CG125 - Cleaning various parts/Lubing
veeeffarr
PostPosted: 17:55 - 05 Dec 2005    Post subject: CG125 - Cleaning various parts/Lubing Reply with quote
Hi guys,
It's been a while since I've done anything cleaning wise to my CG, and was just wondering what products I need to buy for cleaning and aftercare.
I need:
Something for melted textile cooked onto exhaust (Nitromors?)
Something for cleaning the chain (Haven't cleaned it since I got it, just spray shit on it)
Something for lubing cables, contacts etc I think that the bit that connects my brakes to the wheel, kickstart pivot and basically everything that hinges and moves on my bike could do with a good squirt of something (Mainly to lube, and protection from corrosion would be a bonus!
Also, anyone know how to remove a CG125 Battery? Any precautions I need to take?
Thanks,
Toby
Bendy
Mrs Sensible
PostPosted: 17:56 - 05 Dec 2005    Post subject: Reply with quote
I use old engine oil to clean the chain.
Well I am Scottish. Razz
veeeffarr
PostPosted: 17:57 - 05 Dec 2005    Post subject: Reply with quote
I was thinking of swallowing it and drinking diet coke.
mchaggis
PostPosted: 18:43 - 05 Dec 2005    Post subject: Re: CG125 - Cleaning various parts/Lubing Reply with quote
Elbow grease. Razz Autosol might well be useful.
Take it off and clean it with a toothbrush and WD40/ paraffin. A wire brush can be useful for rust on the outside. Old engine oil is always useful stuff for lubing, just it gets flung off pretty quickly.
Cables want 3 in 1 spray lube, switches want WD40, electrical contacts want some emery paper/ wire wool and then vaseline (not grease).
Seat and sidepanel off, unscrew/ unbolt the negative terminal first, then the positive. There's a strap to hold it in. Touching the terminals/ frame is fine, so long as you don't let anything bridge them (including your hand) and short it out. Avoid removing the positive before the neutral, or you'll short it out through the frame if you're not careful.
When putting the battery back in, attach the positive first, then the neutral.
I must not be a troll...
Mmmm, Guinness
The last post was made 20 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 42.44 Kb
