| puremagic72 |
 puremagic72 Brolly Dolly
 Posted: 18:44 - 01 Dec 2005 Post subject: nsr stalls in 1st on take-off?? |
hi all, small problem, my nsr stalls alot in 1st gear when i start to move, now i have only been using it the last 2 days, so might be having to get used to it, it was used before me, as i have just bought it.
Not sure if this is a problem for other users of the nsr.
Also, the speedometer does not work, the cable is of at the wheel end, just not sure where it goes, as there seems to be no space for it to go.
Any help would be appreciated.
Baz. |
| 18_stuart_88 |
 18_stuart_88 World Chat Champion
 Posted: 19:45 - 01 Dec 2005 Post subject: |
Did you speedo work before this problem started?
Do you have petrol in your bike?
Stu  ____________________ Make: Honda NSR 125 R Year: 2004 Colour: Black And Silver - Died on December 18th 2005, Layed to rest December 30th 2005 :(Make: Aprilia RS 125 Year: 2000 Colour: Black And Red - Derestricted Sold!
Make: Suzuki GSXR 600 SRAD Year: 1998 Colour: Red - White - Blue
Pic of My New Bike!! |
| puremagic72 |
| puremagic72 |
 Posted: 19:59 - 01 Dec 2005 Post subject: |
sorry yes there is petrol in it.
Baz.  |
| 18_stuart_88 |
 Posted: 20:03 - 01 Dec 2005 Post subject: |
Right youv completly lost me know
Whats the new cable for? Wat is the new cable and is it to do with the stalling on first take off?
| puremagic72 |
 Posted: 20:14 - 01 Dec 2005 Post subject: |
hi, sorry, this topic has 2 seperate problems.
1. the speedo has not worked since i have had it, and i have just noticed a free cable that has come off at the front wheel( presumably the speedo cable), but not sure where it goes on the wheel.
2. the bike stalls when i take off, twice today i had to pull it over 2 one side of the road as i was in the middle of it, it might be that i'm not used to it yet, but suely shouldn't happen.
Thanks stu,
Baz.  |
| 18_stuart_88 |
 Posted: 20:18 - 01 Dec 2005 Post subject: |
Erm..... Ive never actualy touched my speedo at any time of having a bike, so i dont have a clue about that. If sombody doesnt know on here then take it to a sparky and get them to have a examination on it, should cost you much.
As for it stalling on first take of i wouldnt know unless i seen or experienced the problem, sorry. But another question.
Does it stall wen your just sitting normal at lights for example?
And also have you left your choke on by any chance?
| puremagic72 |
| 18_stuart_88 |
 Posted: 20:28 - 01 Dec 2005 Post subject: |
Yeh could probly do with fixin your idle timer thing! And also you may have left your choke out.
Another screw on the carb?!?!?!?
thers about 20 diffrent screws
| puremagic72 |
 Posted: 20:30 - 01 Dec 2005 Post subject: |
theres another screw right next to the idle timing screw, i've heard something about adjusting this.
Baz.  |
| puremagic72 |
| Black Knight |
 Black Knight World Chat Champion
 Posted: 20:51 - 01 Dec 2005 Post subject: |
The speedo cable should run from the back or side of the speedo unit down through the front fairing to a point near the wheel axle.
The slit thing spins as the wheel turns, this spins a drive in the back of your speedo unit giving you a reading.
If both ends are connected correctly it may be that its broken inside.In which case you need a new cable. Not usually expensive.  |
| puremagic72 |
| Black Knight |
| puremagic72 |
 Posted: 21:15 - 01 Dec 2005 Post subject: |
thanks black knight for your help, will have a gander tomorrow, its frustrating as i work alot of hours, so i go to work when its dark and come home in it, so cant have a look properly, will look tomorrow if i can, i can tell from the cable as it bends it must be close to where you say.
Thanks again,
Baz.  |
| bidman |
 bidman Crazy Courier
 Posted: 21:53 - 01 Dec 2005 Post subject: |
I think your bike may be idling a little too slowly if you are having to give it a fair few revs to get going try turning the idle screw inwards maybe half a turn on the carb slider body, or this can be done on the throttle cable, there should be an adjusting break in the outer cable this can be unscrewed to tighten the throttle cable .
As for the speedo cable as many people have already said there will be a small hole near the front left fork inbetween the wheel and fork leg where the cable slides into and slots into the gearing inside .
Let us know how it goes mate, Dan ____________________ Don't ride it, RAG IT!! |
| puremagic72 |
 Posted: 22:45 - 01 Dec 2005 Post subject: |
ok, gr8, will check it out tom, thanks bidman!!
Will post result very soon.
Thanks again,
Baz.  |
| alains |
 alains World Chat Champion
| puremagic72 |
 Posted: 19:12 - 03 Dec 2005 Post subject: |
well done the pilot screw and everything else, went out on it today, and the same thing, even give it more revs and it still stalls, especially on a hill, on take of mainly.
the choke was off, had fuel in tank...
today it cut out and had to walk it home almost, tried it again after about 30 min, and got it going and managed to get home.
does anyone think the carb is full of crap and needs a good clean??
Or a good service.
Thanks people,
Baz.  |
| alains |
| puremagic72 |
 Posted: 22:43 - 03 Dec 2005 Post subject: |
so this means?
clean the carb?
is this easy on the ns125r??
Thanks,
Baz.  |
| alains |
 Posted: 23:45 - 03 Dec 2005 Post subject: |
it will takes about 2hours if you do anything suggested . it's not difficult , it requires order & application .
download my file https://www.geneva-racing.com/~alains/NSRtips.doc (1Mo) in this file taking off the carb is detailed
the manual is here : https://www.geneva-racing.com/~alains/NSRmanualDOC.zip (64Mo)
good job ! and by the way check how many notches has your needle (should be 4 or 5) and set it on the second notch from the top (you may set it on the third notch if your needle has 5) ____________________ the worst day fishing is better than the best day working |
| Zack |
 Zack L Plate Warrior
| alains |
| puremagic72 |
 Posted: 19:53 - 05 Dec 2005 Post subject: |
well, i went to tesco to fill her up, when i went to start it, it didn't want to start again, tried for about 20 min, and eventually it did, now the engine was warmed up, surely it should have started ok. but i am awaiting to hear from someone who can upjet the carb and clean it out. its not too bad starting in the morning now.
But i did get a new spark plug the other week, it was a BR9EIX which is supposed to be the best this time of year.
Thanks Alain.
Another question, i have a cap for the gearbox, a cap for the 2 stroke, a cap for the coolant, now do i have to fill up the cap for the radiator aswell, as this also has a cap, but its not easy to get to.
Baz.  |
The last post was made 20 years, 259 days ago. Instead of replying here, would creating a new thread be more useful? |
