59 - 24 Jun 2008    Post subject: Reply with quote
Eurocarb are the UK importer:-
https://www.dellorto.co.uk/
plugger147
PostPosted: 22:27 - 25 Jun 2008    Post subject: Reply with quote
I'm pretty sure the standard one was a 110, I had a 120 in mine with a micron and drilled airbox and it'd read at a tad over 90. I did try it with a K&N but couldn't get it to run smoothly enough no matter how much I tried it'd have a flat spot somewhere, ditched it and went back to the airbox and set it up to run fine.
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
alains
PostPosted: 09:51 - 26 Jun 2008    Post subject: Reply with quote
the needle position is surely too low , try to set the clip higher
The last post was made 18 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 77.39 Kb
