BOlt still wont come off
dransy
PostPosted: 23:30 - 24 Nov 2005    Post subject: BOlt still wont come off Reply with quote
Hi all i posted a few weeks ago about my bolt on my caliper not coming of well now its just taken the piss, ive wd40 it it didnt work, i hammered a smaller size rachet it on, the bolt round of again , i grinded a slit and tried to turn it with a hammer and a screw driver and ive grinder the head completely off now and tried drilling it , but it just wont drill threw it,
any ideas? i got told to use a hammer drill?
Marc
Sparks!
Sir Tart-a-lot
PostPosted: 23:32 - 24 Nov 2005    Post subject: Reply with quote
Nooo don't use a hammer drill Laughing
Just use a drill on normal setting, NOT HAMMER.. with a good quality HSS bit. It WILL dril through the middle then the bolt should collapse in and you can clear the thread... either that or drill bigger than the bolt and then re-thread the newly drilled hole... depends on size of bolt etc.
PostPosted: 23:42 - 24 Nov 2005    Post subject: Reply with quote
Have you got the calliper off? If not, take that off, you often find the 'stump' of bolt that is left will just unscrew with some mole grips once you have the pressure off it.
As to drilling, it is a mild steel bolt, a decent drill bit should go through it like butter. As Sparks! says, go get a new HSS drill bit of the correct size and drill through it SLOWLY. If your drill bit is sharp, it should literally 'suck' itself into the metal.
You really need a variable speed drill (gets faster the further you squeeze the trigger), if you only have one (fast) speed setting, you'll overheat the drill bit which will make it softer & blunt and heat harden the end of the bolt (blue colour, smell of burning metal).. With a new drill bit, it should take about 15-20 minutes to drill through just using a hand drill (which is about the speed you should be going).
Drill a small, absolutely bang in the middle pilot hole first, then move on to a bigger drill bit.
Knowlsey
PostPosted: 23:45 - 24 Nov 2005    Post subject: Re: BOlt still wont come off Reply with quote
Marc
if you mean the bolt that fixes the caliper to the fork leg,,, then fid someone with a welder and weld a nut on it and use a hex socket, but if you are going to drill it out then use decent drill bits, the cheap shit ones will burn out, a welder should be ok, just disconect the battery or put a surge protector over, it souldnt disperse to much heat if you wel a bit at a time and cool it with a water spray
ZRX61
Victor Meldrew
PostPosted: 01:54 - 25 Nov 2005    Post subject: Re: BOlt still wont come off Reply with quote
dransy wrote:
i
I
dransy wrote:
of
off
dransy wrote:
ive
I've
dransy wrote:
of
off
dransy wrote:
i grinded
I ground
dransy wrote:
ive grinder
I've ground
dransy wrote:
threw
through
dransy wrote:
any ideas?
Go back to school & try again?
Walloper
PostPosted: 02:07 - 25 Nov 2005    Post subject: Reply with quote
If you can get access to a grinder take a Masonry drill bit and modify the carbide tips to provide a bit of rake Clearance. So the leading edge of the two carbide tips is higher than the trailing edge.
This will pish through the bolt using normal speed and feed.
Use oil to keep the doings cool.
There you go.
Rookie
PostPosted: 02:08 - 25 Nov 2005    Post subject: Reply with quote
Laughing Mildly amusing for you ZXR61. Wink
Walloper
PostPosted: 02:11 - 25 Nov 2005    Post subject: Re: BOlt still wont come off Reply with quote
ZRX61 wrote:
dransy wrote:
i
I
dransy wrote:
of
off
dransy wrote:
ive
I've
dransy wrote:
of
off
dransy wrote:
i grinded
I ground
dransy wrote:
ive grinder
I've ground
dransy wrote:
threw
through
dransy wrote:
any ideas?
ZRX61
Smart
Arsed
Bastar*
Shocked
riichy
PostPosted: 14:31 - 25 Nov 2005    Post subject: Reply with quote
ZXR61 you sound like my old english teacher.... Wink Mr. Green
.......... PLOD ............ zx636 2004
PostPosted: 15:45 - 25 Nov 2005    Post subject: Reply with quote
I would be tempted to remove the head from the bolt (grinder, drill, whatever). Take the pads out of the caliper and push the pistons fully in so that there is plenty of clearance between the pistons and the disk.
You should then be able to take the caliper off the fork leg (unbolting the disk from the wheel would give even more clearance).
With the caliper off you can attempt to get the remains of the bolt out in relative safety and comfort, well away from the forks. Or just cheat and put a replacement caliper on (Aprilia have been using the same caliper since 1988, and they seem generally very weather resistant).
Knowlsey
PostPosted: 17:03 - 25 Nov 2005    Post subject: Re: BOlt still wont come off Reply with quote
ZRX61 wrote:
dransy wrote:
i
I
dransy wrote:
of
off
dransy wrote:
ive
I've
dransy wrote:
of
off
dransy wrote:
i grinded
I ground
dransy wrote:
ive grinder
I've ground
dransy wrote:
threw
through
dransy wrote:
any ideas?
look under name" Victor Meldrew" nuff said,,, oooo sorry "enough" said, who gives a shit.
SoND
PostPosted: 19:44 - 25 Nov 2005    Post subject: Reply with quote
Drilling it out and tapping it is probably the best option. When you're drilling it, do it slowly and give it plenty of pressure.
The hole size should be about 1 - 1.2mm smaller than the tap to get the best thread in it.
Good luck.
The last post was made 20 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 82.36 Kb
