| DukeRed |
 DukeRed World Chat Champion
 Posted: 22:47 - 28 Nov 2005 Post subject: Bike/Car Skidding |
Was wondering what would happen when I'm on the motorway and the car in front slams on its brakes. If I had a front wheel skid would I slow quicker than them if we were going at the same speed before?
Basically wondering if there's ever a time cars have better braking than bikes. Ice or rain maybe? ____________________ Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com |
| superstacker |
 superstacker Traffic Copper
| Sparks! |
 Sparks! Sir Tart-a-lot
 Posted: 22:50 - 28 Nov 2005 Post subject: |
Cars almost always have better brakes than bikes, in my opinion.
In a car you can just slam the brakes on full power with no real worries.. On a bike you gotta be a lot more careful, you have better brakes yes, but you can't use them to their full without falling off.
I can stop my car quicker than my bike unless I'm really trying to stop quickly on the bike... in accident prevention type situtaions I'd rather be in the car  ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
| G |
 G The Voice of Reason
| kb-zxr |
 kb-zxr Could Be A Chat Bot
| kb-zxr |
 Posted: 22:53 - 28 Nov 2005 Post subject: |
Wow that was a lot of posting in the space of 2 minutes.  |
| DukeRed |
 Posted: 22:54 - 28 Nov 2005 Post subject: |
Hmm true. With a front wheel skid in a straight line (motorway) I've found you don't tend to bin it. Corners are obviously different.
But surely we've got less mass and super duper blue spot brakes / double H pads etc etc.
That's a bit depressing/sobering to think that cars can outbrake me.
edit - ok most of those posts make this a bit obselete - edit ____________________ Enjoy Life There's Plenty of Time to be Dead
| SoND |
 SoND World Chat Champion
 Posted: 22:57 - 28 Nov 2005 Post subject: |
When you skid it takes longer for you to stop. You have less grip on the road and are just sliding.
If your front wheel skids you might only get to have a small chance to save it, if you're lucky enough to not hit the ground in a split second. ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister." |
| stinkwheel |
 Posted: 23:30 - 28 Nov 2005 Post subject: |
When you are in low grip conditions, consider the size of the road contact patch on the bike as compared to a car. Especially when nearly all your braking force is going through the front tyre on the bike under hard braking.
Leave a big enough gap! ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| colin1 |
 colin1 Captain Safety
| ZRX61 |
 ZRX61 Victor Meldrew
| G |
| colin1 |
| SoND |
 Posted: 19:31 - 29 Nov 2005 Post subject: |
Can someone explain the 2/3/4 second rule for me?
Never heard that term before. ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister." |
| Bendy |
 Bendy Mrs Sensible
| pjones_po |
 pjones_po Renault 5 Driver
| deputy |
 deputy Scooby Slapper
| extreme3d |
 extreme3d World Chat Champion
| Jack_Cheese |
 Jack_Cheese World Chat Champion
| G |
 Posted: 18:24 - 30 Nov 2005 Post subject: |
Back brake is often more likely to slide as well however, something to keep in mind.
(Though don't go pulling the front in hard when you see ice just because I said that .) |
| Aikman666 |
 Aikman666 World Chat Champion
 Posted: 18:38 - 30 Nov 2005 Post subject: |
Remember, even though the car will have more powerful brakes (and 4 of them at that) It has alot more momentum to reduce, hence it has more impulse. Whereas your bike, having worse brakes (although not necessarily) will have less momentum to dissapate, hence less impulse. Also the chances are that if you slam on your brakes you will just skid, probably binning the bike, i would say you should probably bang down the gearbox aswell, but that may cause further instability. ____________________ Will work for petrol
My Design Blog |
| G |
| Walloper |
 Walloper Super Spammer
 Posted: 18:45 - 30 Nov 2005 Post subject: |
When braking force (the force preventing the wheel from turning) exceeds the force pushing you forward then the wheel locks.
When locked the wheel/tyre provides virtually zero braking effect.
The maximum braking effect is at the point just before the wheel stops turning.
So locking the wheel/s extends braking distance.
Any 'side' force will cause the wheel to slip off axis and you're down. Or in a park.
ABS prevents a 'full lock' by rapidly applying and releasing the brake.
(Cadence). Thus the wheel can almost stop but not skid.
Bikes stop in less distance than cars due to effects of mass.
HGVs need to have more efficient brakes than cars or bikes due to extra mass needing to be stopped in a comparable distance.
I hope this helps you stay on.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| G |
| Cog Head |
 Cog Head Could Be A Chat Bot
 Posted: 18:50 - 30 Nov 2005 Post subject: |
iv hav my front wheel lock up on gravely type stuff at kingsbury water park before, i was attempting to do an e-stop type thing as there was some idiotic kid running round like a fkn idiot in front of me, and i slid for about 5 metres and didnt bag it, must have been lucky  ____________________ Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore
McGee: Hence I smell like a gimp |
The last post was made 20 years, 73 days ago. Instead of replying here, would creating a new thread be more useful? |
