Yamaha XJ600N Oil Light ?
Twitchin
PostPosted: 23:52 - 16 Nov 2005    Post subject: Yamaha XJ600N Oil Light ? Reply with quote
Hey guys.
So..
I turn the key. The neutral light comes on but no oil light. I press the ignition and as the bike starts the oil light flashes on for a sec and then disappears.
Is this normal? Shouldn't the oil light should be on when I turn the key before i start her?
Thanks for reading Smile
PostPosted: 23:56 - 16 Nov 2005    Post subject: Reply with quote
The oil light on those is an oil level light. It normally is on when the ignition is turned on and the engine not running, so I presume there is some circuit to trigger this.
All th ebest
Twitchin
PostPosted: 11:39 - 20 Nov 2005    Post subject: Reply with quote
Thanks for the info Keith Smile
Gazdaman
I did a trackday!!!
PostPosted: 12:25 - 21 Nov 2005    Post subject: Reply with quote
Hi, mine did that.
It used to be on when the ignition was on but the engine not. Then after a while it stopped coming on when the ignition was on but engine not running, but would show while the start motor was turning over.
Never knew why. Just kept a closer eye on the level after that.
Gaz
Redd
PostPosted: 17:44 - 21 Nov 2005    Post subject: Reply with quote
Mine only shows when the starter is turning...except for the other night when I installed a new fuse in my heated grips (never had them working since I got the bike). Lasted about 500 yards, then the fuse blew for the grips and the oil light came on. Stopped, checked oil, turned it back on, everything was normal again...except I still had cold hands. Think the grips are damaged and shorting out, hence the fuse blowing repeatedly.
Professional Uberslacker
2006 Kawasaki Z1000 - Black at the front, airbrushed fade to red at the back.
1998 Kawasaki KDX 200 Enduro project bike
The last post was made 20 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 43.55 Kb
