| mistergixer |
 mistergixer World Chat Champion
 Posted: 14:11 - 15 Aug 2005 Post subject: Track Technique. |
Question about down shifting on track:
When approaching a bend after a straight, and need to downshift a few gears, should you:
A, Go down through the box in sequence, re-engaging the clutch for each gear to make use of engine braking.(Obviously whilst using the brakes!)
B, Use the brakes and shift down to the correct gear in one go, i.e without engaging each gear.
??? ____________________ Space Monkey #7
Mistergixer's videos on YouTube |
| MarJay |
 MarJay But it's British!
 Posted: 14:13 - 15 Aug 2005 Post subject: |
AFAIK you should go down from the gear you are in through to the gear you want and use the brakes to control your speed so that when you let out the clutch you don't lock the rear.
G would be a better person to answer your question though.  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| Kirmit |
 Kirmit Nitrous Nuisance
| Steve H |
 Steve H World Chat Champion
 Posted: 14:29 - 15 Aug 2005 Post subject: |
Yeah Option B - but don't forget to count the gears down, there's nothing worse that the moment just after banging down through the box as you begin to let your clutch out and you realise that you're in 1st for a 2nd or 3rd gear corner  ____________________ Mellow Yellow
The BCF Top TEN - 2010, 2009, 2008, The Original. |
| G |
 G The Voice of Reason
| Silver |
 Silver World Chat Champion
| Gazdaman |
 Gazdaman I did a trackday!!!
| VFR400UK |
 VFR400UK Scooby Slapper
 Posted: 20:07 - 15 Aug 2005 Post subject: |
One gear at a time isthe correct way, using the engine braking on the rear wheel and brakes on the front, which is why racers hardly ever use the rear brake.
In reality itwon't make a huge difference to your speed, so if your used to doing it a certain way, do it like that.
I find 120mph roundabout aproaches the best way to practice  |
| G |
| Kath#27 |
 Kath#27 L Plate Warrior
| jjonth |
 jjonth Renault 5 Driver
| cunni |
 cunni Spanner Monkey
 Posted: 12:09 - 31 Aug 2005 Post subject: |
if it were always the perfect corner you were aproaching, then option A sounds good.
If it is a dam fast corner leading onto a chicane, say from 4th at full lean, stand the bike up slightly then drop into a 1st gear flick, then go down two gears at once on the brakes, let cltuch out to get into corner, then down another as you flick through.
Again, all depends on the corners. You'll figure it out more when you try stuff out! Beware of the grass!
I find my self using different methods at various parts of each track. The longer and straighter a braking zone, the more engine braking I use. The more curved or short the braking zone, the more gears I downshift before letting the clutch out! But then I do have the use of a slipper clutch!
Just do what feels right to you. Try different things until something feels right, then you can concentrate on that and get faster!
Remember, there is no right or wrong way of doing things. One way will keep you (and you alone) upright and one way will make most of us fall off! If you study racing DVD's and watch the pro's, you'll see some bash down the gears, some leave it late, some go one at a time blipping the throttle, others step the rear out and use a ton of back brake. each to their own! ____________________ TL1000R Parts For Sale! |
| Merlin |
 Merlin L Plate Warrior
| cunni |
 Posted: 21:51 - 26 Nov 2005 Post subject: |
In my next track session, i'm going to start playing with changing down whilst in higher revs and using rear brake to see how the bike handles and where it tries to go, as well as weighting pegs under rear braking, just to see if I can't get it turned slightly before actually tipping in. Rear wheel steering basically. Wish me luck, lol. ____________________ TL1000R Parts For Sale! |
| CoronaBoner |
 CoronaBoner World Chat Champion
| G |
| BenBray |
 BenBray Spanner Monkey
| G |
| Shaun |
 Shaun Likes 'em bent
| cunni |
 Posted: 19:15 - 27 Nov 2005 Post subject: |
You have too much finger on the brakes. try using two fingers instead of four, (usually the first two, but I use my middle two fingers) and try to only have the last bits of your fingers on the lever, the bits after the last joint, as this will allow your fingers to flatten out more as you blip the throttle without pulling more brake on.
Also, try blipping the throttle with the curve between your thumb and first finger instead of using the grip from the fingers themselves! This is why I use the middle two fingers, it leaves me more contact area on the twist gripp between my fist finger and thumb. ____________________ TL1000R Parts For Sale! |
| cunni |
 Posted: 19:34 - 27 Nov 2005 Post subject: |
Basic downshifting coming up to a corner (on the track only) for me:
Move my arse halfway off seat and my middle two fingers are reaching to cover the front brake, still accelerating and flat down on the tank, behind the screen.
When at my chosen braking point, I sit up into wind, keeping my upper body over the tank, arse still hanging off, pulling brake lever hard (I use slicks and have full race brakes, you may want to apply them a bit more gradually, but still strong). Very important point, I keep both knees pinned against the tank/frame (one leg is lower due to hanging off) and apply all my body load to the bike through the tank rather than the handle bars. My arms are bent at the elbows and nicely relaxed, taking no strain, so I can feel the breaking force and correct any steering changes. (also not cause any unwanted steering changes) My crotch is approx 2 inch off the tank when braking hard.
When the rev's get down to approx. 5000rpm I down shift to the next gear, using the clutch, blip the throttle to match revs. (You get used to how much) It is important to blip it enough and at just the right moment, as you don't want to be left feeding the throttle on and feeding the clutch out, you want to be turning the throttle on and off within 0.05 seconds max. Only just pull the clutch in to the biting point, no more. Set the biting point where the lever is almost fully let out, this way you spend less time pulling and releasing the lever.
Braking force is kept constant during this, see post above.
Every time the rev's get to 5000rpm, another downshift.
Brakes are graduallysoftened as the bike gets lent over more until at the desired lean for that corner, then the throttle is cracked open, to carry me to the appex with max. ground clearance and speed.
As I'm tipping the bike in, I'm also dropping my knee from pinned against the frame to hanging gentally outwards, not pointing at the floor, I'm leaning my upper body into the turn by droping my elbow and I'm turning my head and looking towards the apex point/exit of the corner. Outside elbow gripping the side of the tank, outside knee pressed into the tank, outside foot pressing hard on the footrest, inside foot right up high on the footrest, knee held just off the tarmac.
Coming down from 150MPH to around 30MPH, you will probably go down 3-4 gears in approx. 4-5 seconds, so that's one gear change per second, sometimes less. I occasionally go down two gears at a time or in higher revs, but I'm riding a fully race prep'd 1000cc V-twin and have a Cresent Suzuki slipper clutch, so I can actually get away with more.
Depending on how brave/controlled you are with your right foot, marginal rear brake can be used, especially at the tipping in point.
watch James toseland in the 2004 WSBK Championship at the French rounds in-particular, he looks like he is doing the funky chicken coming up to corners, as he's changing down gears so fast, his arms and whole body are being used to make it that quick. It is very physically demanding when you ride fast, as in not track day fast, racing speeds!
Hope I haven't missed anything too important there? Not neccessarily very suited to road riding. ____________________ TL1000R Parts For Sale! |
| BenBray |
| clarkee |
 clarkee Derestricted Danger
 Posted: 21:35 - 30 Nov 2005 Post subject: |
Cunni, you go on even more on here  |
| G |
The last post was made 20 years, 317 days ago. Instead of replying here, would creating a new thread be more useful? |
