yamaha rsx100 clutch
lew
PostPosted: 12:39 - 13 Dec 2005    Post subject: yamaha rsx100 clutch Reply with quote
what side of the engine are the clutch plates located? the clutch cable goes into the left hand side of the engine so does this mean the plates are on the left?
rg 250 freak
PostPosted: 12:45 - 13 Dec 2005    Post subject: clutch Reply with quote
i think on the few that i have stripped they have been on the right if they operate from a push rod set up cause most electrical / magnetos are on the left dont know why thats just what i have noticed
Full throttle all the way
PostPosted: 13:23 - 13 Dec 2005    Post subject: Reply with quote
Japanese bikes usually have the clutch on the right. I have never seen one that isn't.
mchaggis
PostPosted: 14:16 - 13 Dec 2005    Post subject: Reply with quote
Edit: I should learn to read the thread title...
What bike have you got? The drive chain on the Rotax 650 engine used in the Pegaso and F650 is on the right: the clutch is on the left for that engine with the generator on the right, and may also be for a few other European bikes.
I must not be a troll...
Mmmm, Guinness
JamesVFR This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
PostPosted: 18:42 - 15 Dec 2005    Post subject: Reply with quote
JamesVFR wrote:
Which has got what to do with the RXS? The cable goes into the left but the plates and basket is on the right. You'll need to fabricate a tool, or buy/borrow a yamaha tool to undo the center nut if your looking to change the plates.
I've not been in the guts of an RXS but I wouldn't imagine you would need to take the centre nut off to get the plates out. You usually undo the five or six bolts holding the springs in place then just pull the plates out. You can usually leave the basket in place.
mchaggis
PostPosted: 22:37 - 15 Dec 2005    Post subject: Reply with quote
Just a guess at which side the clutch was on, pointing out that not all clutches are on the right, especially as the cable enters the left on his. If he's taking the clutch to pieces, he needs a manual, not just the say so of an internet forum.
Mmmm, Guinness
Guest
PostPosted: 23:07 - 15 Dec 2005    Post subject: Reply with quote
Yamaha RT 100 from the Yam USA site - can't be a million miles out
https://houseofmotorcycles.bikebandit.com/partsbandit/assets/schematics/Yamaha/YA4753_13.gif
hazza
PostPosted: 23:14 - 15 Dec 2005    Post subject: Reply with quote
did the clutch on mine a few weeks ago...ther on the right, you dont need a yamaha tool, and it took about 20 mins to do...easy peasy....
ianwhtvr
PostPosted: 14:19 - 01 May 2006    Post subject: Reply with quote
Listen to hazza, the clutch cable goes in the left witch operates the clutch push rod also on the left the clutch basket is on the right hand side. drain oil off take right hand casing off to expose the clutch housing should be four bolts going through the middle off springs undo these to expose the plates.(important)there are 4 friction plates, 5 plain plates and 4 anti-drag plates take note of what order they come off then put new ones back on in the same order.
not sure how true this is but i've heard ov people soaking the plates in engine oil for a night or so but i cant see wot this could possibly do hope ive helped let me know. follow wot ive said and you cant go far wrong honestly good luck
ian
The last post was made 20 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.89 - MySQL Queries: 13 - Page Size: 65.84 Kb
