Parking Lights...
gimpy limp
PostPosted: 20:16 - 05 Dec 2005    Post subject: Parking Lights... Reply with quote
When you have the ignition set to P what should it be doing? With my bike the headlight and the rear light turns itself on; is this what it should be doing? Could anyone kindly check with their bike be a big help?
Also should the 'PO' (I presume that means parking aswell) do the same as the ignition 'P'? The PO on my handlebars does nothing should I just cover that up for the mot if the one on the ignition works fine?
https://img323.imageshack.us/img323/8474/bikeodometer002photoshopped4gr.th.jpg
https://img323.imageshack.us/img323/8474/bikeodometer002photoshopped4gr.jpg
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
loply
PostPosted: 20:30 - 05 Dec 2005    Post subject: Reply with quote
P for Parking usually puts a very dim light on the front and rear, not quite a full headlight. Its designed in case you need to park your bike on an unlit road, so nobody hits it.
It shouldnt be the full headlight as this will run your battery down.
No idea what the PO is about.
Yamaha SZR660 Caution to the wind, the throttle pinned!
NSR-Rulez
if you turn your ignition to P your front light and rear light should light up, so yours sound like they are working fine PO i am not sure on as my bikes don't have that.
Parking lights are not an MOT issue anyway, thats what my MOT center said
Hope that helps
NSR-Rulez
Past: 1985 Suzuki GS 125 + 2002 Honda NSR 125 R-2 + Ford Fusion
Present: Honda CBR 600 RR-5 + Suzuki SV650S-K4 + Mitsubishi FTO GPX
colin1
Captain Safety
PostPosted: 04:24 - 06 Dec 2005    Post subject: Reply with quote
i hate the parking light thing as its very close to the steering lock position. One time i left it on by mistake and drained my battery.
I dont think I would ever use the parking lights intentionally.
R4nger
PostPosted: 08:44 - 06 Dec 2005    Post subject: Reply with quote
Sounds like your parking light is blown or the wiring has gone if your PO does not work. I assume the PO is the parking light. It is the same light at the front that is activated when you select P.
The last post was made 20 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 44.35 Kb
