have i broke it ?
firefox
PostPosted: 23:41 - 09 Dec 2005    Post subject: have i broke it ? Reply with quote
I was clening my brakes and erm one piston poped out and erm brake fluid pissed out, it pushed back in but have i broke it or will it be fine wen i refill the fluid ? Brick Wall
Stevie GooGs
PostPosted: 23:43 - 09 Dec 2005    Post subject: Reply with quote
i would bleed the brakes to make sure they are ok
firefox
PostPosted: 23:51 - 09 Dec 2005    Post subject: Reply with quote
ill see 2 mora i pray to god i aint broke it but saying that can get them for cheap enough Very Happy well cough cough my mams money can get them Very Happy lol cheers for the help.
T1z3R
PostPosted: 23:55 - 09 Dec 2005    Post subject: Reply with quote
it shouldn't be broken mate but you will have air in the system now that will need bled as stevie mentioned.
duck my sick!
The Tot
PostPosted: 00:10 - 10 Dec 2005    Post subject: Reply with quote
By allowing the fluid to gush out you've effectively let a volume of air into the system. Allowing the piston to pop out is not a bad thing. Actually it tells you that they aren't siezed, which in winter IS BAD.
Do a bleed of the whole system - using the squeezy ketchup or shampoo bottle to create the vacuum and draw everything out. Then, once all the air bubbles are removed, bleed as you would normally for the last 2 times.
They're not broken if you're worried. You can put it down to experience.
Ooh, one thing, make sure the dust seals on the piston are intact. Come winter with all the road grit, it may foul the piston without it being in place!
Never argue with autism
Teaman
sounds to me like you pumped em out as far as poss to clean and grease em because of the salt but over did it,
Im impressed that you popped the piston back in,,
give the break a good clean and bleed ant then check the piston for leaks, easy to do so not to worry,
doesnt sound like any worrys
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
firefox
PostPosted: 00:29 - 10 Dec 2005    Post subject: Reply with quote
well what caused it was right piston was seized so left one could move all the way and it just kinda poped out when i pumped it Embarassed and yer the whole thing was covered in crap im not riding no more until nicer weather commin off hurts Neutral
firefox
PostPosted: 00:31 - 10 Dec 2005    Post subject: Reply with quote
big screwdriver Very Happy very big lol amazing what you can do when your angry and yes dont worry i put wood on so i didnt damage it.
The Tot
PostPosted: 00:34 - 10 Dec 2005    Post subject: Reply with quote
Trick here is to leave the master cylinder/brake reservoir lid open. Seeing that you need to bleed the brakes anyway, it's not going to make a difference, but it will make pushing the pistons back a HELLUVA lot easier as you don't have to apply a force against a vacuum. Next time you're cleaning the calipers, stick a block of wood in between the pistons so that the piston doesn't go out fully!
firefox
PostPosted: 01:57 - 10 Dec 2005    Post subject: Reply with quote
the screws were stripped so i coundt drilled the heads off them without damagin the resvor in any way and unsrewed them with pliars so jst need som new screws Brick Wall
ZRX61
Victor Meldrew
PostPosted: 03:49 - 10 Dec 2005    Post subject: Reply with quote
It's gonna end in tears...
firefox
PostPosted: 17:16 - 10 Dec 2005    Post subject: Reply with quote
drilled the screws out Very Happy filled it up got new screws all sorted Smile
thanks for all the help guys
pj25
PostPosted: 21:29 - 10 Dec 2005    Post subject: Reply with quote
still on the tit then. Thumbs Up
wasnt me, honest!!!!!
The last post was made 20 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.37 - MySQL Queries: 14 - Page Size: 76.18 Kb
