NS125R-K
Mark
Guest
PostPosted: 06:07 - 26 Jan 2002    Post subject: NS125R-K Reply with quote
How do you derestrict this model is it the same way as the NSR125R?
What top speed do these do & does the alcast NSR R swingarm bolt directly on?
AndyB
Guest
PostPosted: 13:45 - 26 Jan 2002    Post subject: NS125R Reply with quote
Hello mate
The NS is a bit different to the NSR, but believe me once derestricted you'll have a whole lot more fun! You'll have to drill the exhaust, and the pipe is welded in there good and solid on the NS. None of this 3 little weld points on theses old babies, this bugger is solid. Also, on the right hand side of the engine as you sit on the bike there is a large nut. Undo it and you will see there is a bar coming off the nut ending in a sort of plate that blocks off access to the exhaust section of the cylender. Take a hacksaw to this and cut off the bar and plate, screw the nunt back in and you now own a NS that'll do around 90 and get there pretty 'kin quick! You can drill the airbox as well, but this will mean rejetting the carb and I haven't done this yet so I cant comment, but I'll let you know how it goes when I do...
Stay upright..
There is a gap of 3 years, 321 days between these two posts...
puremagic72
PostPosted: 21:09 - 12 Dec 2005    Post subject: Reply with quote
ant chance of a picture of this large nut?? as i also have this model and could only get 50 out of it!!!
YES 50MPH!!!!!!
tHANKS,
bAZ. Thumbs Up
Rookie
PostPosted: 21:12 - 12 Dec 2005    Post subject: Reply with quote
Oi, stop bringing up old threads, shit head!
PostPosted: 21:47 - 12 Dec 2005    Post subject: Reply with quote
Exhaust is a pig to derestrict, but whatever you do, do not touch that bolt. There is a chamber beside the exhaust that on the full power versions is closed at high revs and open at low revs. If anything you want to block it up effectively rather than chop the bolt down.
The last post was made 20 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.62 - MySQL Queries: 13 - Page Size: 42.06 Kb
