Bike/Car Skidding
DukeRed
PostPosted: 22:47 - 28 Nov 2005    Post subject: Bike/Car Skidding Reply with quote
Was wondering what would happen when I'm on the motorway and the car in front slams on its brakes. If I had a front wheel skid would I slow quicker than them if we were going at the same speed before?
Basically wondering if there's ever a time cars have better braking than bikes. Ice or rain maybe?
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
superstacker
PostPosted: 22:50 - 28 Nov 2005    Post subject: Reply with quote
If you have front wheel skid then chances are you will bin it!
Sparks!
Sir Tart-a-lot
Cars almost always have better brakes than bikes, in my opinion.
In a car you can just slam the brakes on full power with no real worries.. On a bike you gotta be a lot more careful, you have better brakes yes, but you can't use them to their full without falling off.
I can stop my car quicker than my bike unless I'm really trying to stop quickly on the bike... in accident prevention type situtaions I'd rather be in the car Wink
PostPosted: 22:51 - 28 Nov 2005    Post subject: Re: Bike/Car Skidding Reply with quote
Not at all.
When there's a car with ABS and acceptable tyres, I would expect a less experienced rider to have trouble stopping as quickly.
Me an John tried some tests with his mid nintes 325i with ABS - my TRX could stop in quite a lot shorter distance from 60. However I am used to very hard braking (from racing etc) and the bike had enough grip. Add in rain and the bike may start to be having trouble with traction, ice much more so.
A good reason to leave the proper gap - only a fool breaks the two second rule... Smile.
kb-zxr
PostPosted: 22:52 - 28 Nov 2005    Post subject: Reply with quote
A front wheel skid would probably have you off mate.
Generally you can cain the brakes in the car without fear of falling off.
Its the human / machine equation. In a car-stomp pedal ABS will sort it (not best technique but an example).
Snatch the front brake and lock it you might end up on your arse / face. If you are skillful enough you might be able to stop quicker as you have less mass, but also less discs/wheels/tires etc.
kb-zxr
PostPosted: 22:53 - 28 Nov 2005    Post subject: Reply with quote
Wow that was a lot of posting in the space of 2 minutes. Smile
DukeRed
PostPosted: 22:54 - 28 Nov 2005    Post subject: Reply with quote
Hmm true. With a front wheel skid in a straight line (motorway) I've found you don't tend to bin it. Corners are obviously different.
But surely we've got less mass and super duper blue spot brakes / double H pads etc etc.
That's a bit depressing/sobering to think that cars can outbrake me.
edit - ok most of those posts make this a bit obselete - edit
SoND
PostPosted: 22:57 - 28 Nov 2005    Post subject: Reply with quote
When you skid it takes longer for you to stop. You have less grip on the road and are just sliding.
If your front wheel skids you might only get to have a small chance to save it, if you're lucky enough to not hit the ground in a split second.
PostPosted: 23:30 - 28 Nov 2005    Post subject: Reply with quote
When you are in low grip conditions, consider the size of the road contact patch on the bike as compared to a car. Especially when nearly all your braking force is going through the front tyre on the bike under hard braking.
Leave a big enough gap!
colin1
Captain Safety
PostPosted: 00:41 - 29 Nov 2005    Post subject: Reply with quote
I read somewhere that at speeds above 60mph, the 2 second rule shd become the 3 second rule and that at speeds above 100mph, it shd be the 4 second rule.
And you shd double those if its wet.
If you dont think you will stop in time, on a bike you can just nip round them even if its changing lanes without indicating. Id prefer to take the risk if I dont think I'd stop in time.
I guess it wd be good to practise some proper hard braking so I know how quickly I can stop and so I could do it well if needed.
ZRX61
Victor Meldrew
PostPosted: 03:43 - 29 Nov 2005    Post subject: Re: Bike/Car Skidding Reply with quote
If you maintained the correct distance you'd pull up about 20ft behind him without breaking a sweat...
If you're a clueless idiot you'l end up in his passenger seat....
PostPosted: 08:42 - 29 Nov 2005    Post subject: Reply with quote
Except if you're braking at full force, then it's very hard to change direction.
So, when there's a car that you're about to hit, you've got to have enough wits about you to let go of the brakes a bit and steer the bike. A lot harder than it might sound.
colin1
Captain Safety
PostPosted: 11:59 - 29 Nov 2005    Post subject: Reply with quote
i was thinking, no braking and avoid the the car in front by dodging it.
I dont cane it on the motorway, so id be pulling off onto the hard shoulder.
SoND
PostPosted: 19:31 - 29 Nov 2005    Post subject: Reply with quote
Can someone explain the 2/3/4 second rule for me?
Never heard that term before.
Bendy
Mrs Sensible
PostPosted: 19:33 - 29 Nov 2005    Post subject: Reply with quote
Choose a fixed point, a road sign or something. Start counting the seconds when the vehicle in front passes it, stop counting when you pass it.
There's a bit of the M1 has chevrons painted on it to show you how far apart you should be, even thinking you're keeping a good distance you're usually too close.
pjones_po
PostPosted: 19:34 - 29 Nov 2005    Post subject: Reply with quote
I agree with the masses, an average car with an average driver braking at the same time and speed as an average bike with an average rider I would expect the car to come up alot shorter.
At least in a car you can sometimes have the element of "stamp the floor, shut your eyes and hope for the best".
deputy
PostPosted: 19:56 - 29 Nov 2005    Post subject: Reply with quote
And you shd double those if its wet..
It shouldn't matter what speed you are doing, as the distance you travel in 2 seconds at 60mph will be double the distance at 30. So if you keep 2 seconds away from the vehicle in front, as you speed up you should drop back from them to keep the 2 seconds away.
Thanks to Isaac Newton.
extreme3d
PostPosted: 09:28 - 30 Nov 2005    Post subject: Reply with quote
2 second rule should become 4 in the wet and 10 in ice/frost. That's straight out of the highway code, but there is of course nothing stopping you from leaving a bigger gap if you think your bike would struggle to stop in the available space. Remember if you go into the back of someone it's your fault.... and trust me when i say it hurts Embarassed
Jack_Cheese
PostPosted: 13:53 - 30 Nov 2005    Post subject: Reply with quote
I managed it in the fog when I was on diesel. Tried braking but it just locked, tried again and it locked, so had to pull round the car. Good job i decided to use back brake first due to the slipperiness, else i would have had a close encounter with a red Nissan Micra's rear bumper.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
PostPosted: 18:24 - 30 Nov 2005    Post subject: Reply with quote
Back brake is often more likely to slide as well however, something to keep in mind.
(Though don't go pulling the front in hard when you see ice just because I said that Smile.)
Aikman666
PostPosted: 18:38 - 30 Nov 2005    Post subject: Reply with quote
Remember, even though the car will have more powerful brakes (and 4 of them at that) It has alot more momentum to reduce, hence it has more impulse. Whereas your bike, having worse brakes (although not necessarily) will have less momentum to dissapate, hence less impulse. Also the chances are that if you slam on your brakes you will just skid, probably binning the bike, i would say you should probably bang down the gearbox aswell, but that may cause further instability.
Will work for petrol
My Design Blog
PostPosted: 18:41 - 30 Nov 2005    Post subject: Reply with quote
In good conditions with reasonably tyres and bike the bike should stoppy rather than skid.
Perfect braking is going to be got from the point where the rear wheel is just about to leave the ground.
In this case there's no point doing anything with the rear, brakes or gears.
Walloper
PostPosted: 18:45 - 30 Nov 2005    Post subject: Reply with quote
When braking force (the force preventing the wheel from turning) exceeds the force pushing you forward then the wheel locks.
When locked the wheel/tyre provides virtually zero braking effect.
The maximum braking effect is at the point just before the wheel stops turning.
So locking the wheel/s extends braking distance.
Any 'side' force will cause the wheel to slip off axis and you're down. Or in a park.
ABS prevents a 'full lock' by rapidly applying and releasing the brake.
(Cadence). Thus the wheel can almost stop but not skid.
Bikes stop in less distance than cars due to effects of mass.
HGVs need to have more efficient brakes than cars or bikes due to extra mass needing to be stopped in a comparable distance.
I hope this helps you stay on. Laughing
PostPosted: 18:48 - 30 Nov 2005    Post subject: Reply with quote
As above, in conditions this shouldn't happen on a bike - instead the force will start to lift th eback wheel
It is possible to brake very hard while starting to turn on a bike or still quite hard while getting into a corner.
Not advisable on the road I admit.
Cog Head
PostPosted: 18:50 - 30 Nov 2005    Post subject: Reply with quote
iv hav my front wheel lock up on gravely type stuff at kingsbury water park before, i was attempting to do an e-stop type thing as there was some idiotic kid running round like a fkn idiot in front of me, and i slid for about 5 metres and didnt bag it, must have been lucky Wink Thumbs Up
Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore Shifty
McGee: Hence I smell like a gimp
The last post was made 20 years, 72 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 127.91 Kb
