| dransy |
 dransy World Chat Champion
| Sparks! |
 Sparks! Sir Tart-a-lot
 Posted: 23:32 - 24 Nov 2005 Post subject: |
Nooo don't use a hammer drill
Just use a drill on normal setting, NOT HAMMER.. with a good quality HSS bit. It WILL dril through the middle then the bolt should collapse in and you can clear the thread... either that or drill bigger than the bolt and then re-thread the newly drilled hole... depends on size of bolt etc. ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
 Posted: 23:42 - 24 Nov 2005 Post subject: |
Have you got the calliper off? If not, take that off, you often find the 'stump' of bolt that is left will just unscrew with some mole grips once you have the pressure off it.
As to drilling, it is a mild steel bolt, a decent drill bit should go through it like butter. As Sparks! says, go get a new HSS drill bit of the correct size and drill through it SLOWLY. If your drill bit is sharp, it should literally 'suck' itself into the metal.
You really need a variable speed drill (gets faster the further you squeeze the trigger), if you only have one (fast) speed setting, you'll overheat the drill bit which will make it softer & blunt and heat harden the end of the bolt (blue colour, smell of burning metal).. With a new drill bit, it should take about 15-20 minutes to drill through just using a hand drill (which is about the speed you should be going).
Drill a small, absolutely bang in the middle pilot hole first, then move on to a bigger drill bit. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Knowlsey |
 Knowlsey Scooby Slapper
 Posted: 23:45 - 24 Nov 2005 Post subject: Re: BOlt still wont come off |
| dransy wrote: | Hi all i posted a few weeks ago about my bolt on my caliper not coming of well now its just taken the piss, ive wd40 it it didnt work, i hammered a smaller size rachet it on, the bolt round of again , i grinded a slit and tried to turn it with a hammer and a screw driver and ive grinder the head completely off now and tried drilling it , but it just wont drill threw it,
any ideas? i got told to use a hammer drill?
Cheers
Marc |
if you mean the bolt that fixes the caliper to the fork leg,,, then fid someone with a welder and weld a nut on it and use a hex socket, but if you are going to drill it out then use decent drill bits, the cheap shit ones will burn out, a welder should be ok, just disconect the battery or put a surge protector over, it souldnt disperse to much heat if you wel a bit at a time and cool it with a water spray |
| ZRX61 |
 ZRX61 Victor Meldrew
| Walloper |
 Walloper Super Spammer
| Rookie |
 Rookie World Chat Champion
 Posted: 02:08 - 25 Nov 2005 Post subject: |
Mildly amusing for you ZXR61.  |
| Walloper |
| riichy |
 riichy World Chat Champion
 Posted: 14:31 - 25 Nov 2005 Post subject: |
ZXR61 you sound like my old english teacher....  ____________________ .......... PLOD ............ zx636 2004 |
 Posted: 15:45 - 25 Nov 2005 Post subject: |
I would be tempted to remove the head from the bolt (grinder, drill, whatever). Take the pads out of the caliper and push the pistons fully in so that there is plenty of clearance between the pistons and the disk.
You should then be able to take the caliper off the fork leg (unbolting the disk from the wheel would give even more clearance).
With the caliper off you can attempt to get the remains of the bolt out in relative safety and comfort, well away from the forks. Or just cheat and put a replacement caliper on (Aprilia have been using the same caliper since 1988, and they seem generally very weather resistant).
| Knowlsey |
| SoND |
 SoND World Chat Champion
 Posted: 19:44 - 25 Nov 2005 Post subject: |
Drilling it out and tapping it is probably the best option. When you're drilling it, do it slowly and give it plenty of pressure.
The hole size should be about 1 - 1.2mm smaller than the tap to get the best thread in it.
Good luck. ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister." |
The last post was made 20 years, 305 days ago. Instead of replying here, would creating a new thread be more useful? |
